Page 1 of 8 1 2 3 4 5 6 7 8
Build me a 9 inch rear #2215592
12/17/16 01:12 PM
12/17/16 01:12 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
So let's say 3200 lbs A body mono springs with T brake.
Looking at low 8s.
What should I be looking for?
Matt
Re: Build me a 9 inch rear [Re: MattW] #2215608
12/17/16 01:33 PM
12/17/16 01:33 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
I run 9.08 with 2800# A body.
I use a Fab 9 MS housing, Strange aluminum center section, with upgraded front bearing support. I have one with 4.10 gears and one with 4.30 gears.
NO issues!
Don
Re: Build me a 9 inch rear [Re: MattW] #2215622
12/17/16 01:45 PM
12/17/16 01:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
A back brace and a good front support for sure..
spool.. thats all I have in my 9".. I dont have
the spool but mine is just a street car
EDIT
There are a few different 9" carriers..nodular
is a decent one.. thats production on some of them
(Bronco I believe).. it has a extra web on it
wave
Re: Build me a 9 inch rear [Re: MattW] #2215635
12/17/16 02:11 PM
12/17/16 02:11 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
When I had a 9 inch under the Savoy it had the double rib "WAR" carrier and it's still in use under a 67 Camaro running low 9' s.
I used the Daytona pinion support and 33 spline Moser axles and spool. Make sure you get the solid spacer to replace the crush sleeve. I've been seriously considering pulling the Dana and going back to the 9 inch just because of the easy service and wide range of gear options.
Gus
64 Plymouth Savoy
Dana 60
Re: Build me a 9 inch rear [Re: MattW] #2215637
12/17/16 02:14 PM
12/17/16 02:14 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I know this is not what you asked, but unless money is no object or you want to change ratios a lot you really should consider a Dana 60.
A 9 inch can be built to be as strong as a Dana but at more expense. While heavier the Dana will probably be at least as fast, maybe faster because it takes less horsepower to drive it.
I am no expert but I have researched this earlier. My personal experience as many others on this board has been to switch from an 8 3/4 to a Dana and not slow down a bit. The added efficiency of the Dana makes up for the additional weight. An 8 3/4 is more efficient than a 9 inch. That being said I think there are some really high dollar 9 inch center sections with special gears that relocate the pinion and make the 9 inch very efficient.
Again, my answer to a question you did not ask.
Good Luck with your project!
Bill
Re: Build me a 9 inch rear [Re: 340Cuda] #2215644
12/17/16 02:25 PM
12/17/16 02:25 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
They reason the Dana is more popular than the Ford 9 inch is because this is a MOPAR site. LOL. I've had all three (8 3/4, Dana and Ford 9 inch) and currently have 2 Dana's and one 9 inch and I wish all three were 9 inches and may be someday. Build a nice 9 inch and don't look back. If I was starting from new I would probably at least order a fab housing and go from there but price it out for a complete unit and you may save money.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Build me a 9 inch rear [Re: MattW] #2215700
12/17/16 03:30 PM
12/17/16 03:30 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Oh my a nine inch in your mopar!! That's worse then a powerglide!
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Build me a 9 inch rear [Re: MattW] #2215701
12/17/16 03:30 PM
12/17/16 03:30 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
SAE engineers (not owned by mopar) rated the 8.75 over the 9 inch----and the dana 60 over both as stock units......if you want to spend lots of money and be able to say 9 inch all the time then build a 9 inch---the aftermarket chased the 9 and made it what it is today---the same way the aftermarket chased the SBC and made it what it is today....maybe we should all be putting chevys in our muscle cars--it only makes sense...
Re: Build me a 9 inch rear [Re: MattW] #2215715
12/17/16 03:50 PM
12/17/16 03:50 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Hefner 9" housing has internal bracing and is very precisely machined on mount surface and tubing mounts. Strange sells a version of this housing as their own.
Buying new, there is no way I'd go with anything but a strange ultracase. Wicked strong pinion support, forced pinion oiling, large pinion shaft option, speed sensor mount, capable of 9 1/2" gears if needed, etc... Not much cost difference, and you will never have to think about the rear ever again.
