A500? Does anyone use one? #221835
02/12/09 12:42 AM
02/12/09 12:42 AM
S.E. Michigan
cl440 Offline OP
cl440  Offline OP
S.E. Michigan
I don,t know much about them. Anyone running one? Street or Race? I see they share some parts with a 904. Are they a basically an electronic 904 w/OD?
Re: A500? Does anyone use one? [Re: cl440] #221836
02/12/09 01:08 AM
02/12/09 01:08 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
there is a 42rh and 42re model
42rh was used to about 1995 the shifting is controlled hydraulically...
42re use after 1995 and the shifting is controlled electronically.
just rebuild a 42rh a few weeks ago..basically a 904 with an overdrive.
Tony
70 AARCuda Vitamin C
Re: A500? Does anyone use one? [Re: 70AARcuda] #221837
02/12/09 03:15 AM
02/12/09 03:15 AM
Eagleville Tn.
rtstreet Offline
rtstreet  Offline
Eagleville Tn.
yes most in jeeps have a low gear set, the early had a governor, and the newer have gov pressure noid and senssor
Re: A500? Does anyone use one? [Re: rtstreet] #221838
02/12/09 11:00 AM
02/12/09 11:00 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
all a500's have the 2.74/1.54 1-2 gearset and a 5 disc front clutch.
2017 Grand Cherokee Overland
Re: A500? Does anyone use one? [Re: patrick] #221839
02/12/09 11:45 AM
02/12/09 11:45 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I have one I run in a pro street D100....Its got the low 1st gear and OD...I had iit built with all the parts from SMR, and have not had any issues with it, but one. I would not go back to a 904...This thing is great.
Re: A500? Does anyone use one? [Re: patrick] #221840
02/13/09 01:37 AM
02/13/09 01:37 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
just did one in a 95 dakota with aV6 3.9L V6.
it was the original trans...only 4 disc in front clutch pac...I thought it would have had 5 also.
Tony
Re: A500? Does anyone use one? [Re: 70AARcuda] #221841
02/13/09 09:16 AM
02/13/09 09:16 AM
S.E. Michigan
cl440 Offline OP
cl440  Offline OP
S.E. Michigan
The main reason I ask is that I came across a few brand new deep pans(4.5" deep) I grabbed them up cause they will work for a 904 with the right extension. Then I got to thinking about the A500 and if it was being put to use in any performance applications.
I assume the A500 has a small block bell bolt pattern?
