9" Backspace on Rim #221154
02/11/09 02:41 PM
02/11/09 02:41 PM
Colorado
506RR Offline OP
506RR  Offline OP
Colorado
What companies are willing to do a 9" Backspace on rims?
I contacted American Racing and Weld, they said that 7 to 7.5" is the most they will do.
I am trying to avoid having to cut my Dana 60 down, but am wanting to run a 15x12 rim on my car.
Any help is greatly appreciated!
Re: 9" Backspace on Rim [Re: 506RR] #221155
02/11/09 03:44 PM
02/11/09 03:44 PM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: 9" Backspace on Rim [Re: BBR] #221156
02/11/09 04:47 PM
02/11/09 04:47 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Or get a 12 inch rim with 3 in backspace and run it backwards
Re: 9" Backspace on Rim [Re: dthemi] #221157
02/11/09 04:51 PM
02/11/09 04:51 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
Never would of thought of that I think I would cut the Dana.
Re: 9" Backspace on Rim [Re: cudabunch] #221158
02/11/09 04:57 PM
02/11/09 04:57 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Really, if the wheel has a bolt in center take it out and turn it around backwards. Who knows it may work
Re: 9" Backspace on Rim [Re: 506RR] #221159
02/11/09 05:45 PM
02/11/09 05:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Centerline does a 8" back space
Re: 9" Backspace on Rim [Re: MR_P_BODY] #221160
02/11/09 06:56 PM
02/11/09 06:56 PM
Colorado
506RR Offline OP
506RR  Offline OP
Colorado
Called Holeshot, and they will do an 8 7/8" backspace which will work.
Anyone know of any other companies?
Thanks for all the replies so far guys!
Re: 9" Backspace on Rim [Re: 506RR] #221161
02/11/09 06:58 PM
02/11/09 06:58 PM
Renton Washington
Triple Threat Offline
Renton Washington
might try Bogart as well.
IMO for as much money as you will have into a set of custom, goofy offset wheels, you could probably have your rearend narrowed for the same money. Just a thought.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: 9" Backspace on Rim [Re: 506RR] #221162
02/11/09 07:50 PM
02/11/09 07:50 PM
Indiana
65dragnet Offline
Happy Birthday 65dragnet  Offline
Indiana
If you had access to a lathe you can do your own. I did Itook a set of weld draglites and separated them at the weld and added a strip in the middle tig weld it up viola . Mine are 15x12 1/2 8 1/2 backspace.
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: 9" Backspace on Rim [Re: 65dragnet] #221163
02/11/09 11:12 PM
02/11/09 11:12 PM
Colorado
506RR Offline OP
506RR  Offline OP
Colorado
I do have access to a lathe, but my current rims are 15x8 so I need to buy 15x12. Figured I may as well get the correct backspace when I order them. That is a good plan though. That would be interesting to try.
Re: 9" Backspace on Rim [Re: Triple Threat] #221164
02/11/09 11:14 PM
02/11/09 11:14 PM
Colorado
506RR Offline OP
506RR  Offline OP
Colorado
I'll call Bogart tomorrow.
I am actually surprised there are not more rims like this already out there. Being able to keep the housing stock length and buy rims to suit seems like a pretty good idea versus having to narrow the rearend after minitubbing. On a full tub I understand completely, as the rims are so big.
Re: 9" Backspace on Rim [Re: 506RR] #221165
02/11/09 11:31 PM
02/11/09 11:31 PM
Renton Washington
Renton Washington
Most like the idea of being able to shorten the axle, less axle and less back spacing means less rotating weight. Although the ease of just bolting on a wheel would be nice.
Think about it, everything gets smaller and lighter when you narrow a rear end. The difference might not make a difference, but you know us racers, every little bit counts.
-Dustin
Re: 9" Backspace on Rim [Re: Triple Threat] #221166
02/11/09 11:36 PM
02/11/09 11:36 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Unless you have something super trick, axles and rearend narrowing is relatively inexpensive.
A narrow rearend is lighter, cleaner and stiffer.