Re: Build me a 9 inch rear [Re: savoy64] #2215717
12/17/16 03:52 PM
12/17/16 03:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats true in the STOCK form.. not many of us run
anything in the stock form.. a few bucks(not many
at all) and you have a nice 9".. the support is
the biggest thing and thats not much at all.. then
the spool which most guys would do anyways and the
back brace which is another cheap item.. once we
learn what gear we like MOST of us never change gears
again unless you build a different combo.. now days
there are way more gear choices for a 9" than any other
wave
Re: Build me a 9 inch rear [Re: 340Cuda] #2215737
12/17/16 04:32 PM
12/17/16 04:32 PM
in front of the computer
8
80arrow Offline
80arrow  Offline
Bill
With a nine inch rear the ratio of Pro gears is almost unlimited. That's why I switched my Dana 60 to a Strange 9" in my Dart. Only runs mid 8's@3550 lbs so far, but I'm hoping to pick it up some this next year.
Re: Build me a 9 inch rear [Re: 1967dartgt] #2215738
12/17/16 04:32 PM
12/17/16 04:32 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Where did you get yours?
I'm looking for a complete unit.
There'sa company call 9+ ? Any good?
Re: Build me a 9 inch rear [Re: pittsburghracer] #2215740
12/17/16 04:35 PM
12/17/16 04:35 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Heard it all and for me I'm using the 9 for parts availability and ease .
Going to sell all my 83/4 parts to pay for it.
Re: Build me a 9 inch rear [Re: MattW] #2215752
12/17/16 04:56 PM
12/17/16 04:56 PM
PA.
"Little"John
"Little"John
PA.
Dog-gone it. I have a couple of Duster length Dana's I may be selling. LOL
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Build me a 9 inch rear [Re: pittsburghracer] #2215797
12/17/16 05:54 PM
12/17/16 05:54 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Really.
I have TD 1.65 rockers for sale bran new for indy 360-2 and -1 new in box went W9 route.
Re: Build me a 9 inch rear [Re: MattW] #2215810
12/17/16 06:17 PM
12/17/16 06:17 PM
MI
68shifter Offline
68shifter  Offline
MI
Strange or MW thru bolt aluminum case.
The strange ultra cases are nice, but so is anything MW, and you can
get either that will take 9-1/2 gear.
3.81 bore.
Taper/ball pinion support.
40 spline axles.
Spool can be either aluminum or steel, steel will last longer.
Tons of places sell fab housings, or Rhodes sells one you can weld up
yourself. Go 3.25 or 3.5" tube, and Ford or symmetric ends.
Good luck
Re: Build me a 9 inch rear [Re: MattW] #2215834
12/17/16 06:58 PM
12/17/16 06:58 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Matt another consideration on whose 9" parts to buy is who is paying contingency money on the racing you want to do. It is nice to cash a check once in a while. Just something else to consider.
"Just a Bracket car dressed up like a streetcar"
Re: Build me a 9 inch rear [Re: MattW] #2215907
12/17/16 10:12 PM
12/17/16 10:12 PM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
i have a strange pro housing with strange 33 spool and moser 33 axles i have the spool adapted for the big bearings and a sleeve on the pinion gear for the inside big bearing. it is a older unit from around 1996 and it will be the last center i buy. i can't imagine at the level i race at or could afford to go to i will ever brake it. and if i ever go race block and bigger bucks it is plenty.
the housing is a stock 75 merc monarch rear no mods. this went in my duster with out big bucks on someones custom rear.
i have a war housing i stopped using and was told by old timers that they are good but in the 9s they would not use them cause they seen the rear caps brake in the center where the bolt is installed to lock the adjusters.
Re: Build me a 9 inch rear [Re: MattW] #2215957
12/18/16 12:24 AM
12/18/16 12:24 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Looking at low 8s.
Matt
I'm curious what your combo is if you will share. That's a big goal. Not saying it can't happen or being negative at all, just curious how you're going about it
Re: Build me a 9 inch rear [Re: MattW] #2215991
12/18/16 01:38 AM
12/18/16 01:38 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I have a chassis engeering fab housing. I used smith racecraft leaf spring mounts, and a strange ultra case.
