Any tips for rear main seal install? #222324
02/12/09 05:59 PM
02/12/09 05:59 PM
Oakley CA
69charger440_6pa Offline OP
Oakley CA
Just curious if there were any tips I need to know when installing a rear main seal on a BB mopar?
Both motors I have built had dribbled from the rear main. My current motor (493) is going to get the rear main replaced because I am sick of having oil spots in my garage and I dont want it to leak again.
1969 Charger R/T under construction
2014 Ram 3500 Cummins
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Re: Any tips for rear main seal install? [Re: 69charger440_6pa] #222325
02/12/09 06:57 PM
02/12/09 06:57 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
A neat tip is to tilt it slightly so the ends meet in the slotted part ,not the part line.
I'd like to hear if there is a down side to this.
Re: Any tips for rear main seal install? [Re: RemCharger] #222326
02/12/09 07:09 PM
02/12/09 07:09 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I laughed when I saw this thread, I'm doing my seal tonite and just got off the phone with DodgeTony as I was asking questions about it.
Re: Any tips for rear main seal install? [Re: RemCharger] #222327
02/12/09 07:14 PM
02/12/09 07:14 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
Who's rear main seal retainer are you using ?
My experience has been that most aftermarket retainers are poorly engineered and don't meet the original design requirements. If you look closly to the aftermarket retainers, they have a clearance cut for the oil slinger but absolutly no provisions for oil drainback between the seal and oil slinger. In some cases, the seal retainer is so close to the rear main cap, it almost touches and further reduces oil drainback and causes pressureized oil against the seal. The best fix for this is to mill out the material to allow oil drainback like the original retainers.
Another suggestion is to check clearance between your main cap fastners and seal retainer and if you are using rear studs than it will most likley interfer. This can also be clearanced with a grinding tool.
You may want to read up on this guy and what he found.
http://www.dodgecharger.com/forum/index.php/topic,51149.0.html
If you are using a stock retainer, than you will probably have good luck but check clearance between main bolts/studs and retainer.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: Any tips for rear main seal install? [Re: turbobitt] #222328
02/12/09 07:19 PM
02/12/09 07:19 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
I cut and pasted from another post so some of the info is the same from the previous post.
I have had leaking rear main seal and this is what I found.
1. The main studs often interfer with the seal cap. Make sure there is clearance between the top of the main studs and around the nut.
2. Some of these aftermarket caps are solid on the end facing the cap with the oil slinger clearance cut. The cap will mate flush with the main cap and not allow oil to drain from the slinger area. Oil pressurized from priming/running will overcome the seal and find its way on the floor if not allowed to vent. Note the open/profiled area in the factory seal retainer.
3 - If the crank was out of the engine, bolt the main cap and torque. Then bolt on the seal retainer with the seals and check alignment of the seal halfs. With the slop in the holes, it is possible for the halfs not to line up and sensitive with the rubber/neoprean knife edged seals. This is not an issue with a wide rope seal. With the seal cap slightly lose, you can line it up and scribe a line accross the top of the seal retainer and block to correctly assemble later with the crank in the block.
Re: Any tips for rear main seal install? [Re: turbobitt] #222329
02/13/09 04:00 PM
02/13/09 04:00 PM
Oakley CA
Oakley CA
Thanks for the tips. I have one of the aftermarket rear seals, I think its INDY but I dont remember. I wont be using it.... POS in my mind. I have an extra stock one laying around that I will be using.
Thanks again
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Re: Any tips for rear main seal install? [Re: 69charger440_6pa] #222330
02/13/09 04:57 PM
02/13/09 04:57 PM
boscosis Offline
super street
boscosis  Offline
super street
I'm considering tossing the vertical strips and filling the grooves with RTV. Has anyone tried this?
Re: Any tips for rear main seal install? [Re: boscosis] #222331
02/13/09 05:49 PM
02/13/09 05:49 PM
Monroeville, OH
midnight maniac Offline
Monroeville, OH
Like RemCharger said try and rotate the seal so that the seal DOES NOT meet at the part line of the retainer. Also use just a dab of RTV on the ends of the seal. And one more thing coat the vertical strips in RTV.
