2013 Grand Caravan clunk #2210792
12/09/16 05:39 PM
12/09/16 05:39 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
I've had this van for about 4 months. With the drive train hot or cold I will OCCASIONALLY get a transmission clunk when shifting from reverse to drive. I have the car fully stopped and the brakes applied.
This seems to be a problem with this generation van. I haven't learned much from the Web other than it seems to happen to others and not much has helped. Computer flashes, bolt tightening, fluid and filter change didn't do much.
Any opinions?
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: 2013 Grand Caravan clunk [Re: cdstl] #2210941
12/09/16 10:51 PM
12/09/16 10:51 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Had an 04 caravan do that because the torque of the big axle hub bearing nuts were not up to factory torque specs. You could see some very fine rust buildup around spline area.
Re: 2013 Grand Caravan clunk [Re: cdstl] #2211066
12/10/16 03:07 AM
12/10/16 03:07 AM
wisconsin
mod381 Offline
mod381  Offline
wisconsin
It is normal. It is caused from the multiple sets of planetary gears in the trans used causing driveline wind-up. The 6 speed trans is almost the same as the 4 speed except they use a compounder instead of a straight transfer shaft. The compounder has clutches,planetary gears in it.
Re: 2013 Grand Caravan clunk [Re: cdstl] #2211132
12/10/16 11:13 AM
12/10/16 11:13 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Ok thanks. I talked to a Tech buddy that works at a Chrysler dealership and he had never heard about it.
He talked about the axle nuts and maybe the "K" frame bolts.
Re: 2013 Grand Caravan clunk [Re: cdstl] #2212010
12/11/16 07:37 PM
12/11/16 07:37 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
No repair needed is the best news.
I hope it is normal.
Our experience was bad lower control arm bushings.
Of course our van is a much older.
I have mechanical Aptitude.
I can screw up anything.
