putting my 511 back in. #2221857
12/27/16 09:55 PM
12/27/16 09:55 PM
mississippi
bentwheel43 Offline OP
mississippi
I think the studs on the mains is 95# torque, on the 7/16 rods get 63#or 55# it has the ARP stuff. Can anyone help I thought the head studs on the Eddys got 70#.
Section 8 Racing We are nuts about racing.
Re: putting my 511 back in. [Re: bentwheel43] #2221892
12/27/16 11:12 PM
12/27/16 11:12 PM
What brand fasteners are you using?
Re: putting my 511 back in. [Re: Cab_Burge] #2221898
12/27/16 11:21 PM
12/27/16 11:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Cab .. he said ARP stuff
wave
Re: putting my 511 back in. [Re: MR_P_BODY] #2221903
12/27/16 11:27 PM
12/27/16 11:27 PM
I saw his reference to the ARP stuff and assumed he meant ARP lube confused
Re: putting my 511 back in. [Re: Cab_Burge] #2221913
12/27/16 11:35 PM
12/27/16 11:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I believe he has ARP studs and stuff but will
be using oil.. same as I do
wave
Re: putting my 511 back in. [Re: bentwheel43] #2221959
12/28/16 12:53 AM
12/28/16 12:53 AM
mississippi
mississippi
I use 30w oil, I bought the 440 source 512 kit in 09' and use studs both main&head. Even studded the water pump housing.
Re: putting my 511 back in. [Re: bentwheel43] #2221989
12/28/16 01:23 AM
12/28/16 01:23 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Hey Bentwheel, long time no see, still wrenchin, that's good thing. Where are you racing at now a days?
Re: putting my 511 back in. [Re: bentwheel43] #2222009
12/28/16 01:52 AM
12/28/16 01:52 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The 70# sounds right for 7/16 studs.. but I
would either look on line or wait for some one
that knows
wave
Re: putting my 511 back in. [Re: bentwheel43] #2222013
12/28/16 01:56 AM
12/28/16 01:56 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
ARP has a chart you can use.
http://arpinstructions.com/generaltorque.html
or the instructions for the BBM stud kit 140-5402.
http://arpinstructions.com/instructions/140-5402.pdf
Joe
Without Data, you’re just another guy with an opinion.
Re: putting my 511 back in. [Re: sr4440] #2222018
12/28/16 02:04 AM
12/28/16 02:04 AM
rowin4 Offline
rowin4  Offline
That chart is for use with ARP lube, not oil as stated that he use's. Oil will take a lesser torque. I use the ARP lube for assembly, haven't used oil in 20 years.
Re: putting my 511 back in. [Re: rowin4] #2222019
12/28/16 02:08 AM
12/28/16 02:08 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I'll just put this here for a guess-ta-ment but you know the proper way this should be done.
http://www.eaglerod.com/index.php?option=com_content&task=view&id=24&Itemid=25
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: putting my 511 back in. [Re: pittsburghracer] #2222023
12/28/16 02:19 AM
12/28/16 02:19 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Those specs are for rod bolts only
wave
Re: putting my 511 back in. [Re: MR_P_BODY] #2222031
12/28/16 02:32 AM
12/28/16 02:32 AM
PA.
"Little"John
"Little"John
PA.
wave
Ya I just had that one saved. Head bolts and main studs are usually real easy to find. Some heads (ex Stealth heads) have their own suggested torque spec.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: putting my 511 back in. [Re: pittsburghracer] #2222035
12/28/16 02:42 AM
12/28/16 02:42 AM
mississippi
mississippi
I thought I remembered 63# on them rods. I wanted to think 110# on the mains with APR lube. But with 30w oil 95#. I wrote it down but lost it from 2009.
Re: putting my 511 back in. [Re: rowin4] #2222040
12/28/16 02:54 AM
12/28/16 02:54 AM
mississippi
mississippi
I been racing the super summit races at Gulfport, in the yellow 23'Alter last year. Broke a roller lifter in the Duster in the KOC race year before last. We was racing good in that car. I have a good picture of the yellow car but don't know how to put it on here.
Re: putting my 511 back in. [Re: bentwheel43] #2222055
12/28/16 03:25 AM
12/28/16 03:25 AM
I think you have those numbers backwards, less torque with ARP lube and more torque with oil confused I'll look in my shop in the morning for that ARP part # spec sheet and post it on here tomorrow thumbs
Re: putting my 511 back in. [Re: Cab_Burge] #2222061
12/28/16 03:33 AM
12/28/16 03:33 AM
rowin4 Offline
rowin4  Offline
I think your right Cab, less torque with ARP assembly lube. First time being wrong. LOL I just read the torque numbers supplied by ARP. I did have at one time the torque numbers for assembly lube, oil and I think dry for different size fasteners.
Re: putting my 511 back in. [Re: bentwheel43] #2222173
12/28/16 01:48 PM
12/28/16 01:48 PM
mississippi
mississippi
OK, I got the APR lobe, 63f/p on the rods, the mains get 55/75/90 some say 100# I will go 95# with the lobe.
Re: putting my 511 back in. [Re: Cab_Burge] #2222183
12/28/16 02:03 PM
12/28/16 02:03 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I thought it was critical to assemble/torque to the same values that the parts were machined/torqued to including what lube was used. At Pettis if it was machined/torqued w/ARP lube at x amount of torque, then that's where it needs to be..........I know Jason said the ARP lube had changed over the years and found a few issues w/it but now landed on the stuff they like best............... thumbs
Re: putting my 511 back in. [Re: bentwheel43] #2222235
12/28/16 04:02 PM
12/28/16 04:02 PM
I found my copys of the ARP instructions, 1/2 inch main same as listed above.
ARP head stud kits list 80 ft. Lbs. with ARP Ultra Torque lube in three equal steps? work 80 divided by 3=26.66666 shruggy
I have the instructions for their BB Mopar head bolt kit with thier old lube and it shows to use 65 ft. lbs. with thier old ARP Moly Assembly lube or thread sealer and 85 Ft.Lbs. with 30 wt oil shruggy
On the rod bolts I use a stretch gauge and write down the average torque needed with the ARP lube needed to get to the middle strech specs., if one or more stretch longer than the average I throw them away and replace them with ones that meet the needed average torqe required to match the rest scope up
