Re: Limiting wheel stand while useing Caltracs, HOW?
[Re: Diego_Ted]
#221011
02/11/09 11:05 AM
02/11/09 11:05 AM
Posts: 3,456 Out West
408strokerdart
Out West
I know it's kind of an oxymoron but right now footbraking "El Picoso" could pull the front hoops anywhere from 6" to about 20". I am putting a transbrake and don't want to find the car on the bumper. What is the best way to limit the front end with out unloading the rear?
thx Ted
Adjustable front shocks / front travel limiter. This is how I am going to attempt it. If that doesn't work, I will be pulling timing out of it with the programmable digital 7 or putting a launch program into it for control.
[Re: RADAMX]
#221013
02/11/09 01:03 PM
02/11/09 01:03 PM
Posts: 12,008 Finally a HUSKER again
Moparnut426
Our charger did nasy wheelies with the tortion bars, and stock front ewnd under it, when it was switched to a tube K member, and coilovers with a limiting strap that helped a bunch. http://www.youtube.com/watch?v=y4vjllW0rjY this is before the new front end. http://www.youtube.com/watch?v=H96AJ0cfgpY&feature=channel_pagethis is after I believe. This was before we owned it, but Blake told us every trick on the car, now its on its way back to a stock apearing street car. We sold the 588 we had for it, and tha cage is gone, some guys hate me for it, but its a real R/T SE 440 car. And our finances arent in there anymore to keep it as a race car.
[Re: Cab_Burge]
#221016
02/11/09 03:03 PM
02/11/09 03:03 PM
Posts: 2,864 IN
Irun5snd8th
IN
Its been my experience that a good set of double adjustable front shocks will do wonders for giving you control of the wheelies.
AFCO, Rons Fuel Injection sponsored Dodge Challenger
Mention Street Lethal Motorsports
[Re: Irun5snd8th]
#221017
02/11/09 03:45 PM
02/11/09 03:45 PM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: 66coronet]
#221020
02/11/09 04:35 PM
02/11/09 04:35 PM
Posts: 1,217 Wellington, FL
cudabunch
Wellington, FL
There are many ways to do it. 1.adjust the Cal-Tracs 2.adjust the rear shocks for less hit 3.Get Afco shocks on the front-adjust it out 4.limiters on the front 5.Dont dead hook and go faster-air pressure
