Speedo cable questions 64 Savoy
#2216697
12/18/16 11:45 PM
12/18/16 11:45 PM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
Will a speedo cable from a later B body 66-68 fit a 64 speedo head unit. Since I'm converting my car to more street than strip I was thinking of a working speedometer. My factory speedo cable used a one piece adapter that is part of the cable. Any one else use a later B cable in an early B body Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: Speedo cable questions 64 Savoy
[Re: fourgearsavoy]
#2216828
12/19/16 04:25 AM
12/19/16 04:25 AM
Posts: 8,326 fredericksburg,va
cudaman1969
fredericksburg,va
Are you going to a later trans? If so there is a cable made for a Camero that works perfectly, I'll have to look throught my notebooks for the listing and will get back to you. Also a 66 cable works too.
[Re: fourgearsavoy]
#2216873
12/19/16 11:06 AM
12/19/16 11:06 AM
Posts: 21,081 Niles , Ohio
therocks
Niles , Ohio
Gus when my son put the new TF in his 62 300.He got a cable from Imperial Services.Steve used the new end for trans and the small end for the speddo.Early trans didnt have the thread type speedo at trans.Rocky
Chrysler Firepower
[Re: fourgearsavoy]
#2216987
12/19/16 02:27 PM
12/19/16 02:27 PM
RapidRobert
Any one else use a later B cable in an early B body Just A bodies here but the problem I ran into with a 64 A speedo and a later trans was that there was a one year only cable that matched both ends (66 or 67?). not sure if that helps or not. I might still have it if needed
[Re: cudaman1969]
#2217072
12/19/16 04:47 PM
12/19/16 04:47 PM
cudaman1969
fredericksburg,va
Are you going to a later trans? If so there is a cable made for a Camero that works perfectly, I'll have to look throught my notebooks for the listing and will get back to you. Also a 66 cable works too. HeartbearCamero.com Google Heartbeat City $38 ,different lengths too
[Re: topside]
#2217398
12/20/16 12:46 AM
12/20/16 12:46 AM
fourgearsavoy
Rittman Ohio
Thanks a lot guys this gives me all the info I need to get my speedo working. I have been using late model transmissions since I pulled the slant and three speed out. I never used a speedo with the Richmond 5-speed because it used a GM style adapter. Now I have a street Hemi box in the car and it would be nice to know how fast I'm going Thanks again guys Gus
[Re: therocks]
#2217630
12/20/16 11:34 AM
12/20/16 11:34 AM
Posts: 1,796 Greer, SC
TooMany62s
Greer, SC
Gus when my son put the new TF in his 62 300.He got a cable from Imperial Services.Steve used the new end for trans and the small end for the speddo.Early trans didnt have the thread type speedo at trans.Rocky You may want to do a search on Imperial Services before ordering anything there. Plus, I think any number of the suggestions here using off-the-shelf parts store stuff could work. It depends on what transmission you have.
[Re: TooMany62s]
#2217670
12/20/16 12:17 PM
12/20/16 12:17 PM
Posts: 598 Glendale, CA
whuston383
Glendale, CA
Check Control Cables, Inc. in Santa Fe Springs, CA. http://www.controlcables.com/Chances are very high that whoever is selling cables is getting them made at this place and $$$ marking them up. Send them either dimensions, two cable housings each with the correct end fittings you want to use, overall length measurement, etc. They are VERY helpful over the phone or internet and they catalog your application if you or a buddy ever needed another one. I've had them make stock looking throttle cables and E-brake cables for early B-body using Wilwood disc rear. I've been extremely satisfied with their work. Short turn around times but always good to have your 'end in view' and work the long-lead time parts of your project first. And, Redline Gage Works in Santa Clarita, CA are simply awesome at what they do. And, no. I don't work for Control Cables, Inc.
Wow. You say you have a Sports Fury? Talk about rare.
[Re: fourgearsavoy]
#2218096
12/20/16 11:42 PM
12/20/16 11:42 PM
therocks
Niles , Ohio
Cab try finding the correct gear for say my 65 with 3.91s.let alone when it had 4.88s.Rocky
Chrysler Firepower
[Re: fourgearsavoy]
#2218412
12/21/16 03:29 PM
12/21/16 03:29 PM
therocks
Niles , Ohio
Yeah I know Imperial had them.If I can ever get ahold of Steve Ill ask about one.Im going 4.30s when the Dana goes in.Rocky
Chrysler Firepower
[Re: fourgearsavoy]
#2218579
12/21/16 08:55 PM
12/21/16 08:55 PM
fourgearsavoy
Rittman Ohio
Now all I have to do is find someone to loan me a cable to try and if it fits I will know what cable would work for my combo Good thing I live close to so many Moparts guys with large parts stashes Thanks all who replied Gus
[Re: fourgearsavoy]
#2218831
12/22/16 06:50 AM
12/22/16 06:50 AM
cudaman1969
fredericksburg,va
Now all I have to do is find someone to loan me a cable to try and if it fits I will know what cable would work for my combo Good thing I live close to so many Moparts guys with large parts stashes Thanks all who replied Gus Like I said the GM cable fits both ends, screw on end for cluster and screw on end for trans, in any length you need, for $38. There are more than enough speedo gears for the 66 and up trans to choose from to get the speedometer right.
[Re: fourgearsavoy]
#2218983
12/22/16 02:23 PM
12/22/16 02:23 PM
therocks
Niles , Ohio
John I run a 3.23 gear now as thats what came in my 65.The speedo is appx 20% fast so i know how fast im going.Now when I had the 88s in it I could hit over 100 realfast speedo.If I ever get the later 4 speed done ill be able to use a lter gear.Rocky
Chrysler Firepower
