How much st wheel travel with a Firm Feel box?
#2221252
12/26/16 07:04 PM
12/26/16 07:04 PM
Posts: 12,028 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I have about 800 miles on my Firm Feel Stg 3 box. There is 2 full inches of steering wheel travel before the pitman arm moves. That is with the stock steering wheel. I have looked at this very closely to find the excess movement. The coupler is tight with no measurable play.
I can look down between a header tube and the steering box and directly watch the input shaft of the box move a lot before the pitman arm begins to move. So I am sure that the loss of motion is in the box itself.
I have a call in to Firm Feel to get their take on this, but I thought that I would get your opinions on it too. I haven't adjusted anything yet. The box is just as it came from FF earlier this year.
Master, again and still
Re: How much st wheel travel with a Firm Feel box?
[Re: DaveRS23]
#2221265
12/26/16 07:34 PM
12/26/16 07:34 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Sounds like a power box. Did you test it with the engine running? Without pressure in the box it's sloppier than it is in use.
[Re: Supercuda]
#2221341
12/26/16 09:49 PM
12/26/16 09:49 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Yep, power box with the engine running. Had to leave a message at FF. Guess it will be next week now.
[Re: DaveRS23]
#2221478
12/27/16 01:50 AM
12/27/16 01:50 AM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
Did you turn the adjuster in on the box to tighten it up?
A new iron curtain drawn across the 49th parallel
[Re: 67autocross]
#2221565
12/27/16 12:28 PM
12/27/16 12:28 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Like I said in the original post, I haven't adjusted anything until I talk to Firm Feel. It would be nice if that were all it would take to remove the slop. But then again, that would mean that it left Firm Feel mis-adjusted.
[Re: DaveRS23]
#2221613
12/27/16 02:34 PM
12/27/16 02:34 PM
67autocross
Manitoba Canada
By all means talk to them first, saying that I have bought 2 of their boxes and ended up adjusting both of them after a few hundred miles.
[Re: Kern Dog]
#2222132
12/28/16 12:41 PM
12/28/16 12:41 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
2 1/4" Hemi headers are certainly in the way.....of everything.
Dick from FF returned my call yesterday and we decided to make a quick video and send it to him. Modern technology. He wanted to be sure I am not mistaking coupler slop with box slop. I' not.
First we'll try adjusting the box under his direction. I'll probably have to make a tool for that due to the headers. And if that doesn't do it..........
