Re: Differences between '67-'69 Barracudas
[Re: big-block-dave]
#50654
03/19/09 03:00 PM
03/19/09 03:00 PM
Posts: 1,187 USA
big-block-dave
USA
How about fenders? Other than the side marker difference, the '69 has 2 angled tabs welded on the head light bucket to screw the plastic head light trim/bezel to. So if you use a '67-8 fender for a '69 you need these tabs.
I'm the CARETAKER of Weinstats '69 440 'cuda registry and have 104 of the 360 cars to date. 84 fastbacks/20 coupes. Always looking for new(REAL M-code) '69 440 'cudas to add to the registry so drop me a note if any are found or known. This isn't a publicly released registry. Thanks, Dave
[Re: 6T6Cuda]
#50659
03/21/09 10:03 AM
03/21/09 10:03 AM
Posts: 1,187 USA
big-block-dave
USA
I believe there is a difference with trunk lids. '67 has a frame with a outer skin(like a hood) where '69 has 2 solid skins with the frame as part of the inner skin. I'm not sure which way a '68 is. I have a '68 lid but can't get to it at this time.
#50660
03/21/09 10:14 AM
03/21/09 10:14 AM
Posts: 1,187 USA
big-block-dave
USA
I DON"T believe the bumper gaurds were further apart on '69 as a earlier post said. If you look here the guards are on the outside but notice in the older pic someone added those TALL guards in the middle and moved the factory guards out!! That is very odd looking with guards on the out side! Maybe this is where the poster saw this without seeing the old pic? I have car #29 survivor with 21K miles and it is correct position as factory. http://www.mooresmopars.com/modtop1.html
[Re: 6T6Cuda]
#50663
12/03/09 07:53 PM
12/03/09 07:53 PM
Posts: 2,601 Great White North
Furyman
Great White North
In 69 A bodys the pan that is just forward of the trunk pan changes.67/68 and up to mid 69 has a well in it...mid 69 and up is smooth.
"Long Live Mopars"
[Re: Furyman]
#50664
12/05/09 09:08 PM
12/05/09 09:08 PM
Posts: 1,187 USA
big-block-dave
USA
I've heard that '67 notchback rear window is smaller than a '68 & '69??????? Therefore the opening is also smaller. How much????
#50665
12/05/09 09:16 PM
12/05/09 09:16 PM
Posts: 27,467 So Cal
autoxcuda
So Cal
I don't know about that one. Even with notchbacks I think people convert the rear window molding to the 68/69 stainless style. If it was a different size opening the molding wouldn't work.
[Re: 69Cuda340S]
#2219947
12/24/16 12:46 AM
12/24/16 12:46 AM
Posts: 8,241 fredericksburg,va
cudaman1969
fredericksburg,va
Just a little something I have learned about a 69 hood,a dart sport hood is a bolt on and can be spotted right away by the crumple zone. Any '73 up Dart hood will bolt right on and look correct. I believe the braces under the hood are different. A little more clarification on the hoods. I have a 73 Dart hood with no crumple zones and another with, and two rusted up 69s. The ribs are the same as far as I can tell and the 73s have the little bolt cutouts for the 69 scoops so my feeling they used the same ribs from 69 other than the adjusting pieces for the hinge and crumple zone latter in the year.? They will bolt on but have no adjustment unless you use the same year hood-hinges, 73-73 and 69-69 . I have a 68 and 69 fb trunk lid and see no difference except trim holes. 69s had two maybe three steering wheels, cheapo three spoke with holes and thin hard rubber band, second same spokes but wood looking band with ss strips around band, third was a rim blow type, not compleatly sure on that but what I heard. Also heard but not sure, the bumper guards on 69 (witch I have) where splayed out on the back but straight forward on the front. The guards I have now (4 out of 10) are made this way so?? 69s S and Cudas have spring torque boxes in the rear, convertibles have rear and front. 440 engine has a unique driver side motor mount.
[Re: 6T6Cuda]
#2220568
12/25/16 04:59 AM
12/25/16 04:59 AM
Posts: 1,653 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
The Formula S round medallions are the same part number for '67-'68, one on each front fender, total 2. These have wide silver outer rings and are readily obtainable.
In '69 the round medallion was re-designed with a narrow black outer ring and moved to the tail panel, just one. Layson's used to sell a re-pop until 2008. Except for the Layson's version, I've never seen one of these for sale anywhere.
There were also "340-S" emblems in 1969 only for the front fenders when the upper body stripe with engine call out was deleted. But I've seen lots of cars with both these emblems and the upper body stripes, which isn't factory correct as I understand it. Were there "383-S" emblems?
[Re: 6T6Cuda]
#2223364
12/30/16 02:30 PM
12/30/16 02:30 PM
Posts: 3,392 cheshire, ct
davesmopars
cheshire, ct
yes the 67 notchback rear window is smaller. but the opening is the same as 68 and 69
I did years ago, I had all 3 year next to each other and did a comparison at my house. Going on memory so I might get years messed up but I will be close. 67 68 cowls are differs for 69 all three year the fire was is different all 3 years the radiator support header is different all 3 years the sides of the radiator support are different I there was something on the 67 in the roof that was different I think the inside of the trunk the trail light brackets a little different 67 inner fender are different front license plate brackets is different I think 67 had no slots at the top 69 shoulder belts January of 69 mandatory headrest The fastback fold down seat hinge bracket on the seat chrome on 67 and 68 natural on 69 also and the part that screws to the body different one was cast steel and the I believe the other was cast aluminum seat belts different hood release different all 3 yeas 67 68 are close but different 68 astray key light heater cables in 67 different 67 bucket seat reinforcements different 68 69 There is more sheet metal on the body that is different have think some more.
Keeper of the 440 M code Cuda registry mcodecuda@yahoo.com
[Re: 75RoadRunner]
#2226999
01/04/17 11:41 AM
01/04/17 11:41 AM
autoxcuda
So Cal
What about the horn button on the steering wheels. I have seen some with a Plymouth emblem in the center, and some with a Barracuda(fish) emblem. I have seen both on all 3 years. What determines when it would have the Plymouth emblem verses the fish emblem? Great old thread that I am glad someone drug up. 69 = fish emblem
