Re: How fast have you gone with a standard port bb head? [Re: viperblue72] #2215330
12/16/16 10:07 PM
12/16/16 10:07 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Originally Posted By viperblue72
Thanks for the responses. I ask because I have a lowly 383 and I am putting portted sidewinder heads and a tr on it. But my future plan is to build a bigger short block eventually.
My current combo is 12.5 to 1 trw domes, mp590 cam. 2800lb valiant. I'm hoping at least 10.7s.
-12.5:1 383
-ported sidewinders
-tunnel ram
-590 cam
-2800lbs
Assuming it doesnt have a crappy converter and totally the wrong gear/tire combo, if that doesn't run at least 10.70's (at a track that's below 1500'-ish elevation), there's something seriously wrong with it.
Re: How fast have you gone with a standard port bb head? [Re: viperblue72] #2215333
12/16/16 10:12 PM
12/16/16 10:12 PM
junction city oregon
V
viperblue72 Offline OP
V
Fast68,
For now it has the wrong gear 4.56 and 31x13.5 slicks. I just bought the car in June and only ran it once and was disappointed with a 11.80@113.33. So I decided it was time to freshen up the bottom end and new rings, and new heads. I agree it should go quicker than 10.7 but I don't want to be too optimistic. I do plan on changing gears to a 4.88 or 5.13.
Re: How fast have you gone with a standard port bb head? [Re: viperblue72] #2215355
12/16/16 10:50 PM
12/16/16 10:50 PM
UK
rb446 Offline
rb446  Offline
UK
'69 Cuda stock 440-6pk bottom end, 9.8:1, 2.14/1.81 906's mild port, 3000lbs all in, CC.650/.650 290@.050 SFT cam, Team G dom w/adapter to 850DP, 727, stock front end w/90/10's, 4800 verter, Hoosier 14x32, 4.88's, l/bars c/overs
10.71@125 NA 1.46 60ft> 9.96@133.9 1.38 60ft with small Hit in 1990
11.23@118 with bone stock 906's.
I think it would've gone quicker with a cam where the intake closed somewhat earlier for a bit more effective stroke/CP....was at 0 sea, knowledge wasn't the best back then, like running 4psi in the slicks!
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: How fast have you gone with a standard port bb head? [Re: viperblue72] #2215449
12/17/16 01:49 AM
12/17/16 01:49 AM
V
V
290@050? 😳
Re: How fast have you gone with a standard port bb head? [Re: viperblue72] #2215474
12/17/16 02:47 AM
12/17/16 02:47 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
290@050? 😳
Way to big for you, as you already know.
Re: How fast have you gone with a standard port bb head? [Re: viperblue72] #2215494
12/17/16 04:01 AM
12/17/16 04:01 AM
V
V
lol I think my mp590 is too big with 271@050. For only 383 ci.
Re: How fast have you gone with a standard port bb head? [Re: Sport440] #2215611
12/17/16 01:35 PM
12/17/16 01:35 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
65 Belevadere all steel we have gone 10.94 on pump gas with 915 heads 2.14 / 1.81 valves....Its a pump gas 440 Source 526 stroker. Its got more in it, we are fighting traction since the car is not tubbed. Its fast, streetable and fun to drive.
Re: How fast have you gone with a standard port bb head? [Re: Dragula] #2215617
12/17/16 01:41 PM
12/17/16 01:41 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
With a 526 that has to have some fast port speed
Re: How fast have you gone with a standard port bb head? [Re: viperblue72] #2215912
12/17/16 10:32 PM
12/17/16 10:32 PM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
i have a duster 3120 with me in it with a 30 over 440 old indy econo i think heads (non offset rockers) with a old 262@50 solid predator cam 13.7 to 1 dominator and m1 intake ran a best of 9.89 in killer air at cecil md. ports are 270cc 330 cfm flow
Re: How fast have you gone with a standard port bb head? [Re: viperblue72] #2215934
12/17/16 11:15 PM
12/17/16 11:15 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
My old DartSport had a low deck 451(400 block with 440 crank), MP 590 purpleshaft, ported Eddy heads, 727 with 8" ATI converter, 4.56 gears and 14x32 tires and weighed 3050# with me in it.
Ran 10.0's with a best of 9.96 in good air with a single Dominator.
Ran 9.90's with a best of 9.89 with a M1 TR and two 750 Quickfuel carbs. Extremely fun car, with 11.2 to 1 compression I ran pump gas on the street and mixed in a gallon of 110 octane as an additive. I'm guessing around 650HP.
I don't have any photos on this new computer.
Re: How fast have you gone with a standard port bb head? [Re: ProSport] #2216329
12/18/16 04:40 PM
12/18/16 04:40 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Ummmm... not fast enough. whistling
Re: How fast have you gone with a standard port bb head? [Re: Clanton] #2216353
12/18/16 05:17 PM
12/18/16 05:17 PM
Dragula Offline
Dragula  Offline
And it likes a lot of carburetor.....1.50 60ft on that 3400 steel tank plus driver.
Re: How fast have you gone with a standard port bb head? [Re: viperblue72] #2216361
12/18/16 05:31 PM
12/18/16 05:31 PM
UK
rb446 Offline
rb446  Offline
UK
Here's another combo, my mates 3150lbs Dart>
440, 12.7:1, MP.590sft, 273 rockers, MCH Eddy's (320cfm), Victor int, 1050 Dom, 5000 verter, SS springs, 4.56, 13x31's = 10.14@131
Re: How fast have you gone with a standard port bb head? [Re: viperblue72] #2217961
12/20/16 08:12 PM
12/20/16 08:12 PM
Milledgeville, (central) Georg...
Bighead440 Offline
Bighead440  Offline
170mph, high 7s in a 1700lb rail dragster. 471B with flat-top Ross pistons, 3.9125" stroke, Racer Brown tight lash .660" roller, M1 tunnel ram with 2 x 850 Quickfuels. The heads are Edelbrock RPM's with 2.14x1.81" valves and stiff Lunati springs, Hughes rockers, etc. "Ancient Orange"
