putting my 511 back in.
#2221857
12/27/16 09:55 PM
12/27/16 09:55 PM
Posts: 635 mississippi
bentwheel43
mississippi
I think the studs on the mains is 95# torque, on the 7/16 rods get 63#or 55# it has the ARP stuff. Can anyone help I thought the head studs on the Eddys got 70#.
Section 8 Racing We are nuts about racing.
Re: putting my 511 back in.
[Re: bentwheel43]
#2221892
12/27/16 11:12 PM
12/27/16 11:12 PM
Posts: 43,190 Bend,OR USA
Cab_Burge
What brand fasteners are you using?
[Re: bentwheel43]
#2221959
12/28/16 12:53 AM
12/28/16 12:53 AM
bentwheel43
mississippi
I use 30w oil, I bought the 440 source 512 kit in 09' and use studs both main&head. Even studded the water pump housing.
[Re: bentwheel43]
#2221989
12/28/16 01:23 AM
12/28/16 01:23 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
Hey Bentwheel, long time no see, still wrenchin, that's good thing. Where are you racing at now a days?
[Re: bentwheel43]
#2222009
12/28/16 01:52 AM
12/28/16 01:52 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I use 30w oil, I bought the 440 source 512 kit in 09' and use studs both main&head. Even studded the water pump housing. The 70# sounds right for 7/16 studs.. but I would either look on line or wait for some one that knows
[Re: sr4440]
#2222018
12/28/16 02:04 AM
12/28/16 02:04 AM
rowin4
That chart is for use with ARP lube, not oil as stated that he use's. Oil will take a lesser torque. I use the ARP lube for assembly, haven't used oil in 20 years.
[Re: MR_P_BODY]
#2222031
12/28/16 02:32 AM
12/28/16 02:32 AM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Those specs are for rod bolts only Ya I just had that one saved. Head bolts and main studs are usually real easy to find. Some heads (ex Stealth heads) have their own suggested torque spec.
[Re: pittsburghracer]
#2222035
12/28/16 02:42 AM
12/28/16 02:42 AM
bentwheel43
mississippi
I thought I remembered 63# on them rods. I wanted to think 110# on the mains with APR lube. But with 30w oil 95#. I wrote it down but lost it from 2009.
[Re: rowin4]
#2222040
12/28/16 02:54 AM
12/28/16 02:54 AM
bentwheel43
mississippi
I been racing the super summit races at Gulfport, in the yellow 23'Alter last year. Broke a roller lifter in the Duster in the KOC race year before last. We was racing good in that car. I have a good picture of the yellow car but don't know how to put it on here.
[Re: Cab_Burge]
#2222061
12/28/16 03:33 AM
12/28/16 03:33 AM
rowin4
I think you have those numbers backwards, less torque with ARP lube and more torque with oil I'll look in my shop in the morning for that ARP part # spec sheet and post it on here tomorrow I think your right Cab, less torque with ARP assembly lube. First time being wrong. LOL I just read the torque numbers supplied by ARP. I did have at one time the torque numbers for assembly lube, oil and I think dry for different size fasteners.
[Re: bentwheel43]
#2222173
12/28/16 01:48 PM
12/28/16 01:48 PM
bentwheel43
mississippi
OK, I got the APR lobe, 63f/p on the rods, the mains get 55/75/90 some say 100# I will go 95# with the lobe.
[Re: Cab_Burge]
#2222183
12/28/16 02:03 PM
12/28/16 02:03 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
I thought it was critical to assemble/torque to the same values that the parts were machined/torqued to including what lube was used. At Pettis if it was machined/torqued w/ARP lube at x amount of torque, then that's where it needs to be..........I know Jason said the ARP lube had changed over the years and found a few issues w/it but now landed on the stuff they like best...............
[Re: bentwheel43]
#2222235
12/28/16 04:02 PM
12/28/16 04:02 PM
Cab_Burge
I found my copys of the ARP instructions, 1/2 inch main same as listed above. ARP head stud kits list 80 ft. Lbs. with ARP Ultra Torque lube in three equal steps? 80 divided by 3=26.66666 I have the instructions for their BB Mopar head bolt kit with thier old lube and it shows to use 65 ft. lbs. with thier old ARP Moly Assembly lube or thread sealer and 85 Ft.Lbs. with 30 wt oil On the rod bolts I use a stretch gauge and write down the average torque needed with the ARP lube needed to get to the middle strech specs., if one or more stretch longer than the average I throw them away and replace them with ones that meet the needed average torqe required to match the rest
