Re: Racing a 5.9 magnum
[Re: Crabra]
#2210456
12/09/16 01:36 AM
12/09/16 01:36 AM
Posts: 4,684 On the parachute mount
n20mstr
Great engine even in stock form. My son has one in a duster from a junkyard runs low 12 on motor and has been 10.99 with a plate . Stock motor except for cam intake and headers.
....BAD A$$ STREET CAR.....
[Re: Crabra]
#2210474
12/09/16 02:17 AM
12/09/16 02:17 AM
n20mstr
Magnumswap.com says the same thing.I have a chance to buy a 80k motor for 725.00 what do you think? My son paid 300.00 and sold the whole intake/wire harness for 100.00 , don't know how many miles on his motor but it does smoke sometimes. His came out of a 98 jeep ? You will at the minimum need an intake carb, oil pan and figure out the front cover. We took all his front cover etc off his 318 so you can do the same. Sounds like a good deal for you. Rebuild the motor and even all stock stuff you should have an 11 sec car pretty low budget
[Re: n20mstr]
#2210507
12/09/16 03:25 AM
12/09/16 03:25 AM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
A local Mopar guy races a Duster in Super Stock with a 340 and a late full size Dodge truck with a 360 Magnum in Stock. The Duster runs in the 10s and the truck runs high 11s and that is with the stock though tuned FI system. His name is Kelly Thomas and he is a serious racer in NHRA Division 6.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Crabra]
#2210557
12/09/16 10:37 AM
12/09/16 10:37 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
Price is sightly steep but might be ok depending on your area. I have a 5.9 in my '74 Duster, 13.0's with 3.55's out back and 3675 lbs with driver. With the 3.90's being installed later this winter it should be in the 12's all day long. Very mild motor. Used roller cam from Dakota forum, dual plain intake, 750 AFB, 1 3/4 headers and 1.88 heads from Enginequest.
"I think its got a hemi"
[Re: Crabra]
#2211117
12/10/16 10:02 AM
12/10/16 10:02 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
There used to be some guys on here that made a jig to drill magnum heads with LA patterns, for better intake selection. They used to rent them out to other members on here, but don't remember who made them.
[image][/image]
[Re: Crabra]
#2211177
12/10/16 01:09 PM
12/10/16 01:09 PM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
I have a junkyard 5.9 in my 3300lb Dakota that goes 11.70s with ease. It started out as a 160k motor so I took it apart to inspect it. Just needed rod bearings but the cylinders still looked great! So I dingleberry honed it and put in a set of std. KB107 pistons and a Hughes 234/238 hyd. roller cam. For heads, I used a pair of MP iron R/Ts w/ 2.02 in.valves that were lightly ported. Topped it off with an Indy single plane and an 850 carb. I'm happy with this engine so far and I believe it has quite abit more potential as it is. It would be hard to convince me to build an LA engine over a magnum in a less than 450hp application. The salvage yards are littered with these great little engines that make exceptional power for little money. Not to mention they are reliable as hell and dont leak oil.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: jeff1974]
#2211811
12/11/16 02:08 PM
12/11/16 02:08 PM
Posts: 4,987 new jersey usa
11secdart
new jersey usa
The crate short blocks are great, I put my W2 heads on one with a 590 lift mechanical cam and went 10.70s with it in my Dart, after spinning a bearing we upgraded to a forged crank, Scat rods and JE pistons and I Went 10.40 a best , 549 hp and 450 tq on the dyno. I just took it out last year to put in my 408 and it still ran strong after over 1,000 runs. I wish M/P still offered them, I bought a used 5.9 Magnum short block on here a few years ago to do for my D150 some day.
