Page 2 of 3 1 2 3
Re: What pistons are in a steel crank post 71 440? [Re: mopar346] #2212988
12/13/16 02:13 AM
12/13/16 02:13 AM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Have built a few 440s using the later casting and have had no problems. I found when I was running 440s that there were more early 440 motors around than later 440s maybe because the later motors were still being used in their original vehicles,while the early ones the vehicles were worn out both body and motor so they were cheap. The only problem I found was when you bought a later 440 it just did not have the good crank. You got more bang for you buck buying the early forged crank motor.
Pick up the 440s one day they will be next to impossible to find cheap. I still have 5 440s as spares and two are early and three are 72 and up.
1971 HEMI E BODY REGISTRY
Re: What pistons are in a steel crank post 71 440? [Re: JohnRR] #2213119
12/13/16 08:08 AM
12/13/16 08:08 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Originally Posted By JohnRR
Originally Posted By 451Mopar
seems 440 builders are getting expensive around here, grab them if the price is right.
My notes from the old Silv-o-lite catalog show the 72 and up 8:1 pistons have a compression height of 1.912"
The 66-71, 9:1 pistons have a compression height of 1.970"
The 66-71 HP, CH = 1.990"? (this still seems fairly low compression?)
The TRW six-pack piston, CH = 2.061"
68-69 440 350HP, 375Hp and the 69 390hp 6pk engines used the same piston.
I imagine that 66-67 is the same because they both have the same advertised compression ratio like 68-69 .
Originally Posted By BSB67
67 hp = 2.00"
68-70 hp = 2.03"
This is more accurate of FACTORY pistons , the numbers at the top are not factory numbers ... not including 70-71 6 pack engines
I thought that was true for the 350 hp motors, but was not sure. And for some reason I was thinking that the 71 piston was 1.99, but I don't know where I got that.
To the OPs question - I don't know. I doubt that it is a 2.00 or 1.99 piston, but not sure if there was something in between that and the 1.91 piston.
Re: What pistons are in a steel crank post 71 440? [Re: mopar346] #2213207
12/13/16 11:09 AM
12/13/16 11:09 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Originally Posted By mopar346
My questions was more about if anyone had seen left over steel crack short blocks used in 72 cars or just steel cranks with the smogger pistons.
440's went to cast cranks in mid-73.
72's had forged cranks.
Guess that has already been stated.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: What pistons are in a steel crank post 71 440? [Re: mopar346] #2213333
12/13/16 03:01 PM
12/13/16 03:01 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
NHRA piston guide,
69 440- .027 below deck
70 440. .051 below deck
71. 440 .051
72. 440 .123 below deck
67 440 .059
68 same as 69
Re: What pistons are in a steel crank post 71 440? [Re: cudaman1969] #2213349
12/13/16 03:43 PM
12/13/16 03:43 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted By cudaman1969
NHRA piston guide,
71. 440 .051
67 440 .059
68 same as 69
NHRA specs are not ACTUAL FACTORY and should not be used as a guide for any spec that is Factory as delivered mopar related.
Re: What pistons are in a steel crank post 71 440? [Re: mopar346] #2213358
12/13/16 04:00 PM
12/13/16 04:00 PM
mopar346 Offline OP
Let me tell ya about fat chicks!
mopar346  Offline OP
So my assumption that a steel crank engine in a 72 was a leftover 71 is incorrect so these 72 engines were built to 72 specs, I.E. dished pistons and not leftover engines built to 71 specs, I.E. flat tops. Pistons are cheap enough in the grand scheme of things I was just trying to cheap out and get extra blacks in the process. I think the NHRA guidelines help in the conversation from the simple fact that they show a significantly shorter piston which is based on a significantly short factory version of the piston.
Thanks for all the input folks.
Careful, your character's showing!
Re: What pistons are in a steel crank post 71 440? [Re: JohnRR] #2213360
12/13/16 04:02 PM
12/13/16 04:02 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
NHRA piston guide,
71. 440 .051
67 440 .059
68 same as 69
So they just pulled those numbers out of the hat? Whitch one do you think is wrong?
Just did the NHRA allowed pistons, 68-71 use same piston but show different ch? Should have checked what head gasket they allowed.
Re: What pistons are in a steel crank post 71 440? [Re: mopar346] #2213400
12/13/16 05:06 PM
12/13/16 05:06 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Wrong again.
The low compression 1972 engines have FLAT TOP pistons. They are just really short to give the low compression.
Here's a screen shot from the video I made where I was removing a broken head bolt from my 1972 440. The bottom end is dead stock. This piston was at TDC and you can see how far down it is.
- Stu Harmon
Re: What pistons are in a steel crank post 71 440? [Re: feets] #2213405
12/13/16 05:18 PM
12/13/16 05:18 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Closer cropped shot. Best I can offer until I tear the engine down again.
- Stu Harmon
Re: What pistons are in a steel crank post 71 440? [Re: mopar346] #2213484
12/13/16 07:50 PM
12/13/16 07:50 PM
mopar346 Offline OP
mopar346  Offline OP
Did all the earlier ones have valve reliefs or just 6 pack pistons? I think an earlier post said all had the same piston year to year. Feets clearly has no valve reliefs so that might be a tell tale sign of compression, I have always known/believed valve reliefs in a piston denoted "high compression" regardless (within reason of domestics) of the make.
