Re: 9" Backspace on Rim
[Re: dthemi]
#221157
02/11/09 04:51 PM
02/11/09 04:51 PM
Posts: 1,217 Wellington, FL
cudabunch
Wellington, FL
Or get a 12 inch rim with 3 in backspace and run it backwards
Never would of thought of that I think I would cut the Dana.
[Re: cudabunch]
#221158
02/11/09 04:57 PM
02/11/09 04:57 PM
Posts: 3,097 back in Georgia
dthemi
back in Georgia
Really, if the wheel has a bolt in center take it out and turn it around backwards. Who knows it may work
[Re: 506RR]
#221161
02/11/09 06:58 PM
02/11/09 06:58 PM
Triple Threat
Renton Washington
might try Bogart as well.
IMO for as much money as you will have into a set of custom, goofy offset wheels, you could probably have your rearend narrowed for the same money. Just a thought.
[Re: 65dragnet]
#221163
02/11/09 11:12 PM
02/11/09 11:12 PM
Posts: 977 Colorado
506RR
Colorado
If you had access to a lathe you can do your own. I did Itook a set of weld draglites and separated them at the weld and added a strip in the middle tig weld it up viola . Mine are 15x12 1/2 8 1/2 backspace.
I do have access to a lathe, but my current rims are 15x8 so I need to buy 15x12. Figured I may as well get the correct backspace when I order them. That is a good plan though. That would be interesting to try.
[Re: Triple Threat]
#221164
02/11/09 11:14 PM
02/11/09 11:14 PM
Posts: 977 Colorado
506RR
Colorado
I'll call Bogart tomorrow.
I am actually surprised there are not more rims like this already out there. Being able to keep the housing stock length and buy rims to suit seems like a pretty good idea versus having to narrow the rearend after minitubbing. On a full tub I understand completely, as the rims are so big.
[Re: 506RR]
#221165
02/11/09 11:31 PM
02/11/09 11:31 PM
Triple Threat
Renton Washington
Most like the idea of being able to shorten the axle, less axle and less back spacing means less rotating weight. Although the ease of just bolting on a wheel would be nice.
Think about it, everything gets smaller and lighter when you narrow a rear end. The difference might not make a difference, but you know us racers, every little bit counts.
