Master cylinder #2217621
12/20/16 11:18 AM
12/20/16 11:18 AM
Hilltown Pa
1967dartgt Offline OP
Hilltown Pa
Looking at new strange master cylinders. Have aerospace race brakes at all four corners. What diameter would be best? 1.032 or 1.125 for my set up. Believe it would be better with the 1.125.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Master cylinder [Re: 1967dartgt] #2217674
12/20/16 12:27 PM
12/20/16 12:27 PM
oregon
greendart408 Offline
oregon
I have aerospace on the front, and strange race on the rear, strange told me 1 1/8 bore. I went with that and have perfect pedal and brakes. Stock 69, 340 swinger everything else. Only been 144+ with our 59 degree n/a deal, but stops it effortless and weighs 3,090.
Re: Master cylinder [Re: 1967dartgt] #2217762
12/20/16 02:34 PM
12/20/16 02:34 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
Call Diff Doc Cass. He sells mopar kits cheaper and sells strange.
Re: Master cylinder [Re: 1967dartgt] #2217783
12/20/16 02:53 PM
12/20/16 02:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
How is the feel now and how much pedal travel
do you have now(assuming you have been running
all the brakes on the currant master)... most
guys go too big on the master and that gives you
a HARD pedal with very little travel... on my
Rampage I am thinking about putting a samller
master on.. its ALMOST perfect but I think I can
get it better.. if I really stand on it(brakes)
the pedal is just a touch too hard vs the travel
wave
Re: Master cylinder [Re: MR_P_BODY] #2217813
12/20/16 03:37 PM
12/20/16 03:37 PM
Colorado
Bob J Offline
Bob J  Offline
Colorado
Wilwood told me to go 7/8 master for manual brakes and 1 1/16 for power. My brake pedal has a 7 to 1 ratio if it was 6 to 1 I could use 1 1/16. But the 7 to 1 with 7/8 master would be better. This is with 4 wheel 4 piston disc.
This should be 15/16 not 7/8
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS
68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam
65 Chrysler 300 Convert. project
57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son
2003 Dodge Dakota R/T "DEAD"
Re: Master cylinder [Re: 1967dartgt] #2217820
12/20/16 03:47 PM
12/20/16 03:47 PM
Hilltown Pa
Hilltown Pa
Haven't run the car with rear disc, new set up. I have a pep boys master off a 93 truck and think I have to much pedal travel with my drums and aerospace front disc.
Re: Master cylinder [Re: 1967dartgt] #2217847
12/20/16 04:24 PM
12/20/16 04:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Question for ya... do you foot brake.. if so the drums HOLD
better than disc when sitting still.. disc are better at
stopping the car but dont hold as well.. just something to
think about.. when I built my Rampage I put big drums on
it just for better holding being that I wasnt allowed to
run a trans brake(when I was building this thing for DW
the rules stated no trans brake in the class I was building
for)
EDIT
what size bore is that 93 truck master
wave
Re: Master cylinder [Re: 1967dartgt] #2217853
12/20/16 04:37 PM
12/20/16 04:37 PM
Hilltown Pa
Hilltown Pa
No I have transbrake, and don't know what size it is. Just measured it and it's .975.
Re: Master cylinder [Re: 1967dartgt] #2217857
12/20/16 04:40 PM
12/20/16 04:40 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
1967dartgt, I can't believe your asking a question on here. I thought you knew everything
Re: Master cylinder [Re: sixpackgut] #2217991
12/20/16 09:24 PM
12/20/16 09:24 PM
oregon
oregon
Having just switched from rear 10in rear drums to the rear disk, ran it only one time and being a foot brake guy, seems exactly the same holding wise. The thing I do notice is not trying to plow the farmers field at the end of the track every pass. Effortless now, only thing I changed is installed the rear strange disks and strange master. Only thing I would do diff, is put them on 10 yrs ago.
Re: Master cylinder [Re: sixpackgut] #2218003
12/20/16 09:42 PM
12/20/16 09:42 PM
Cab_Burge Online work
Cab_Burge  Online Work
work Are you working on becoming one of the "cooks' on here now whistling devil stirthepot whistling
