Is 1000 CFM too big for street/strip car? #2221268
12/26/16 07:38 PM
12/26/16 07:38 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
My buddy races a 900 hp big block chevy dirt track car. He has a Gary Williams built 4150 1000 cfm carb that he ran once and will no longer use. I can get a good deal on it - I have a Gary Williams built Dominator I got from him some time ago and it worked very well on my race car. I am shooting to run 10.60's to 10.70's with the car. Targeting about 650 hp.
Do you think a 4150 1000 cfm carb would be a decent choice for my street/strip car with the following specs? I am not worried about the track just how it would behave on the street:
- 69 GTX
- 3800/3900 lbs
- 9 1/2 inch frank lupo converter
- 4.56 gear with 30 inch tire and gearvendors OD
- New 512 inch Mike Ware block with fully ported Side Winder heads from Todd Marsh
- cam is not yet chosen
- Mopar M1 gasket matched intake
- Other????
Re: Is 1000 CFM too big for street/strip car? [Re: markz528] #2221275
12/26/16 07:52 PM
12/26/16 07:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'd run it.. but you will need to dial it in to
your engine and for cruise
wave
Re: Is 1000 CFM too big for street/strip car? [Re: markz528] #2221279
12/26/16 08:00 PM
12/26/16 08:00 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Heck yea.
I run a 950 on my little 318, drive it everywhere. Haven't touched a plug in two years.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Is 1000 CFM too big for street/strip car? [Re: B3422W5] #2221281
12/26/16 08:03 PM
12/26/16 08:03 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
We have run my 4150 1000cfm on just as many track mile road miles. Great street carb.
I also run a 1250 Domintator on the street with awesome street manners.
Set them up right, and they work just fine.
Re: Is 1000 CFM too big for street/strip car? [Re: markz528] #2221283
12/26/16 08:08 PM
12/26/16 08:08 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Looks like a BLP main body, I have one on my 434 and it works great.
Re: Is 1000 CFM too big for street/strip car? [Re: justinp61] #2221290
12/26/16 08:18 PM
12/26/16 08:18 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
My 1000 CFM 4150's work excellent on the street. I would not hesitate to run it.
Re: Is 1000 CFM too big for street/strip car? [Re: markz528] #2221292
12/26/16 08:22 PM
12/26/16 08:22 PM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
Running an AED 1000 street/strip on my '67 R/T
505
Solid flat tappet
Indy 2D
8" Dynamic
3.54 gear
Pump Gas 93
3,950 pounds
11.30's @ 118
Put about 700 miles on the street as well
Re: Is 1000 CFM too big for street/strip car? [Re: markz528] #2221328
12/26/16 09:28 PM
12/26/16 09:28 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I've ran Dominators on my 500" street cars for years. 1,000CFM on the street is no problem with these engines. As long as the carb is set up right. And Thumper can help with that.
Master, again and still
Re: Is 1000 CFM too big for street/strip car? [Re: SILVER67] #2221342
12/26/16 09:50 PM
12/26/16 09:50 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
505
Solid flat tappet
Indy 2D
8" Dynamic
3.54 gear
Pump Gas 93
3,950 pounds
11.30's @ 118
What size cam are you running?
Re: Is 1000 CFM too big for street/strip car? [Re: MR_P_BODY] #2221368
12/26/16 10:38 PM
12/26/16 10:38 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
wave
x2; the basic carb design is probably fine, but the tune is likely to be way off for a street application.
Re: Is 1000 CFM too big for street/strip car? [Re: markz528] #2221380
12/26/16 11:12 PM
12/26/16 11:12 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
I've played with a few different setups on my 511. I've ran both a six pack and a 1050an 4150 carb that's pieced together from a proform 850 street carb. Both setups ran 10.90's on my 4g 69 runner on dot's, through mufflers, and driving to the track. I have the 1050 on an old tm6 I ported. Really runs well, it did take a few tricks to clean up the street manners. It really drives around as good or better than the six pack.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Is 1000 CFM too big for street/strip car? [Re: markz528] #2221396
12/26/16 11:34 PM
12/26/16 11:34 PM
Nashville, Tennessee
Tempest Offline
Tempest  Offline
I ran a 3 circuit 1150 Dominator on the street and it ran better than 850 DP when dialed in with a large roller cam.
Re: Is 1000 CFM too big for street/strip car? [Re: markz528] #2221454
12/27/16 01:17 AM
12/27/16 01:17 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
CFM wise no problem but the tune will determine how close it is to your needs.............
Re: Is 1000 CFM too big for street/strip car? [Re: markz528] #2221464
12/27/16 01:26 AM
12/27/16 01:26 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I hope not! I just switched from an 830 downleg carb to a new Annular HP 1000 on my 451 street / strip combo. Haven't ran it yet.
Holley's carb-selector tool landed on it for my combo, and a lot of guys here who's opinions I respect have suggested bigger is generally better.
Re: Is 1000 CFM too big for street/strip car? [Re: StealthWedge67] #2221469
12/27/16 01:32 AM
12/27/16 01:32 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Those calculators dont work for making power
bigger has always been better for me for street
or strip... its all about the amount of air
wave
Re: Is 1000 CFM too big for street/strip car? [Re: BSB67] #2221486
12/27/16 02:14 AM
12/27/16 02:14 AM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
Comp XX Lobe
Hughes 1.5 Rocker
.585/.600
260@50 / 268@50
109 cl
104-105 installed
Re: Is 1000 CFM too big for street/strip car? [Re: SILVER67] #2221511
12/27/16 04:03 AM
12/27/16 04:03 AM
The bigger CFM carbs. only count at WOT, the rest of the time your right foot controls the CFM the motor see's, correct work grin
Re: Is 1000 CFM too big for street/strip car? [Re: markz528] #2221552
12/27/16 11:32 AM
12/27/16 11:32 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
You are aware that is a 1,000 cfm 4150 "3 circuit" correct?
That will take a little extra tuning...
Re: Is 1000 CFM too big for street/strip car? [Re: Cab_Burge] #2221553
12/27/16 11:38 AM
12/27/16 11:38 AM
BradH Offline
BradH  Offline
Saying it's all about the amount of air is over simplifying things. DEPENDING ON THE COMBINATION, a smaller carb can ET & MPH better than a larger carb when it has better shift recovery.
Re: Is 1000 CFM too big for street/strip car? [Re: roadhazard] #2221556
12/27/16 11:49 AM
12/27/16 11:49 AM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
I bolted a BLP 3 circuit 1000 to my pump gas 505.....it was borrowed from a local dyno guy I know. So, I didn't want to monkey with it too much.
However, it fouled out my plugs in less than 1/2 of idling and one short drive.
I'm sure the 3 circuit can work on the street......but like Greg said.....plan on tuning time and prob a set of plugs
Mike
