Re: disc brakes...again.
[Re: bbtrux]
#2212014
12/11/16 07:43 PM
12/11/16 07:43 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
You have to use a Disc/drum master cylinder, because you need more fluid pressure to operate the front discs.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Clanton]
#2212035
12/11/16 08:04 PM
12/11/16 08:04 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Or a wilwood proportion valve NO
[Re: bbtrux]
#2212048
12/11/16 08:24 PM
12/11/16 08:24 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
the only thing not saved from the duster was the combination valve. Whats the best source for one? Save yourself a LOT of grief... Find an OEM prop valve...
[Re: bbtrux]
#2212063
12/11/16 08:44 PM
12/11/16 08:44 PM
Supercuda
About to go away
About to go away
up yours
I like to use the prop valves out of Diplomats, there are two to choose from, 10" or 11" rear drums, just get the one that matches your rear drums.
[Re: Supercuda]
#2212149
12/11/16 10:14 PM
12/11/16 10:14 PM
RapidRobert
I like to use the prop valves out of Diplomats, there are two to choose from, 10" or 11" rear drums, just get the one that matches your rear drums. Now that you mention that, it rings a bell from way back that that is indeed the best choice & another adv of an OE unit is you can retain the OE warning light
[Re: bbtrux]
#2212180
12/11/16 10:58 PM
12/11/16 10:58 PM
Supercuda
About to go away
About to go away
up yours
In conjunction with a stock combination valve, yes. By itself (he has no stock valve) no.
[Re: bbtrux]
#2212185
12/11/16 11:01 PM
12/11/16 11:01 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
In conjunction with a stock combination valve, yes. By itself (he has no stock valve) no. why?
[Re: DrCharles]
#2212231
12/12/16 12:13 AM
12/12/16 12:13 AM
Supercuda
About to go away
About to go away
up yours
In conjunction with a stock combination valve, yes. By itself (he has no stock valve) no. why? Because any aftermarket adjustable proportion valve only provides one of several functions that a disc drum combo needs to work properly. It is a tuning aid, not a replacement. http://stoptech.com/technical-support/technical-white-papers/proportioning-valves
[Re: bbtrux]
#2212429
12/12/16 12:49 PM
12/12/16 12:49 PM
Posts: 2,918 Calgary, Alberta Canada
a12rag
I put changed to front disc's on my 70 Sport Satellite - it had manual drum brakes, left it manual disc brake - used the aluminum master cylinder with adapter, from Dr. Diff. It is not hard to brake and works great !
FYI . . . on my 70 300HURST I changed to disc also, but never touched the master cylinder - other than to make sure the check valve was not in the master cylinder. Knowing the master was drum brake, I just made sure to check the reservoir monthly, and never was an issue - pain in the butt, but not an issue . . .
[Re: bbtrux]
#2212698
12/12/16 07:21 PM
12/12/16 07:21 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
I used a Diplomat MC on my car with zero prop valve. I have 73 Charger discs on front and Wilwood Dynalite on the rear. Car stops on a dime with no issues. I used to have 4 wheel drums with a Volare cast iron master with zero prop valve and didn't have any issues with that either. The only reason I switched to discs was I am in the tens now and after I go a few round the drums were starting to fade. If I were going with some sort of valve it would be the Wilwood. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
