#221154 - 02/11/09 11:41 AM 9" Backspace on Rim
506RR Offline
Loc: Colorado
What companies are willing to do a 9" Backspace on rims?
I contacted American Racing and Weld, they said that 7 to 7.5" is the most they will do.
I am trying to avoid having to cut my Dana 60 down, but am wanting to run a 15x12 rim on my car.
Any help is greatly appreciated!
#221155 - 02/11/09 12:44 PM Re: 9" Backspace on Rim [Re: 506RR]
BBR Offline
Loc: Texas
Drag Week 2011 - 77th place - DD Drag Week 2012 - 2nd place SRBB N/A Drag Week 2014 - Kapooya
#221156 - 02/11/09 01:47 PM Re: 9" Backspace on Rim [Re: BBR]
dthemi Online   content
Loc: back in Georgia
Or get a 12 inch rim with 3 in backspace and run it backwards
#221157 - 02/11/09 01:51 PM Re: 9" Backspace on Rim [Re: dthemi]
cudabunch Offline
Loc: Wellington, FL
Never would of thought of that I think I would cut the Dana.
#221158 - 02/11/09 01:57 PM Re: 9" Backspace on Rim [Re: cudabunch]
Really, if the wheel has a bolt in center take it out and turn it around backwards. Who knows it may work
#221159 - 02/11/09 02:45 PM Re: 9" Backspace on Rim [Re: 506RR]
MR_P_BODY Online   content
Loc: Romeo MI
Centerline does a 8" back space
W-9 8.94 @ 151 NOW ON E-85
Mike "Raff"...(180)Watching over us
CAR IS FOR SALE
#221160 - 02/11/09 03:56 PM Re: 9" Backspace on Rim [Re: MR_P_BODY]
506RR Offline
Loc: Colorado
Called Holeshot, and they will do an 8 7/8" backspace which will work.
Anyone know of any other companies?
Thanks for all the replies so far guys!
#221161 - 02/11/09 03:58 PM Re: 9" Backspace on Rim [Re: 506RR]
Triple Threat Offline
Loc: Renton Washington
might try Bogart as well.
IMO for as much money as you will have into a set of custom, goofy offset wheels, you could probably have your rearend narrowed for the same money. Just a thought.
-Dustin
392" G3 Hemi
1.37, 6.17@111, 9.74@136.9
#221162 - 02/11/09 04:50 PM Re: 9" Backspace on Rim [Re: 506RR]
65dragnet Offline
Loc: Indiana
If you had access to a lathe you can do your own. I did Itook a set of weld draglites and separated them at the weld and added a strip in the middle tig weld it up viola . Mine are 15x12 1/2 8 1/2 backspace.
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
#221163 - 02/11/09 08:12 PM Re: 9" Backspace on Rim [Re: 65dragnet]
506RR Offline
Loc: Colorado
I do have access to a lathe, but my current rims are 15x8 so I need to buy 15x12. Figured I may as well get the correct backspace when I order them. That is a good plan though. That would be interesting to try.
#221164 - 02/11/09 08:14 PM Re: 9" Backspace on Rim [Re: Triple Threat]
506RR Offline
Loc: Colorado
I'll call Bogart tomorrow.
I am actually surprised there are not more rims like this already out there. Being able to keep the housing stock length and buy rims to suit seems like a pretty good idea versus having to narrow the rearend after minitubbing. On a full tub I understand completely, as the rims are so big.
#221165 - 02/11/09 08:31 PM Re: 9" Backspace on Rim [Re: 506RR]
Most like the idea of being able to shorten the axle, less axle and less back spacing means less rotating weight. Although the ease of just bolting on a wheel would be nice.
Think about it, everything gets smaller and lighter when you narrow a rear end. The difference might not make a difference, but you know us racers, every little bit counts.
-Dustin
392" G3 Hemi
#221166 - 02/11/09 08:36 PM Re: 9" Backspace on Rim [Re: Triple Threat]
DoctorDiff Offline
Loc: Polson, MT
Unless you have something super trick, axles and rearend narrowing is relatively inexpensive.
A narrow rearend is lighter, cleaner and stiffer.
Contact info
25,383 Registered Members
190,972 Topics
Forgive me father, for I have sinned.........
by SKR8PN
07/20/18 07:17 PM
First time front suspension issues...
by ksat
07/20/18 07:12 PM
Which rad cap
by dragon
07/20/18 06:29 PM
1970 - 71 Cuda Convertible trunk torsion bars
by flitesweep
07/20/18 06:26 PM
