Blown, more power from less stroke? #2209787
12/08/16 01:16 AM
12/08/16 01:16 AM
Parts unknown
590 Challenger Offline OP
Parts unknown
I'm running a 588 cube Hemi on alky, 4.50 bore 4 5/8 stroke. I have been told it would more power if I down size to a 526, 4.50 bore 4 1/8 stroke. It was explained the extra boost would be made and RPM would go higher, this would crank it up. Is this something I should consider doing?
Re: Blown, more power from less stroke? [Re: 590 Challenger] #2209840
12/08/16 02:30 AM
12/08/16 02:30 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Theoretically yes. More RPM, more HP. You may be limiting your HP by your rpm limits of that big stroke 588. But you should be able to make up for it with your boost and lower rpm if your current suspension and tire combo can handle it . What is your RPM band right now?
Re: Blown, more power from less stroke? [Re: 590 Challenger] #2209842
12/08/16 02:36 AM
12/08/16 02:36 AM
Parts unknown
Parts unknown
I've been keeping the limit at 7200, Launch at 3200
Re: Blown, more power from less stroke? [Re: 590 Challenger] #2209998
12/08/16 12:38 PM
12/08/16 12:38 PM
New York
polyspheric Offline
polyspheric  Offline
New York
What it looks like: RPM increase matches stroke length decrease.
4.625" / 4.125" = +12.1%
But it doesn't - RPM limit is inertial load on the rods, which only goes up inverse to the square root of the stroke change.
The product of shorter stroke X higher rpm at the same stress level is lower than the original.
1.12^.5 = +5.9%
The blower's pumping loss also goes up quickly.
Remember: boost pressure is bad, it's resistance to intake flow.
Could it work?
Sure, it's your (a lot of) money.
Boffin Emeritus
Re: Blown, more power from less stroke? [Re: 590 Challenger] #2210051
12/08/16 02:22 PM
12/08/16 02:22 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
It just depends how big the blower is. If it's big enough to feed a big motor, then it'll make more power with the motor big. If the blower is too small, you could keep it in a better efficiency range by making the motor smaller.
Re: Blown, more power from less stroke? [Re: dizuster] #2210109
12/08/16 04:02 PM
12/08/16 04:02 PM
ca
brownout Offline
brownout  Offline
ca
What is the overdrive now?
And how much boost at 7200?
Just curious where it is at now.
Re: Blown, more power from less stroke? [Re: 590 Challenger] #2210121
12/08/16 04:24 PM
12/08/16 04:24 PM
Parts unknown
Parts unknown
50% over, 31lbs, I'm really not sure if my old blower really has that much more to give
Re: Blown, more power from less stroke? [Re: 590 Challenger] #2210137
12/08/16 04:46 PM
12/08/16 04:46 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
This is a matter of piston speed with that large of crank. Too much makes the motor less efficient and limits RPM which is important with a blower. There does seem to be a sweet spot and I believe it's about 526 cubes with a 4.15 crank. My present motor has a 3.75 crank and 470 cubes and it makes a whole lot of power with twin 98's.
Re: Blown, more power from less stroke? [Re: BobR] #2210139
12/08/16 04:47 PM
12/08/16 04:47 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Our new motor has the 4.15 crank and 521 cubes. Not so much for power but for quicker spooling.
Re: Blown, more power from less stroke? [Re: 590 Challenger] #2210294
12/08/16 09:06 PM
12/08/16 09:06 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
When you get into the 50% use things are not as happy as they can be unless the blower is top of the line and I am not sure what that is now days.
Re: Blown, more power from less stroke? [Re: 590 Challenger] #2210325
12/08/16 09:50 PM
12/08/16 09:50 PM
Superfreak
Superfreak
Chris Cadetto went from a 588" down to a 526" and he said he makes a lot more power and his et times show it.
Re: Blown, more power from less stroke? [Re: ] #2210407
12/09/16 12:01 AM
12/09/16 12:01 AM
Parts unknown
Parts unknown
Yes he did, but his has really evolved through the years into a Monster, way more than cubes changed and I love his 1871
Re: Blown, more power from less stroke? [Re: 590 Challenger] #2210408
12/09/16 12:05 AM
12/09/16 12:05 AM
Parts unknown
Parts unknown
I have heard the sweet spot is 526-540 range, I didn't know if anyone down sized to make more power and how it worked, mine worked great as a torque monster on the street
Re: Blown, more power from less stroke? [Re: 590 Challenger] #2210530
12/09/16 04:58 AM
12/09/16 04:58 AM
One thing to keep in mind when compressing air, it takes power to compress it. The higher the pressure with the same size compressor the more power it takes to make that pressure. A bigger compressor turned at a slower speed that makes the same pressure as the smaller compressor will probably go faster in a race car with good traction work grin
Another thing to remember is compressing air makes heat, hot air expands and take up more space than cooler air does shruggy
I can't remember the HP lost due to changing the manifold inlet temps from. 130F to 190F by letting the motor warm up more before making the two pulls with no other changes, it was more than I thought it would be puke shock
Re: Blown, more power from less stroke? [Re: 590 Challenger] #2210559
12/09/16 10:39 AM
12/09/16 10:39 AM
Parts unknown
Parts unknown
Sounds like it might help but not enough to bother right now. This guy is selling a sweet billet 4 1/8 crank, I'll probably buy it and throw it into inventory and save it for the next major rebuild
