400 "230"block main ??? #2210211
12/08/16 07:04 PM
12/08/16 07:04 PM
K
KOS Offline OP
KOS  Offline OP
K
how much would you compromise strenght if your line bored the mains to 440 size?
Re: 400 "230"block main ??? [Re: KOS] #2210218
12/08/16 07:10 PM
12/08/16 07:10 PM
AndyF Offline
AndyF  Offline
Some for sure. The way I think about it is that steel is a lot stronger than cast iron so keep the thick cast iron and go with the smaller steel shaft. Only problem with using the 383 size mains is that there aren't very many choices for bearings.
Re: 400 "230"block main ??? [Re: AndyF] #2210277
12/08/16 08:37 PM
12/08/16 08:37 PM
K
KOS Offline OP
KOS  Offline OP
K
yes true on the bearings........so ill just turn the crank down if i end up using what i have if not ill buy one with the smaller journal.
Re: 400 "230"block main ??? [Re: KOS] #2210291
12/08/16 08:52 PM
12/08/16 08:52 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I wouldn't worry about it if its the true 230 block from 4/4/71 to 10/10/71. The webbing thickness is huge compared to any other 440 block with the bigger mains.
Barton does them all this way or at least he did. I myself would only do it , if it were a true 230. Even then though, I might not waste the money.
Re: 400 "230"block main ??? [Re: KOS] #2210305
12/08/16 09:19 PM
12/08/16 09:19 PM
K
KOS Offline OP
KOS  Offline OP
K
whats the diff in price?grind crank down or line bore...
Re: 400 "230"block main ??? [Re: KOS] #2210307
12/08/16 09:27 PM
12/08/16 09:27 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
turn the crank. ON an interesting side note I had a 230 383 block in the shop a few weeks ago. Looked and was marked just like the 400 and had a July casting date. Thought it was cool.
Todd
Re: 400 "230"block main ??? [Re: sasquatch] #2210316
12/08/16 09:40 PM
12/08/16 09:40 PM
K
KOS Offline OP
KOS  Offline OP
K
Todd
that is cool ive heard of the 230 383block but never came across one.i am going to grind the crank just curious of the price diff.....
Re: 400 "230"block main ??? [Re: KOS] #2210323
12/08/16 09:47 PM
12/08/16 09:47 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Don't know the price diff. But its more then just a line bore. The bearing register divots will need to be machined back in.
Re: 400 "230"block main ??? [Re: Sport440] #2210337
12/08/16 10:00 PM
12/08/16 10:00 PM
K
KOS Offline OP
KOS  Offline OP
K
ya never thought of that ...
Re: 400 "230"block main ??? [Re: sasquatch] #2210338
12/08/16 10:02 PM
12/08/16 10:02 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Todd
Did it have super-thick cylinder walls (so it could be bored to 400 size)? work
Re: 400 "230"block main ??? [Re: DrCharles] #2210343
12/08/16 10:08 PM
12/08/16 10:08 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Did not have chance to sonic test but I would bet money it did.
Todd
Re: 400 "230"block main ??? [Re: KOS] #2210509
12/09/16 03:29 AM
12/09/16 03:29 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
IMO buy a better block smile
Re: 400 "230"block main ??? [Re: KOS] #2210529
12/09/16 04:45 AM
12/09/16 04:45 AM
I've had two early(06-71 to 10-71) 230 blocks, one had the large casting numbers on the block and the other one didn't confused
Neither one of them had really thick cylinder walls when sonic tested shruggy
Re: 400 "230"block main ??? [Re: Al_Alguire] #2210543
12/09/16 08:53 AM
12/09/16 08:53 AM
K
KOS Offline OP
KOS  Offline OP
K
[quote=Al_Alguire]IMO buy a better block smile
i would never build a stock block again i have a indy maxx low deck waiting for a set of Mike Duke oval port MCs wink.....its for my son just a mild (600hp max) build for his 67 R/T.
Re: 400 "230"block main ??? [Re: Cab_Burge] #2210544
12/09/16 08:58 AM
12/09/16 08:58 AM
K
KOS Offline OP
KOS  Offline OP
K
ya Cab where gonna have it sonic checked too...........
Re: 400 "230"block main ??? [Re: KOS] #2210563
12/09/16 10:52 AM
12/09/16 10:52 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
I personally think line bore to 440 main with aluminum caps. The larger main diameter will flex less. Plus lot better bearing choices.
Re: 400 "230"block main ??? [Re: Sport440] #2210606
12/09/16 12:13 PM
12/09/16 12:13 PM
moparx Offline
moparx  Offline
as i understand it, those are only used as assembly and location aids, while the crush prevents the bearing shells from spinning. would, or could it be possible, to meticulously position the bearing shell in the block after removing the locating tang on the upper shell ?
beer