Re: What pistons are in a steel crank post 71 440? [Re: mopar346] #2213496
12/13/16 08:15 PM
12/13/16 08:15 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
RBs From 65 up 440-6 only, 64 down Max wedge.
Same pistons year to year, no
Re: What pistons are in a steel crank post 71 440? [Re: cudaman1969] #2213535
12/13/16 09:37 PM
12/13/16 09:37 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
NHRA piston guide,
71. 440 .051
67 440 .059
68 same as 69
Those numbers actually line up well with what I said, minus 1970.
Re: What pistons are in a steel crank post 71 440? [Re: mopar346] #2213566
12/13/16 10:27 PM
12/13/16 10:27 PM
mt. pleasant, PA
Diplomat440 Offline
Diplomat440  Offline
mt. pleasant, PA
I've got a stock '72 short block in my shed. I'll try and measure how far down in the hole the pistons are tomorrow.
Re: What pistons are in a steel crank post 71 440? [Re: cudaman1969] #2213596
12/13/16 11:10 PM
12/13/16 11:10 PM
mopar346 Offline OP
mopar346  Offline OP
I want to make sure I understand your information, so only 6 pack engines had pistons with valve reliefs from 65 up and only Max Wedge pistons had valve reliefs is 64 and older. And 440s did not use the same pistons from say 65-71.
Re: What pistons are in a steel crank post 71 440? [Re: mopar346] #2213734
12/14/16 02:44 AM
12/14/16 02:44 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
One example, 67 had the closed chamber 915 head, so the piston was down in the cylinder more. In 68 the 906 open chamber came about and the piston was raised to keep same CR. I do have some 70 standard pistons I can check against the 68-69 ones I have too, just got to find them, hope I didn't toss them. I can also measure the ones still in the 72 block, if it will turn over, never had any 71s so no idea on those. 70-71 6 Pacs where the tallest CH in 440s and had valve reliefs. Also have a 74 with low pistons, six-pac rods and steel crank, internally balanced, came out of a motor home, got its own balancer too.
Re: What pistons are in a steel crank post 71 440? [Re: mopar346] #2213784
12/14/16 10:24 AM
12/14/16 10:24 AM
mopar346 Offline OP
mopar346  Offline OP
Don't go to any great trouble but it would be interesting to know. If you have a good set of standard bore 68-69/comparable pistons you want to get rid of PM me.
The reason for all these questions is I have a 76 RV engine with very low miles that I should be able to pop a set of good pistons in with some good heads and have another respectable engine ready to go.
Thank you
Re: What pistons are in a steel crank post 71 440? [Re: cudaman1969] #2213882
12/14/16 02:39 PM
12/14/16 02:39 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
NHRA piston guide,
71. 440 .051
67 440 .059
68 same as 69
I don't know where they get them, Chrysler maybe ?? But I know that a 69 440 piston is not .027 in the hole , it's more like .050 in the hole.
For some reason Chrysler piston spec is .020ish HIGHER than actual. Perfect example is a 68-69 383 HP, the factory piston on blueprint spec is .0025 in the hole ... CH is 1.932 ..., NHRA spec has the piston .021 ABOVE the deck. There isn't a 383 delivered from Chrysler with a piston that high above the deck surface.
Also the NHRA spec for a 906 is 79.5cc chamber, ACTUAL is 90-92cc.
Advertised compression ratio from Chrysler on the 383 is 10.0, actual is 9.2, built to the NHRA allowed spec of 79.5cc , +.021 deck and .070 max overbore yields close to 11.5 ...
Re: What pistons are in a steel crank post 71 440? [Re: mopar346] #2213883
12/14/16 02:42 PM
12/14/16 02:42 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
the only dished factory pistons I have seen in a Chrysler was a 73 360 and the 68-69 383 2bbl , I've never seen a dished piston in a 440.
Re: What pistons are in a steel crank post 71 440? [Re: BSB67] #2213888
12/14/16 02:49 PM
12/14/16 02:49 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
NHRA piston guide,
71. 440 .051
67 440 .059
68 same as 69
Common core math maybe wink
10.725 blueprint RB deck
6.768 rod
3.75/2 = 1.875 crank stroke
68-69 2.03 piston is .052 in the hole
66-67 2.00 piston is .082 in the hole
I'm not sure what 70 is because NHRA spec is different for 70, which has 2 piston specs 440-4 and 440-6pk.
The 440-6pk in 70 is the only piston spec where NHRA and factory actually match up, 71???
Re: What pistons are in a steel crank post 71 440? [Re: mopar346] #2213909
12/14/16 03:38 PM
12/14/16 03:38 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Update, found three different pistons. First is 1.937 these I think are the 67 440. Next is the 70 at 1.99 next is a 72 HP set with the six-pac rods at 1.875, these are approximate numbers. Did find my earliest 440 block, cast date 7-2-65
About NHRA discrepancies on years deck heights, the 70 piston is the same as 68-69 so who knows where they come up with their figures. If I was running a 70 440-4 I would want the same compression as the 69 engine (need to look at the HP factor on both years, might rate it lower on 70).
Sorry I don't have a full set of the 1.99 pistons, should be a lot available though. I would keep the low ones, sure nice pulling up to the reg. gas pump. That's what I ran in my 64 Plym and would run 7.55 all day.
Page 2 of 3 1 2 3
