Trunk spare tire well
#2219285
12/22/16 10:34 PM
12/22/16 10:34 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
How much does that spare tire well weigh in a bodies? I found a fuel cell i just have to have and would need to cut that out
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: Trunk spare tire well
[Re: sixpackgut]
#2219323
12/22/16 11:24 PM
12/22/16 11:24 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Not much, replace it with a flat aluminum sheet.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: sixpackgut]
#2219395
12/23/16 01:09 AM
12/23/16 01:09 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
Not much, I chopped it out of mine to install a trailer hitch I never used.
68 Barracuda Formula S 340
[Re: sixpackgut]
#2219444
12/23/16 03:48 AM
12/23/16 03:48 AM
Posts: 99 Nampa, Idaho
Moparmatts72
Nampa, Idaho
Yep easy to cut out and replace, I did a metal plate and added some framing to help support the 20 gal cell in my trunk of my 67 dart.
[Re: sixpackgut]
#2219577
12/23/16 01:34 PM
12/23/16 01:34 PM
1967dartgt
Hilltown Pa
Can you post a pic of your push pull switch Mopar matt? Getting ready to do it in my car.
[Re: sixpackgut]
#2219592
12/23/16 01:50 PM
12/23/16 01:50 PM
Thumperdart
State of confusion
It's a chunk of wt. and I removed mine many years ago and went a sheet of alum. and a 12 gal alum cell............
[Re: sixpackgut]
#2219783
12/23/16 07:16 PM
12/23/16 07:16 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Cut ours out and used a sheet of aluminum. I welded two pieces of 1.5" tubing between the frame rails and used a 68 Ford Falcon/Mustang tank,and it worked perfect.
[Re: 1967dartgt]
#2220265
12/24/16 04:47 PM
12/24/16 04:47 PM
Moparmatts72
Nampa, Idaho
Can you post a pic of your push pull switch Mopar matt? Getting ready to do it in my car. Sure here you go. Course doing this is did one thing I've never done before, I locked the keys in the trunk after the pictures lol had to remove the firewall between the trunk and passenger compartment lol its all good glad I got them out. Here's also the frame is added to help support.
[Re: Moparmatts72]
#2220533
12/25/16 02:14 AM
12/25/16 02:14 AM
1967dartgt
Hilltown Pa
Can you post a pic of your push pull switch Mopar matt? Getting ready to do it in my car. Sure here you go. Course doing this is did one thing I've never done before, I locked the keys in the trunk after the pictures lol had to remove the firewall between the trunk and passenger compartment lol its all good glad I got them out. Here's also the frame is added to help support. Thx
[Re: sixpackgut]
#2220591
12/25/16 11:35 AM
12/25/16 11:35 AM
Posts: 1,229 In The Hills
jughed
In The Hills
OP, the spare tire well does not weigh a whole lot more than alum., unless it's caked with undercoating. Can you post a pic of your push pull switch Mopar matt? Getting ready to do it in my car. The handle for this push/pull switch exits through the glass bumper.
[Re: jughed]
#2220954
12/26/16 02:54 AM
12/26/16 02:54 AM
1967dartgt
Hilltown Pa
OP, the spare tire well does not weigh a whole lot more than alum., unless it's caked with undercoating. Can you post a pic of your push pull switch Mopar matt? Getting ready to do it in my car. The handle for this push/pull switch exits through the glass bumper. That's interesting as I am just switching a electronic switch, my battery is in front of car. Could stay below the trunk. Hate to drill through my glass bumpers as they were just painted.
[Re: 1967dartgt]
#2220978
12/26/16 03:59 AM
12/26/16 03:59 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
OP, the spare tire well does not weigh a whole lot more than alum., unless it's caked with undercoating. Can you post a pic of your push pull switch Mopar matt? Getting ready to do it in my car. The handle for this push/pull switch exits through the glass bumper. That's interesting as I am just switching a electronic switch, my battery is in front of car. Could stay below the trunk. Hate to drill through my glass bumpers as they were just painted. Sorry to hiJack, but those look great! Can you outline the process ?? Are they really just painted?
[Re: Dave Hall]
#2220980
12/26/16 04:02 AM
12/26/16 04:02 AM
StealthWedge67
Puyallup, WA
Those are glass bumpers? If so I seriously need the info on the paint! Drilled ya at the tree, Dave. 😉
[Re: 1967dartgt]
#2221070
12/26/16 02:01 PM
12/26/16 02:01 PM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
OP, the spare tire well does not weigh a whole lot more than alum., unless it's caked with undercoating. Can you post a pic of your push pull switch Mopar matt? Getting ready to do it in my car. The handle for this push/pull switch exits through the glass bumper. That's interesting as I am just switching a electronic switch, my battery is in front of car. Could stay below the trunk. Hate to drill through my glass bumpers as they were just painted. They look great. The guy who did mine said not to nick paint around bolt holes or it may cause yellowing to start. Insane paint in WI did mine, a little pricey but I like it! Looks like real chrome. Don
[Re: Cab_Burge]
#2221170
12/26/16 04:22 PM
12/26/16 04:22 PM
1967dartgt
Hilltown Pa
I don't think you need a master cut off switch mounted at the rear of a race car on any car that has the battery in the stock location I feel it is in my best interest to have one on my car with a electric fuel pump. In case I crash and have a fire would be best for me and Saftey crews if a 500 gph pump isn't running.
[Re: sixpackgut]
#2221171
12/26/16 04:24 PM
12/26/16 04:24 PM
1967dartgt
Hilltown Pa
They are painted in a multiple step process. I had many issues with the shop who painted and will not refer him or his shop to anyone.
