disc brakes...again. #2212001
12/11/16 07:25 PM
12/11/16 07:25 PM
ohio
bbtrux Offline OP
bbtrux  Offline OP
ohio
Ok, planning on using front brake stuff from a 73 duster on a 69 satellite. Satellite is currently manual drum , duster was power disc. Could I use the power booster and master in the satellite without modification or shortcomings (pedal ratio, etc.)? Also, the only thing not saved from the duster was the combination valve. Whats the best source for one? Thanks for any input on what Im sure is an entirely over asked question.
Re: disc brakes...again. [Re: bbtrux] #2212014
12/11/16 07:43 PM
12/11/16 07:43 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
You have to use a Disc/drum master cylinder, because you need more fluid pressure to operate the front discs.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: disc brakes...again. [Re: bbtrux] #2212029
12/11/16 07:55 PM
12/11/16 07:55 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Or a wilwood proportion valve
Re: disc brakes...again. [Re: Clanton] #2212035
12/11/16 08:04 PM
12/11/16 08:04 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
NO
Don't be the exception.
Re: disc brakes...again. [Re: bbtrux] #2212048
12/11/16 08:24 PM
12/11/16 08:24 PM
RSNOMO Online rolleyes
Moparts Torchbearer
RSNOMO  Online Rolleyes
Moparts Torchbearer
Save yourself a LOT of grief...
Find an OEM prop valve...
Re: disc brakes...again. [Re: bbtrux] #2212063
12/11/16 08:44 PM
12/11/16 08:44 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I like to use the prop valves out of Diplomats, there are two to choose from, 10" or 11" rear drums, just get the one that matches your rear drums.
Re: disc brakes...again. [Re: Supercuda] #2212149
12/11/16 10:14 PM
12/11/16 10:14 PM
Now that you mention that, it rings a bell from way back that that is indeed the best choice & another adv of an OE unit is you can retain the OE warning light
Re: disc brakes...again. [Re: Supercuda] #2212172
12/11/16 10:40 PM
12/11/16 10:40 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
NO
Thank you for speaking for the op,I am just providing an option.
Re: disc brakes...again. [Re: bbtrux] #2212180
12/11/16 10:58 PM
12/11/16 10:58 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
In conjunction with a stock combination valve, yes. By itself (he has no stock valve) no.
Re: disc brakes...again. [Re: bbtrux] #2212184
12/11/16 11:00 PM
12/11/16 11:00 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Don't think that the A-body booster and linkage will fit a B-body will it?.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: disc brakes...again. [Re: bbtrux] #2212185
12/11/16 11:01 PM
12/11/16 11:01 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
why?
Re: disc brakes...again. [Re: bbtrux] #2212189
12/11/16 11:06 PM
12/11/16 11:06 PM
moparmarks Offline
moparmarks  Offline
Think the bellcranks are different
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: disc brakes...again. [Re: DrCharles] #2212231
12/12/16 12:13 AM
12/12/16 12:13 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
why?
Because any aftermarket adjustable proportion valve only provides one of several functions that a disc drum combo needs to work properly. It is a tuning aid, not a replacement.
http://stoptech.com/technical-support/technical-white-papers/proportioning-valves
Re: disc brakes...again. [Re: bbtrux] #2212313
12/12/16 02:08 AM
12/12/16 02:08 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
The A-body booster will not fit the Satellite.
Re: disc brakes...again. [Re: bbtrux] #2212429
12/12/16 12:49 PM
12/12/16 12:49 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
I put changed to front disc's on my 70 Sport Satellite - it had manual drum brakes, left it manual disc brake - used the aluminum master cylinder with adapter, from Dr. Diff. It is not hard to brake and works great !
FYI . . . on my 70 300HURST I changed to disc also, but never touched the master cylinder - other than to make sure the check valve was not in the master cylinder. Knowing the master was drum brake, I just made sure to check the reservoir monthly, and never was an issue - pain in the butt, but not an issue . . .
Re: disc brakes...again. [Re: a12rag] #2212458
12/12/16 01:14 PM
12/12/16 01:14 PM
ohio
bbtrux Offline OP
bbtrux  Offline OP
ohio
Ok, next question. If I elect to stick with manual brakes, what master should I use? Dont want to have to buy an adapter of sorts if I dont have to.
Re: disc brakes...again. [Re: bbtrux] #2212468
12/12/16 01:29 PM
12/12/16 01:29 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
I used 73 disc setup 3 times and all's I used was the spindles..bought everything else new from napa. No prop valve..no power booster...and they work fine
Re: disc brakes...again. [Re: terzmo] #2212503
12/12/16 02:34 PM
12/12/16 02:34 PM
ohio
bbtrux Offline OP
bbtrux  Offline OP
ohio
Ok....what did you order a master to fit?
Re: disc brakes...again. [Re: bbtrux] #2212698
12/12/16 07:21 PM
12/12/16 07:21 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I used a Diplomat MC on my car with zero prop valve. I have 73 Charger discs on front and Wilwood Dynalite on the rear.
Car stops on a dime with no issues.
I used to have 4 wheel drums with a Volare cast iron master with zero prop valve and didn't have any issues with that either.
The only reason I switched to discs was I am in the tens now and after I go a few round the drums were starting to fade.
If I were going with some sort of valve it would be the Wilwood.
Gus beer
64 Plymouth Savoy
Dana 60
Re: disc brakes...again. [Re: bbtrux] #2212771
12/12/16 09:26 PM
12/12/16 09:26 PM
a12rag Offline
a12rag  Offline
Mom & Dad had a 76 Valiant with manual disc brakes . . . could probably look for MC for that. Or the FMJ Body cars . . . .