'69 Road Runner 528 B-1 headed pump gas. Best 9.39 @ 142. 3320#
Re: Any tips for rear main seal install? [Re: boscosis] #222332
02/13/09 06:24 PM
02/13/09 06:24 PM
Cab_Burge Online work
Cab_Burge  Online Work
I leave the vertical strips in and follow the instruction using the mineral spirits on them after the seal holder is tight, I use a small 5 cc syringe and squirt the mineral sprits down the srips on both sides of the seal holder. I let it dry over night and then silicone the whole back of the seal holder up from the oil pan rail to the block. I have found some of the main seals are installed backward, the sealing lips where installed towards the torque converter instead of installed towards the # 5 rear main bearing You want the crankcase pressure to try and blow the sealing lip tighter onto the crankshaft, not blow it open
Re: Any tips for rear main seal install? [Re: Cab_Burge] #222333
02/13/09 06:29 PM
02/13/09 06:29 PM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
So what you are saying is that the tapered edge of the seal should face the front of the engine? I think that's what the instructions said although a picture would have been better.
Re: Any tips for rear main seal install? [Re: Classof70Chally] #222334
02/13/09 07:27 PM
02/13/09 07:27 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Tapered side is to the rear, think of a barb, movement in one direction causes no resistance, going the other way isn't allowed...
Re: Any tips for rear main seal install? [Re: 69charger440_6pa] #222335
02/13/09 07:31 PM
02/13/09 07:31 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Yes offset the seal in the retainer. Lip of the seal inward so that any oil splash or pressure build up forces the lip tighter against the sealing surface. Taper of the lip in and the pressure or oil splash can push the lip of seal outward or downward causing a leak. there should be a paint ring on the seal and the directions will show which directions the ring should be.
Re: Any tips for rear main seal install? [Re: MoparforLife] #222336
02/28/09 11:37 PM
02/28/09 11:37 PM
Port Alberni, British Columbia
MoparDonny Offline
MoparDonny  Offline
The New Mopar seal kit is a joke. The side seals are little orange noodles that are impossible to keep from moving when installing the retainer. How is mineral spirits gonna help a noodle??? I seem to remember those seals being a solid material of some sort IIRC??? My dad thinks he's got one leaking on a freshened 383 and I'm not to comfy with mine in the 451 i have downstairs right now!!
Don.
Re: Any tips for rear main seal install? [Re: MoparDonny] #222337
03/01/09 01:39 AM
03/01/09 01:39 AM
Bowling Green KY / Nashville, ...
300by500 Offline
300by500  Offline
So the Mancini one in my 496 that's still at the machine shop will probably leak?
Great....spent the money because of the rubber side seals...
Re: Any tips for rear main seal install? [Re: 69charger440_6pa] #222338
03/01/09 02:13 AM
03/01/09 02:13 AM
AndyF Offline
AndyF  Offline
I've been using the billet rear main seal kit from Mancini Racing on all of my motors now for a few years. The motor in the picture has been on and off the dyno now for over 2 years and the rear main area is dry as a bone.
Re: Any tips for rear main seal install? [Re: AndyF] #222339
03/01/09 02:49 PM
03/01/09 02:49 PM
MoparDonny Offline
MoparDonny  Offline
What type of side seals go into that billet retainer,Andy?? Guess I could just look at Mancini's site
Just looked on their site and guess this is the one. 69 bucks sounds decent. How good does it go together with those doubled side seals?
Don.
Re: Any tips for rear main seal install? [Re: MoparDonny] #222340
03/01/09 04:26 PM
03/01/09 04:26 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mine don't leak. This is how I do them. First make sure the rear pan bolt holes are not cracked in the retainer. I use the factory GM sealer. I have worked for the dark side for 26 years. This is the best sealer I have ever used. I put a small line of anerobic sealer between the retainer and block. Then a SMALL dab of GM sealer on the seal ends where they but together. Fill the side grooves with sealer. You can use the filler strips as well if you want to. Make sure there are no voids. Slip the retainer in and use a putty knife to fill the v shapped crevice on the outside of the block. I've built 6 in the last year,none leak.
Good Luck Doug
