Trunk spare tire well #2219285
12/22/16 10:34 PM
12/22/16 10:34 PM
Charleston
sixpackgut Offline OP
Drag Week Mod Champion
Charleston
How much does that spare tire well weigh in a bodies? I found a fuel cell i just have to have and would need to cut that out
Re: Trunk spare tire well [Re: sixpackgut] #2219323
12/22/16 11:24 PM
12/22/16 11:24 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Not much, replace it with a flat aluminum sheet.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Trunk spare tire well [Re: sixpackgut] #2219395
12/23/16 01:09 AM
12/23/16 01:09 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Not much, I chopped it out of mine to install a trailer hitch I never used.
68 Barracuda Formula S 340
Re: Trunk spare tire well [Re: sixpackgut] #2219444
12/23/16 03:48 AM
12/23/16 03:48 AM
Nampa, Idaho
Moparmatts72 Offline
Nampa, Idaho
Yep easy to cut out and replace, I did a metal plate and added some framing to help support the 20 gal cell in my trunk of my 67 dart.
Re: Trunk spare tire well [Re: sixpackgut] #2219577
12/23/16 01:34 PM
12/23/16 01:34 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Can you post a pic of your push pull switch Mopar matt? Getting ready to do it in my car.
Re: Trunk spare tire well [Re: sixpackgut] #2219592
12/23/16 01:50 PM
12/23/16 01:50 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
It's a chunk of wt. and I removed mine many years ago and went a sheet of alum. and a 12 gal alum cell............ beer
Re: Trunk spare tire well [Re: sixpackgut] #2219783
12/23/16 07:16 PM
12/23/16 07:16 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Cut ours out and used a sheet of aluminum. I welded two pieces of 1.5" tubing between the frame rails and used a 68 Ford Falcon/Mustang tank,and it worked perfect.
Nautilus Racing-
Re: Trunk spare tire well [Re: Chris2581] #2219823
12/23/16 08:35 PM
12/23/16 08:35 PM
tboomer Offline
tboomer  Offline
Pretty good idea on the aluminum. What gauge are fellas using?
Re: Trunk spare tire well [Re: 1967dartgt] #2220265
12/24/16 04:47 PM
12/24/16 04:47 PM
Nampa, Idaho
Nampa, Idaho
Sure here you go. Course doing this is did one thing I've never done before, I locked the keys in the trunk after the pictures lol had to remove the firewall between the trunk and passenger compartment lol its all good glad I got them out. Here's also the frame is added to help support.
Re: Trunk spare tire well [Re: Moparmatts72] #2220533
12/25/16 02:14 AM
12/25/16 02:14 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Thx
Re: Trunk spare tire well [Re: sixpackgut] #2220591
12/25/16 11:35 AM
12/25/16 11:35 AM
In The Hills
jughed Offline
jughed  Offline
In The Hills
OP, the spare tire well does not weigh a whole lot more than alum., unless it's caked with undercoating.
The handle for this push/pull switch exits through the glass bumper.
Re: Trunk spare tire well [Re: jughed] #2220954
12/26/16 02:54 AM
12/26/16 02:54 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
That's interesting as I am just switching a electronic switch, my battery is in front of car. Could stay below the trunk. Hate to drill through my glass bumpers as they were just painted.
Re: Trunk spare tire well [Re: 1967dartgt] #2220978
12/26/16 03:59 AM
12/26/16 03:59 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Sorry to hiJack, but those look great! Can you outline the process ?? Are they really just painted?
Re: Trunk spare tire well [Re: sixpackgut] #2220979
12/26/16 04:01 AM
12/26/16 04:01 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Those are glass bumpers? If so I seriously need the info on the paint!
Re: Trunk spare tire well [Re: Dave Hall] #2220980
12/26/16 04:02 AM
12/26/16 04:02 AM
Puyallup, WA
Puyallup, WA
Drilled ya at the tree, Dave. 😉
Re: Trunk spare tire well [Re: sixpackgut] #2220983
12/26/16 04:04 AM
12/26/16 04:04 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Tore my eyeballs out! bump
Re: Trunk spare tire well [Re: 1967dartgt] #2221070
12/26/16 02:01 PM
12/26/16 02:01 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
They look great. The guy who did mine said not to nick paint around bolt holes or it may cause yellowing to start.
Insane paint in WI did mine, a little pricey but I like it!
Looks like real chrome.
Don
Re: Trunk spare tire well [Re: 1967dartgt] #2221164
12/26/16 04:11 PM
12/26/16 04:11 PM
Cab_Burge Online work
Cab_Burge  Online Work
I don't think you need a master cut off switch mounted at the rear of a race car on any car that has the battery in the stock location scope
Re: Trunk spare tire well [Re: Cab_Burge] #2221170
12/26/16 04:22 PM
12/26/16 04:22 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I feel it is in my best interest to have one on my car with a electric fuel pump. In case I crash and have a fire would be best for me and Saftey crews if a 500 gph pump isn't running.
Re: Trunk spare tire well [Re: sixpackgut] #2221171
12/26/16 04:24 PM
12/26/16 04:24 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
They are painted in a multiple step process. I had many issues with the shop who painted and will not refer him or his shop to anyone.
