Racing a 5.9 magnum #2210448
12/09/16 01:20 AM
12/09/16 01:20 AM
Indiana
Crabra Offline OP
Crabra  Offline OP
Indiana
Is anybody racing a 5.9 magnum engine.I have spent some time on magnumswap.com.I think it's in my future.Any thoughts?My car is a 72 duster with a 318.Best time last year 15.72.Won once runner up once.Having more fun than I should be allowed.
Re: Racing a 5.9 magnum [Re: Crabra] #2210456
12/09/16 01:36 AM
12/09/16 01:36 AM
On the parachute mount
N
n20mstr Online content
n20mstr  Online Content
N
Great engine even in stock form. My son has one in a duster from a junkyard runs low 12 on motor and has been 10.99 with a plate . Stock motor except for cam intake and headers.
....BAD A$$ STREET CAR.....
Re: Racing a 5.9 magnum [Re: n20mstr] #2210460
12/09/16 01:43 AM
12/09/16 01:43 AM
Indiana
Crabra Offline OP
Crabra  Offline OP
Indiana
Magnumswap.com says the same thing.I have a chance to buy a 80k motor for 725.00 what do you think?
Re: Racing a 5.9 magnum [Re: Crabra] #2210474
12/09/16 02:17 AM
12/09/16 02:17 AM
N
N
My son paid 300.00 and sold the whole intake/wire harness for 100.00 , don't know how many miles on his motor but it does smoke sometimes. His came out of a 98 jeep ? You will at the minimum need an intake carb, oil pan and figure out the front cover. We took all his front cover etc off his 318 so you can do the same. Sounds like a good deal for you. Rebuild the motor and even all stock stuff you should have an 11 sec car pretty low budget
Re: Racing a 5.9 magnum [Re: n20mstr] #2210507
12/09/16 03:25 AM
12/09/16 03:25 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
A local Mopar guy races a Duster in Super Stock with a 340 and a late full size Dodge truck with a 360 Magnum in Stock. The Duster runs in the 10s and the truck runs high 11s and that is with the stock though tuned FI system. His name is Kelly Thomas and he is a serious racer in NHRA Division 6.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Racing a 5.9 magnum [Re: Crabra] #2210557
12/09/16 10:37 AM
12/09/16 10:37 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Price is sightly steep but might be ok depending on your area.
I have a 5.9 in my '74 Duster, 13.0's with 3.55's out back and 3675 lbs with driver. With the 3.90's being installed later this winter it should be in the 12's all day long.
Very mild motor. Used roller cam from Dakota forum, dual plain intake, 750 AFB, 1 3/4 headers and 1.88 heads from Enginequest.
"I think its got a hemi"
Re: Racing a 5.9 magnum [Re: Crabra] #2211071
12/10/16 03:43 AM
12/10/16 03:43 AM
Earth
Rob C Offline
Rob C  Offline
Earth
FWIW, MP's create 360's are 5.9's. Stock long blocks with bolt on goodies and a cam. Underated in the HP ratings as to not get creamed for not having that advertised rating.
Normal 360/380 create engines dyno'd north of 400.
Copy it but with a better cam and enjoy the heck out of it.
Another FWIW, use ether Hooker Super Comp headers at 1-3/4 or TTI stepped.
Re: Racing a 5.9 magnum [Re: Crabra] #2211117
12/10/16 10:02 AM
12/10/16 10:02 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
There used to be some guys on here that made a jig to drill magnum heads with LA patterns, for better intake selection. They used to rent them out to other members on here, but don't remember who made them.
[image][/image]
Re: Racing a 5.9 magnum [Re: Crabra] #2211177
12/10/16 01:09 PM
12/10/16 01:09 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
I have a junkyard 5.9 in my 3300lb Dakota that goes 11.70s with ease. It started out as a 160k motor so I took it apart to inspect it. Just needed rod bearings but the cylinders still looked great! So I dingleberry honed it and put in a set of std. KB107 pistons and a Hughes 234/238 hyd. roller cam. For heads, I used a pair of MP iron R/Ts w/ 2.02 in.valves that were lightly ported. Topped it off with an Indy single plane and an 850 carb. I'm happy with this engine so far and I believe it has quite abit more potential as it is. It would be hard to convince me to build an LA engine over a magnum in a less than 450hp application. The salvage yards are littered with these great little engines that make exceptional power for little money. Not to mention they are reliable as hell and dont leak oil.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Racing a 5.9 magnum [Re: sgcuda] #2211537
12/10/16 10:35 PM
12/10/16 10:35 PM
Illinois, USA
jeff1974 Offline
jeff1974  Offline
Illinois, USA
That would be Hot Rod Dave. He made the jigs referred to, and I think he wanted $30 apiece for them back in the day. Hit him up if your interested
Re: Racing a 5.9 magnum [Re: jeff1974] #2211811
12/11/16 02:08 PM
12/11/16 02:08 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
The crate short blocks are great, I put my W2 heads on one with a 590 lift mechanical cam and went 10.70s with it in my Dart, after spinning a bearing we upgraded to a forged crank, Scat rods and JE pistons and I Went 10.40 a best , 549 hp and 450 tq on the dyno. I just took it out last year to put in my 408 and it still ran strong after over 1,000 runs. I wish M/P still offered them, I bought a used 5.9 Magnum short block on here a few years ago to do for my D150 some day.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
