Re: Blown, more power from less stroke?
[Re: 590 Challenger]
#2209998
12/08/16 12:38 PM
12/08/16 12:38 PM
Posts: 4,209 New York
polyspheric
New York
What it looks like: RPM increase matches stroke length decrease. 4.625" / 4.125" = +12.1% But it doesn't - RPM limit is inertial load on the rods, which only goes up inverse to the square root of the stroke change. The product of shorter stroke X higher rpm at the same stress level is lower than the original. 1.12^.5 = +5.9% The blower's pumping loss also goes up quickly. Remember: boost pressure is bad, it's resistance to intake flow.
Could it work? Sure, it's your (a lot of) money.
Boffin Emeritus
#2210294
12/08/16 09:06 PM
12/08/16 09:06 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
50% over, 31lbs, I'm really not sure if my old blower really has that much more to give When you get into the 50% use things are not as happy as they can be unless the blower is top of the line and I am not sure what that is now days.
#2210325
12/08/16 09:50 PM
12/08/16 09:50 PM
Superfreak
Superfreak
Chris Cadetto went from a 588" down to a 526" and he said he makes a lot more power and his et times show it.
[Re: ]
#2210407
12/09/16 12:01 AM
12/09/16 12:01 AM
Posts: 493 Parts unknown
590 Challenger
Parts unknown
Chris Cadetto went from a 588" down to a 526" and he said he makes a lot more power and his et times show it. Yes he did, but his has really evolved through the years into a Monster, way more than cubes changed and I love his 1871
#2210530
12/09/16 04:58 AM
12/09/16 04:58 AM
Posts: 43,227 Bend,OR USA
Cab_Burge
