Crank Oil Slinger: Yes or No ? #221191
02/11/09 03:41 PM
02/11/09 03:41 PM
Renton, Wa.
Classof70Chally Offline OP
super gas
super gas
Renton, Wa.
I'm putting my shortblock together and installed and degreed my timing set. The bad news is I can't locate my crank oil slinger. I've heard that some use it and some don't. Looking for some 'expert' opinions. BTW this is a street motor (440) if that matters. Thanks.
Re: Crank Oil Slinger: Yes or No ? [Re: Classof70Chally] #221192
02/11/09 03:44 PM
02/11/09 03:44 PM
Fort DODGE, Ioway
O
origcharger Offline
origcharger  Offline
O
Fort DODGE, Ioway
IMHO, Leave it out!!
MOPARTS ALERT!: Chris Pugh aka gabodyman of Dalton, Georgia, cashed my $140 money order on 4-16-02 never sent parts. On 3-19-07 he agreed to return my money; "april 9, it will be in the mail by that date""will do as promised. chris" Still no parts and no money!
Re: Crank Oil Slinger: Yes or No ? [Re: Classof70Chally] #221193
02/11/09 04:21 PM
02/11/09 04:21 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Don't loose any sleep over it. some came with them some didn't from the factory.
Re: Crank Oil Slinger: Yes or No ? [Re: Classof70Chally] #221194
02/11/09 04:24 PM
02/11/09 04:24 PM
CHRGR69 Offline
CHRGR69  Offline
Fagetabout it!
Grandma always said I had "hands of gold"!
Re: Crank Oil Slinger: Yes or No ? [Re: Classof70Chally] #221195
02/11/09 04:35 PM
02/11/09 04:35 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I'd use it if you can find it. Helps gaurd against oil leakage at the crank seal and you know how irrating oil leaks are.
Re: Crank Oil Slinger: Yes or No ? [Re: MoparforLife] #221196
02/11/09 04:40 PM
02/11/09 04:40 PM
Wilmington,NC
I
I go fast Offline
I go fast  Offline
I
Wilmington,NC
In 35+ years of taking apart B series engines,I have yet to see an original engine that has never been apart that didn't have one.
Re: Crank Oil Slinger: Yes or No ? [Re: Challenger 1] #221197
02/11/09 05:19 PM
02/11/09 05:19 PM
Newark,De
hemi471 Offline
hemi471  Offline
Newark,De
Re: Crank Oil Slinger: Yes or No ? [Re: I go fast] #221198
02/11/09 05:20 PM
02/11/09 05:20 PM
Alone in the darkness
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
Same here. I have been around a very long time and have pulled plenty of originals apart at the yard. I don`t spend my time second guessing the engineers who designed these things so I always reinstall it.
`02 RAM2500 SPORT V10 4x4 `06 GMC sierra NO cars
Re: Crank Oil Slinger: Yes or No ? [Re: gamagoat6x6] #221199
02/11/09 05:53 PM
02/11/09 05:53 PM
Fort DODGE, Ioway
O
origcharger Offline
origcharger  Offline
O
Fort DODGE, Ioway
Ok, However roller timing chain clearance is my concern. Those engineers were only concerned with the OEM stuff of the time.
Re: Crank Oil Slinger: Yes or No ? [Re: origcharger] #221200
02/11/09 06:07 PM
02/11/09 06:07 PM
Cincinnati, Ohio
Cincinnati, Ohio
All of my original 340s had double roller chains and they all have oil slingers.
Re: Crank Oil Slinger: Yes or No ? [Re: Challenger 1] #221201
02/11/09 06:20 PM
02/11/09 06:20 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
As did all Max Wedge motors,it shouldn't be an issue.
Re: Crank Oil Slinger: Yes or No ? [Re: 62maxwgn] #221202
02/11/09 07:39 PM
02/11/09 07:39 PM
Upper Midwest
Upper Midwest
You are right that most if not all bb engines had them but I have seem as many small blocks with them as with out. They are oil leak preventive for the most part and seals are much better quality now than in yester year.
Re: Crank Oil Slinger: Yes or No ? [Re: MoparforLife] #221203
02/11/09 07:45 PM
02/11/09 07:45 PM
Renton, Wa.
super gas
super gas
Renton, Wa.
Well, I think I'll try to round one up if I can. Thanks for the input guys!
Re: Crank Oil Slinger: Yes or No ? [Re: Classof70Chally] #221204
02/11/09 08:01 PM
02/11/09 08:01 PM
Upper Midwest
Upper Midwest
Mancini has them.
Re: Crank Oil Slinger: Yes or No ? [Re: Classof70Chally] #221205
02/11/09 09:55 PM
02/11/09 09:55 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Without it, the crank pulley alignment will be off ever so slightly.
Re: Crank Oil Slinger: Yes or No ? *DELETED* [Re: MoparforLife] #221206
02/11/09 10:40 PM
02/11/09 10:40 PM
Fort DODGE, Ioway
O
origcharger Offline
origcharger  Offline
O
Fort DODGE, Ioway
Post deleted by origcharger
Re: Crank Oil Slinger: Yes or No ? [Re: origcharger] #221207
02/11/09 11:50 PM
02/11/09 11:50 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
I did a cam change some years back ...I misplaced the slinger ... put the TC cover back on without the slinger and it leaked like a Maggot Farmer !!
Re: Crank Oil Slinger: Yes or No ? [Re: MoparforLife] #221208
02/12/09 12:03 AM
02/12/09 12:03 AM
Fort DODGE, Ioway
O
origcharger Offline
origcharger  Offline
O
Fort DODGE, Ioway
Mancini has them.
Now that you mention Mancini, I believe it was an MRE roller chain set that chewed up my oil slinger.
Re: Crank Oil Slinger: Yes or No ? [Re: dOoC] #221209
02/12/09 12:04 AM
02/12/09 12:04 AM
Renton, Wa.
super gas
super gas
Renton, Wa.
OK, I'm convinced, I'm going to put one back on. My son has a couple laying around his shop so I'll use one of his and replace it later.
Re: Crank Oil Slinger: Yes or No ? [Re: origcharger] #221210
02/12/09 12:51 AM
02/12/09 12:51 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Mancini has them.
If the chain touched the slinger then the slinger was installed backward...
