Page 4 of 5 1 2 3 4 5
Re: Article on Muscle Motors new block [Re: hemi-itis] #2221369
12/26/16 10:42 PM
12/26/16 10:42 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
Originally Posted By hemi-itis
If the weight loss program is done on a megablock,how much weight is taken out?? Will the block loose any strength??? work
I think maybe around 30-40 pounds
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: Article on Muscle Motors new block [Re: Old School] #2221382
12/26/16 11:13 PM
12/26/16 11:13 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Originally Posted By Old School
... I just bought an Indy aluminum block. Close to the same money, but 200 pounds lighter!!!No brainer....
What sort of additional work was required w/ the Indy block to make it "ready to assemble", and would you be willing to give an approximate cost of what the block plus any necessary finishing work totaled?
Hey Brad. the block was $4835. cnc clearance for the large stroke was $250. large bore sleeves were $100. total was about $5185.00.
boring honing ect...would be the same as any block.
Re: Article on Muscle Motors new block [Re: Old School] #2221395
12/26/16 11:34 PM
12/26/16 11:34 PM
BradH Offline
BradH  Offline
My 4.530 mega block weighs 330 pounds. The indy block weighs 130 pounds. a stock block weighs 230 pounds.
Those weights are consistent with what I've heard, too. I know some Mega blocks came with thinner cylinders that couldn't be bored out as far as the best ones, and would expect their weights would vary accordingly.
Re: Article on Muscle Motors new block [Re: AndyF] #2221470
12/27/16 01:35 AM
12/27/16 01:35 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I just weighed the Megablock I have here. it is the version with the flat face in front of the oil pump. No machining has been done yet. With caps, 4.19 rough bore, it is 292 pounds. Boring to 4.500 will reduce it by 30 pounds using a weight of .259 pounds per cubic inch for cast iron and a 7" bore length. So there is a big variance in weight of these cast iron blocks.
Re: Article on Muscle Motors new block [Re: Hemi_Joel] #2221473
12/27/16 01:43 AM
12/27/16 01:43 AM
I have weigh several stock 440, 426W,383 and 400 with stock bores and not hot tanked production blocks and they all weighed between 213 Lbs. and 225 Lbs. shruggy The three new unmachined cast iron World blocks weigh right at 320 Lbs. regardless of the bore size work
Re: Article on Muscle Motors new block [Re: Hemi_Joel] #2221483
12/27/16 02:12 AM
12/27/16 02:12 AM
AndyF Offline OP
AndyF  Offline OP
My World block was 321 lbs out of the box. Probably ended up around 300 lbs after being bored to size.
Re: Article on Muscle Motors new block [Re: Hemi_Joel] #2221494
12/27/16 02:37 AM
12/27/16 02:37 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
So No where close to the 230 you thought. That's ok. That weight is much closer to a stock block weights.
Re: Article on Muscle Motors new block [Re: AndyF] #2221500
12/27/16 03:26 AM
12/27/16 03:26 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Once it's bored, it will be 260. With a little trimming of un-needed fat, 240 - 250. And the other one was 230. So that's a 100 pound swing in weight for iron blocks. 1/2 of the savings of aluminum. I'm not advocating for any block, iron or aluminum. Just getting the info out there so we can all make informed decisions. For my stuff, weight is important. I don't think I'd use a 300+ pound block unless I was throwing a bunch of boost at it.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Article on Muscle Motors new block [Re: Hemi_Joel] #2221519
12/27/16 04:37 AM
12/27/16 04:37 AM
dogdays Offline
dogdays  Offline
Well you must have weighed a really early block. The World Products blocks weighed north of 320 lb. A bigblock chevy World block weighs 320lb. Those buggers are heavy, and much of the extra weight is right where it does the most good.
Re: Article on Muscle Motors new block [Re: AndyF] #2221551
12/27/16 11:32 AM
12/27/16 11:32 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
I don't care if it weighs 500lbs...availability and cost are what I'm concerned about.
The purse money is the same regardless of how fast you go.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Article on Muscle Motors new block [Re: A39Coronet] #2221571
12/27/16 12:47 PM
12/27/16 12:47 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
iagree availability!
Re: Article on Muscle Motors new block [Re: AndyF] #2221761
12/27/16 06:35 PM
12/27/16 06:35 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
This topic reminds me of when the Koleno block came out
Re: Article on Muscle Motors new block [Re: AndyF] #2236659
01/18/17 01:27 PM
01/18/17 01:27 PM
Texas
mprhound Offline
mprhound  Offline
Texas
Any news on availability? Anybody got one yet?
Re: Article on Muscle Motors new block [Re: AndyF] #2236669
01/18/17 01:48 PM
01/18/17 01:48 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
I called Eric, he will send you a build sheet, you send him $1800. 6 weeks later he said you will have it after you pay the other 1/2.
Joe
Without Data, you’re just another guy with an opinion.
Re: Article on Muscle Motors new block [Re: AndyF] #2237030
01/18/17 11:49 PM
01/18/17 11:49 PM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
I ain't gonna be losing sleep if it weighs a bit more....I'll lose the weight elsewhere if required.
Availability and quality/design/strength would be #1 on the list for Mopar guys atm.
Re: Article on Muscle Motors new block [Re: sr4440] #2237554
01/19/17 10:54 PM
01/19/17 10:54 PM
Midland,Tx
wyldebill Offline
wyldebill  Offline
Midland,Tx
Joe
But has anyone received their's and started building yet?
Re: Article on Muscle Motors new block [Re: AndyF] #2237578
01/19/17 11:32 PM
01/19/17 11:32 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Is MM going to submit a block to NHRA so it will be legal replacements for the production blocks? I think the Stock and SS guys may need these as soon as their supply of blocks runs out.
Floyd Lippencott IV
Re: Article on Muscle Motors new block [Re: AndyF] #2237770
01/20/17 10:49 AM
01/20/17 10:49 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
Hopefully they get this done soon. I heard and had pictures of it well over a year ago and it was supposed to come out soon. Was purchasing a new block, couldn't get any reliable schedule for KB, Bill Mitchells blocks were just around the corner... wonder if they are now available? Went with an Indy and even that took almost a year to arrive here...
Plynouth VIP '67 TT IC EFI
Re: Article on Muscle Motors new block [Re: AndyF] #2238265
01/21/17 02:46 AM
01/21/17 02:46 AM
cleveland, ohio
AJsDUSTER Offline
AJsDUSTER  Offline
cleveland, ohio
I was in the same boat, No aftermarket Iron blocks available, so was going to go with a Bill Mitchell aluminum block($5400 no machining) 8-9 week delivery. Then a buddy sent me this article, I asked some friends advice, I ordered one 2 weeks ago. We shall see in another 6 weeks. luck luck beer
Re: Article on Muscle Motors new block [Re: AndyF] #2238494
01/21/17 04:17 PM
01/21/17 04:17 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
So what I am hearing is there are no blocks that have been delivered or built from Muscle Motors yet? I'm just trying to understand the situation, not start a bashing war.
