1970 Cuda disc brake conversion question #2223622
12/30/16 09:31 PM
12/30/16 09:31 PM
Connecticut
biginchmotor Offline OP
Connecticut
A friend is changing over his front drums to disc brakes on his 70 cuda. I see inline tube sells the proper valve to do this. Would someone have a reference picture of this valve mounted on the car? Also there is another hold off valve shown in their product picture. How does this valve mount? The picture shows this small valve but I do not see a mounting bracket. Thanks John.
Re: 1970 Cuda disc brake conversion question [Re: biginchmotor] #2223693
12/30/16 11:26 PM
12/30/16 11:26 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
The service manual showes the different valves
Re: 1970 Cuda disc brake conversion question [Re: biginchmotor] #2223711
12/30/16 11:46 PM
12/30/16 11:46 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Drums or discs on the rear?
Gus beer
64 Plymouth Savoy
Dana 60
Re: 1970 Cuda disc brake conversion question [Re: biginchmotor] #2223721
12/30/16 11:53 PM
12/30/16 11:53 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
I think this is later than you are requesting but it's a start
Re: 1970 Cuda disc brake conversion question [Re: UCUDANT] #2223750
12/31/16 12:30 AM
12/31/16 12:30 AM
Connecticut
Connecticut
The car has 11 inch drums in the rear. That is a great picture. I do not have a factory service manual handy, would someone have an illustration for a 70 -71 cuda disc brake car ? Thanks John.
Re: 1970 Cuda disc brake conversion question [Re: biginchmotor] #2223751
12/31/16 12:36 AM
12/31/16 12:36 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I avoid the In-Line brand proportioning valve (PV) has too many issues from leaks to non functioning, to stuck valve assys, buy the one from FINELINES
here's a few photos
Re: 1970 Cuda disc brake conversion question [Re: DAYCLONA] #2223759
12/31/16 12:47 AM
12/31/16 12:47 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
more
Re: 1970 Cuda disc brake conversion question [Re: DAYCLONA] #2224125
12/31/16 04:58 PM
12/31/16 04:58 PM
Connecticut
Connecticut
Thanks for posting those pictures dayclona. I went to fine lines web site and could not find that part #. I will give them a call Tuesday morning. John.
Re: 1970 Cuda disc brake conversion question [Re: biginchmotor] #2224138
12/31/16 05:24 PM
12/31/16 05:24 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
IIRC FINELINES uses the same PN# as IN-LINE TUBE, part is from the same oversea vendor (China repro) but FINELINES disassembles and rebuilds/tests the unit prior to shipping to customer because of the known issues with this valve, IN-Line Tube just repackages it for resale
mike
Re: 1970 Cuda disc brake conversion question [Re: DAYCLONA] #2224219
12/31/16 07:10 PM
12/31/16 07:10 PM
Connecticut
Connecticut
Good info, thanks again.
Re: 1970 Cuda disc brake conversion question [Re: biginchmotor] #2225175
01/01/17 11:44 PM
01/01/17 11:44 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
I also swapped a front disc set up from a 70 cuda to another 70 cuda with an automatic floor shift, my problem is that the rear proportional valve bolts into the frame in the same spot that the reverse lock out z-bar bracket attaches to I think? that picture I would like to see if anyone has that combination..
Re: 1970 Cuda disc brake conversion question [Re: biginchmotor] #2225428
01/02/17 11:31 AM
01/02/17 11:31 AM
Georgia
magiccuda Offline
magiccuda  Offline
Georgia
If Im not mistaken fine lines no longer sells them, You might try MP brakes.
Re: 1970 Cuda disc brake conversion question [Re: AARCONV] #2225590
01/02/17 02:54 PM
01/02/17 02:54 PM
Ky
jt4406 Offline
jt4406  Offline
Ky
AARConv, I believe the valve bolts on farther back than the lockout linkage. In this pic of my car you can see the tapped bolt holes for the linkage bracket ahead of the valve.
jess
Yeah, it's hopped up to over 160...
Re: 1970 Cuda disc brake conversion question [Re: biginchmotor] #2225639
01/02/17 04:01 PM
01/02/17 04:01 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Here is a good picture of an E-body prop valve installed:
https://board.moparts.org/ubbthreads/upload2/2901851-PropValve.JPG
