need help w/33 ply ext. door handle #2211278
12/10/16 03:30 PM
12/10/16 03:30 PM
Shelby, Ohio
2
2abodymcodes Offline OP
Shelby, Ohio
need to remove the base (escutcheon) from my exterior door handles so I can send the handles out for chrome. I can't figure out how they come apart and I don't want to break them because they are very hard to find. anyone know how they come apart ?
Re: need help w/33 ply ext. door handle [Re: 2abodymcodes] #2211356
12/10/16 05:48 PM
12/10/16 05:48 PM
British Columbia, Canada
Old Ray Offline
Old Ray  Offline
No, sorry, but have you tried pushing the escutcheon up / out to see if there is a wire clip under it?
Re: need help w/33 ply ext. door handle [Re: Old Ray] #2211372
12/10/16 06:13 PM
12/10/16 06:13 PM
Shelby, Ohio
2
Shelby, Ohio
None that I can see
Re: need help w/33 ply ext. door handle [Re: 2abodymcodes] #2211448
12/10/16 08:33 PM
12/10/16 08:33 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
The handle shaft is probably swaged to the escutcheon. You'll have to remove the swage and reinstall the handle with some sort of homemade device....possibly a snap ring.
Re: need help w/33 ply ext. door handle [Re: John_Kunkel] #2211545
12/10/16 10:48 PM
12/10/16 10:48 PM
Shelby, Ohio
2
Shelby, Ohio
Thanks, but what does swaged mean ?
Re: need help w/33 ply ext. door handle [Re: 2abodymcodes] #2211691
12/11/16 03:38 AM
12/11/16 03:38 AM
Rio Linda, CA
Rio Linda, CA
Swaging is a form of crimping; material on one part is crimped in order to retain another part. In this case the handle shaft might have a groove (where the shaft changes from round to square) into which a ring is crimped to keep the handle in the escutcheon but still allowing the handle to turn.
Just spitballing, not positive that's the way it's retained.
Re: need help w/33 ply ext. door handle [Re: 2abodymcodes] #2212325
12/12/16 02:46 AM
12/12/16 02:46 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
If that is swaged or somehow retained where the ring must be destroyed to remove the handle you can still secure it a couple other ways.Either make a collar to fit over the square shaft with a set screw or drill the square stock for a roll pin and use a washer to retain the escutcheon.Maybe add a wave washer/nylon washer to reduce rattling while there. It looks like the first 1/2" is what engages to the door latch so I'm assuming you have room for either.~RT
Re: need help w/33 ply ext. door handle [Re: RTSrunner] #2213247
12/13/16 12:45 PM
12/13/16 12:45 PM
Shelby, Ohio
2
Shelby, Ohio
Thanks for the helpful ideas. Just sent the handles out for re-chrome. I'll figure it out when they come back.
Re: need help w/33 ply ext. door handle [Re: 2abodymcodes] #2213789
12/14/16 11:14 AM
12/14/16 11:14 AM
moparx Offline
moparx  Offline
did you get the handles apart, or did you send them out the way they were ?
beer
Re: need help w/33 ply ext. door handle [Re: moparx] #2216253
12/18/16 02:51 PM
12/18/16 02:51 PM
Shelby, Ohio
2
Shelby, Ohio
i took them apart. I destroyed the thin steel cones that hold them together but i'll come up with a way to put them back together when I get them back from the chrome. I also could not figure how to get the key lock out of the passenger side. I didn't want to break it, so I told the chrome shop to chrome over top of it.
Re: need help w/33 ply ext. door handle [Re: 2abodymcodes] #2216365
12/18/16 05:36 PM
12/18/16 05:36 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Look at these RETAINERS and see if one of them looks like the right one.
As for the lock, it'll never work again if they chrome it. A lock smith could have removed it for you.
Don't be the exception.
Re: need help w/33 ply ext. door handle [Re: 2abodymcodes] #2217985
12/20/16 09:08 PM
12/20/16 09:08 PM
Bellevue,Mich.
Dodge33 Offline
Dodge33  Offline
Bellevue,Mich.
The lock will be melted/ destroyed. I have a 33 dodge coupe and the trunk handle lock was destroyed during chrome.
Re: need help w/33 ply ext. door handle [Re: 2abodymcodes] #2218651
12/21/16 11:14 PM
12/21/16 11:14 PM
Shelby, Ohio
2
Shelby, Ohio
Yea, I know that the lock will be destroyed. I didn't want to take a chance on breaking my handle getting the lock out. I'll probably never need to lock it anyway
