Any tips for rear main seal install?
#222324
02/12/09 05:59 PM
02/12/09 05:59 PM
Posts: 1,523 Oakley CA
69charger440_6pa
Oakley CA
Just curious if there were any tips I need to know when installing a rear main seal on a BB mopar? Both motors I have built had dribbled from the rear main. My current motor (493) is going to get the rear main replaced because I am sick of having oil spots in my garage and I dont want it to leak again.
1969 Charger R/T under construction 2014 Ram 3500 Cummins 2006 Corvette Z06 2015 Corvette Z06 2014 BMW M5
Re: Any tips for rear main seal install?
[Re: RemCharger]
#222326
02/12/09 07:09 PM
02/12/09 07:09 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I laughed when I saw this thread, I'm doing my seal tonite and just got off the phone with DodgeTony as I was asking questions about it.
[Re: RemCharger]
#222327
02/12/09 07:14 PM
02/12/09 07:14 PM
Posts: 760 Southington Ct.
turbobitt
Southington Ct.
Who's rear main seal retainer are you using ? My experience has been that most aftermarket retainers are poorly engineered and don't meet the original design requirements. If you look closly to the aftermarket retainers, they have a clearance cut for the oil slinger but absolutly no provisions for oil drainback between the seal and oil slinger. In some cases, the seal retainer is so close to the rear main cap, it almost touches and further reduces oil drainback and causes pressureized oil against the seal. The best fix for this is to mill out the material to allow oil drainback like the original retainers. Another suggestion is to check clearance between your main cap fastners and seal retainer and if you are using rear studs than it will most likley interfer. This can also be clearanced with a grinding tool. You may want to read up on this guy and what he found. http://www.dodgecharger.com/forum/index.php/topic,51149.0.html If you are using a stock retainer, than you will probably have good luck but check clearance between main bolts/studs and retainer.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: turbobitt]
#222328
02/12/09 07:19 PM
02/12/09 07:19 PM
turbobitt
Southington Ct.
I cut and pasted from another post so some of the info is the same from the previous post.
I have had leaking rear main seal and this is what I found.
1. The main studs often interfer with the seal cap. Make sure there is clearance between the top of the main studs and around the nut.
2. Some of these aftermarket caps are solid on the end facing the cap with the oil slinger clearance cut. The cap will mate flush with the main cap and not allow oil to drain from the slinger area. Oil pressurized from priming/running will overcome the seal and find its way on the floor if not allowed to vent. Note the open/profiled area in the factory seal retainer.
3 - If the crank was out of the engine, bolt the main cap and torque. Then bolt on the seal retainer with the seals and check alignment of the seal halfs. With the slop in the holes, it is possible for the halfs not to line up and sensitive with the rubber/neoprean knife edged seals. This is not an issue with a wide rope seal. With the seal cap slightly lose, you can line it up and scribe a line accross the top of the seal retainer and block to correctly assemble later with the crank in the block.
[Re: turbobitt]
#222329
02/13/09 04:00 PM
02/13/09 04:00 PM
69charger440_6pa
Oakley CA
Thanks for the tips. I have one of the aftermarket rear seals, I think its INDY but I dont remember. I wont be using it.... POS in my mind. I have an extra stock one laying around that I will be using.
Thanks again
[Re: boscosis]
#222331
02/13/09 05:49 PM
02/13/09 05:49 PM
Posts: 5 Monroeville, OH
midnight maniac
Monroeville, OH
Like RemCharger said try and rotate the seal so that the seal DOES NOT meet at the part line of the retainer. Also use just a dab of RTV on the ends of the seal. And one more thing coat the vertical strips in RTV.
'69 Road Runner 528 B-1 headed pump gas. Best 9.39 @ 142. 3320#
