Ebody drum spindles - Which side? #2222301
12/28/16 05:54 PM
12/28/16 05:54 PM
Texas
GoodysGotaCuda Offline OP
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I have spindles #35696N58 and #2535696 66 [from what I can read]. Any idea which is the drivers side?
Thanks-
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Ebody drum spindles - Which side? [Re: GoodysGotaCuda] #2222314
12/28/16 06:20 PM
12/28/16 06:20 PM
I'm assuming they are identical enough that a person cant tell from a visual. the angle must be slightly different as something is cuz as we know whenever there was a change however slight Ma put a different casting # on there. well here is a BTT for ya
Re: Ebody drum spindles - Which side? [Re: RapidRobert] #2222332
12/28/16 06:39 PM
12/28/16 06:39 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
'70-'72 B&E-body drum brake spindles are the same left to right (same part number 2535697)
part numbers are often 1-off from actual forging/casting numbers
2535696 = as forged
2535697 = as machined
Re: Ebody drum spindles - Which side? [Re: GoodysGotaCuda] #2222339
12/28/16 06:53 PM
12/28/16 06:53 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Thanks Dan, any idea what the 35696N58 fits or if it interchanges? It sure looks the same.
2020 RAM 1500
Re: Ebody drum spindles - Which side? [Re: GoodysGotaCuda] #2222356
12/28/16 07:19 PM
12/28/16 07:19 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
best guess it is a 2535696 forging (same part - different plant/manufacturer?)
