New Heads #2208926
12/06/16 08:28 PM
12/06/16 08:28 PM
usa,pa
jkwedge540 Offline OP
usa,pa
Indy and Goodwin have new heads coming out. Anyone know anything about them?
Re: New Heads [Re: jkwedge540] #2208946
12/06/16 09:17 PM
12/06/16 09:17 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Got a link? Goodwin is know for Hemi's, and Indy makes both Hemi's and Wedge's....What are you looking for?
Re: New Heads [Re: Dragula] #2208956
12/06/16 09:37 PM
12/06/16 09:37 PM
usa,pa
usa,pa
No link. Looking for anything new wedge or Hemi.
Re: New Heads [Re: jkwedge540] #2208968
12/06/16 09:57 PM
12/06/16 09:57 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
It is their version of the Indy 600-13 head. Been out for a bit. From what I've seen they seem like very good pieces. Was developed for some of the NA classes to be legal without a weight hit..I'm sure the man behind it will chime in and tell you more.
Re: New Heads [Re: jkwedge540] #2208969
12/06/16 09:58 PM
12/06/16 09:58 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
You looking for hustlinhoosier stuff ? Lol it's one off stuff, don't know if it's being mass produced . Contact chuck at best machine if you want info.
....BAD A$$ STREET CAR.....
Re: New Heads [Re: jkwedge540] #2208971
12/06/16 09:59 PM
12/06/16 09:59 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Hustlin Hoosier can tell you everything you want to know. Search his posts, it's kind of his brainchild. They make POWER
Re: New Heads [Re: jkwedge540] #2209130
12/07/16 02:14 AM
12/07/16 02:14 AM
hustlin hoosier Offline
The new head is for 4.840 bore space blocks "600-13X". We raced the prototype head last year. It was welded up and full of epoxy and used the old exhaust port as the 600-13X head. After seeing the performance gain Russ at Indy cylinder head modified the core boxes adding material to the casting to facilitate the new port. That was completed last year. We purchased 2 sets of heads and sent them up to Goodwin for porting. At that time Todd advised me that there was no way the old exhaust port would keep up with the intake port. So again with a lot of welding and some inserts welded in Todd raised the exhaust port. The new head complete with new exhaust port are in the machining center being ported as we speak. Hopefully Indy will modify the core box again to change the exhaust port.
Casting are in stock at Indy now. These castings support the new intake port but utilize the old exhaust port. Which is the same head we raced last year. That head made 30 more hp than our previous engine and it was 67 inches smaller. The test engine this year will be a big engine again "632ci". I think it will make 125 HP more than the 632 inch motors we have built in the past. Conservatively the intake flows well over 515 cfm.
Re: New Heads [Re: jkwedge540] #2209137
12/07/16 02:22 AM
12/07/16 02:22 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
Any pics ?
1.39 9.85 - 137 mph
Re: New Heads [Re: hustlin hoosier] #2209190
12/07/16 09:30 AM
12/07/16 09:30 AM
usa,pa
usa,pa
Thanks for the up date.
Re: New Heads [Re: Ari440] #2209726
12/08/16 12:00 AM
12/08/16 12:00 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Originally Posted By Ari440
Any pics ?
X2...
Re: New Heads [Re: jkwedge540] #2209785
12/08/16 01:14 AM
12/08/16 01:14 AM
Todd will have a head with him at pri with 2 cylinders done. We need to discuss a couple issues before finishing. Pictures shortly after pri.
Re: New Heads [Re: jkwedge540] #2210248
12/08/16 07:58 PM
12/08/16 07:58 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Want
Re: New Heads [Re: BradH] #2211800
12/11/16 01:38 PM
12/11/16 01:38 PM
I saw the new head for the first time since we dropped it off. Only 2 ports were done and they look great. Todd did not have time to flow before PRI. It will be on the bench next week. Goodwin has done an unbelievable job on this project. This is a very robust piece, far stronger than any of our older stuff.
Re: New Heads [Re: hustlin hoosier] #2237653
01/20/17 12:52 AM
01/20/17 12:52 AM
New heads are finally done. No epoxy all alum 517 @ 1.00 intake 334 on the exhaust, and a new chamber. We have added .125 between the exhaust and intake. They should be robust enough to boost. The new na motor will debut at the Atlanta NMCA race. The intake is as it was last year the exhaust is over 50 cfm better. 1300+ na or bust!
Re: New Heads [Re: hustlin hoosier] #2237697
01/20/17 01:58 AM
01/20/17 01:58 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Awesome Mike. Can't wait to hear the results of your efforts up
Re: New Heads [Re: jkwedge540] #2237775
01/20/17 11:14 AM
01/20/17 11:14 AM
an8sec70cuda Offline
Pics?
CHIP
'06 GMC 2500HD LBZ Duramax
Re: New Heads [Re: BradH] #2238135
01/20/17 10:01 PM
01/20/17 10:01 PM
I am picking up the heads sunday pictures on Monday.
Re: New Heads [Re: jkwedge540] #2243045
01/28/17 09:44 PM
01/28/17 09:44 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
Any pictures??? bump
Re: New Heads [Re: Diablo] #2243050
01/28/17 09:55 PM
01/28/17 09:55 PM
Idabel,Oklahoma
Gary Robbins Offline
Idabel,Oklahoma
Re: New Heads [Re: Gary Robbins] #2243108
01/28/17 11:22 PM
01/28/17 11:22 PM
7second dart got the first set , his engine should be done in about a month. Good luck Clinton.
