Re: Ebody drum spindles - Which side?
[Re: GoodysGotaCuda]
#2222314
12/28/16 06:20 PM
12/28/16 06:20 PM
RapidRobert
I'm assuming they are identical enough that a person cant tell from a visual. the angle must be slightly different as something is cuz as we know whenever there was a change however slight Ma put a different casting # on there. well here is a BTT for ya
[Re: RapidRobert]
#2222332
12/28/16 06:39 PM
12/28/16 06:39 PM
Posts: 17,516 Las Vegas, NV
6bblgt
Las Vegas, NV
'70-'72 B&E-body drum brake spindles are the same left to right (same part number 2535697)
part numbers are often 1-off from actual forging/casting numbers
2535696 = as forged 2535697 = as machined
#2222356
12/28/16 07:19 PM
12/28/16 07:19 PM
6bblgt
Las Vegas, NV
Thanks Dan, any idea what the 35696N58 fits or if it interchanges? It sure looks the same. best guess it is a 25 35696 forging (same part - different plant/manufacturer?)
