Re: Build me a 9 inch rear
[Re: MattW]
#2215622
12/17/16 01:45 PM
12/17/16 01:45 PM
Posts: 52,972 Romeo MI
MR_P_BODY
A back brace and a good front support for sure.. spool.. thats all I have in my 9".. I dont have the spool but mine is just a street car EDIT There are a few different 9" carriers..nodular is a decent one.. thats production on some of them (Bronco I believe).. it has a extra web on it
[Re: MattW]
#2215635
12/17/16 02:11 PM
12/17/16 02:11 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
When I had a 9 inch under the Savoy it had the double rib "WAR" carrier and it's still in use under a 67 Camaro running low 9' s. I used the Daytona pinion support and 33 spline Moser axles and spool. Make sure you get the solid spacer to replace the crush sleeve. I've been seriously considering pulling the Dana and going back to the 9 inch just because of the easy service and wide range of gear options. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: 340Cuda]
#2215644
12/17/16 02:25 PM
12/17/16 02:25 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
They reason the Dana is more popular than the Ford 9 inch is because this is a MOPAR site. LOL. I've had all three (8 3/4, Dana and Ford 9 inch) and currently have 2 Dana's and one 9 inch and I wish all three were 9 inches and may be someday. Build a nice 9 inch and don't look back. If I was starting from new I would probably at least order a fab housing and go from there but price it out for a complete unit and you may save money.
[Re: MattW]
#2215700
12/17/16 03:30 PM
12/17/16 03:30 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Oh my a nine inch in your mopar!! That's worse then a powerglide!
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: MattW]
#2215715
12/17/16 03:50 PM
12/17/16 03:50 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Hefner 9" housing has internal bracing and is very precisely machined on mount surface and tubing mounts. Strange sells a version of this housing as their own. Buying new, there is no way I'd go with anything but a strange ultracase. Wicked strong pinion support, forced pinion oiling, large pinion shaft option, speed sensor mount, capable of 9 1/2" gears if needed, etc... Not much cost difference, and you will never have to think about the rear ever again.
[Re: savoy64]
#2215717
12/17/16 03:52 PM
12/17/16 03:52 PM
MR_P_BODY
SAE engineers (not owned by mopar) rated the 8.75 over the 9 inch----and the dana 60 over both as stock units......if you want to spend lots of money and be able to say 9 inch all the time then build a 9 inch---the aftermarket chased the 9 and made it what it is today---the same way the aftermarket chased the SBC and made it what it is today....maybe we should all be putting chevys in our muscle cars--it only makes sense... Thats true in the STOCK form.. not many of us run anything in the stock form.. a few bucks(not many at all) and you have a nice 9".. the support is the biggest thing and thats not much at all.. then the spool which most guys would do anyways and the back brace which is another cheap item.. once we learn what gear we like MOST of us never change gears again unless you build a different combo.. now days there are way more gear choices for a 9" than any other
[Re: 340Cuda]
#2215737
12/17/16 04:32 PM
12/17/16 04:32 PM
Posts: 814 in front of the computer
80arrow
I know this is not what you asked, but unless money is no object or you want to change ratios a lot you really should consider a Dana 60.
A 9 inch can be built to be as strong as a Dana but at more expense. While heavier the Dana will probably be at least as fast, maybe faster because it takes less horsepower to drive it.
I am no expert but I have researched this earlier. My personal experience as many others on this board has been to switch from an 8 3/4 to a Dana and not slow down a bit. The added efficiency of the Dana makes up for the additional weight. An 8 3/4 is more efficient than a 9 inch. That being said I think there are some really high dollar 9 inch center sections with special gears that relocate the pinion and make the 9 inch very efficient.
Again, my answer to a question you did not ask.
Good Luck with your project!
Bill With a nine inch rear the ratio of Pro gears is almost unlimited. That's why I switched my Dana 60 to a Strange 9" in my Dart. Only runs mid 8's@3550 lbs so far, but I'm hoping to pick it up some this next year.
[Re: 1967dartgt]
#2215738
12/17/16 04:32 PM
12/17/16 04:32 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Oh my a nine inch in your mopar!! That's worse then a powerglide! Where did you get yours? I'm looking for a complete unit. There'sa company call 9+ ? Any good?
[Re: pittsburghracer]
#2215740
12/17/16 04:35 PM
12/17/16 04:35 PM
MattW
Ontario Canada
They reason the Dana is more popular than the Ford 9 inch is because this is a MOPAR site. LOL. I've had all three (8 3/4, Dana and Ford 9 inch) and currently have 2 Dana's and one 9 inch and I wish all three were 9 inches and may be someday. Build a nice 9 inch and don't look back. If I was starting from new I would probably at least order a fab housing and go from there but price it out for a complete unit and you may save money. Heard it all and for me I'm using the 9 for parts availability and ease . Going to sell all my 83/4 parts to pay for it.
[Re: MattW]
#2215752
12/17/16 04:56 PM
12/17/16 04:56 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
They reason the Dana is more popular than the Ford 9 inch is because this is a MOPAR site. LOL. I've had all three (8 3/4, Dana and Ford 9 inch) and currently have 2 Dana's and one 9 inch and I wish all three were 9 inches and may be someday. Build a nice 9 inch and don't look back. If I was starting from new I would probably at least order a fab housing and go from there but price it out for a complete unit and you may save money. Heard it all and for me I'm using the 9 for parts availability and ease . Going to sell all my 83/4 parts to pay for it. Dog-gone it. I have a couple of Duster length Dana's I may be selling. LOL
#2215797
12/17/16 05:54 PM
12/17/16 05:54 PM
MattW
Ontario Canada
They reason the Dana is more popular than the Ford 9 inch is because this is a MOPAR site. LOL. I've had all three (8 3/4, Dana and Ford 9 inch) and currently have 2 Dana's and one 9 inch and I wish all three were 9 inches and may be someday. Build a nice 9 inch and don't look back. If I was starting from new I would probably at least order a fab housing and go from there but price it out for a complete unit and you may save money. Heard it all and for me I'm using the 9 for parts availability and ease . Going to sell all my 83/4 parts to pay for it. Dog-gone it. I have a couple of Duster length Dana's I may be selling. LOL Really. I have TD 1.65 rockers for sale bran new for indy 360-2 and -1 new in box went W9 route.
[Re: MattW]
#2215834
12/17/16 06:58 PM
12/17/16 06:58 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Matt another consideration on whose 9" parts to buy is who is paying contingency money on the racing you want to do. It is nice to cash a check once in a while. Just something else to consider.
"Just a Bracket car dressed up like a streetcar"
[Re: MattW]
#2215957
12/18/16 12:24 AM
12/18/16 12:24 AM
Posts: 1,563 Janesville, WI
SpareParts
Janesville, WI
So let's say 3200 lbs A body mono springs with T brake. Looking at low 8s. What should I be looking for? Matt I'm curious what your combo is if you will share. That's a big goal. Not saying it can't happen or being negative at all, just curious how you're going about it
[Re: MattW]
#2215991
12/18/16 01:38 AM
12/18/16 01:38 AM
1967dartgt
Hilltown Pa
I have a chassis engeering fab housing. I used smith racecraft leaf spring mounts, and a strange ultra case.
