Re: 340 production windage tray
[Re: jeff1974]
#2207506
12/04/16 12:42 PM
12/04/16 12:42 PM
RapidRobert
just from my std stroke SB builds I would be inclined to opinionate no as is but can be easily rectified. You can space it further away from sitting flush on the flats of those 4 bolts. I think there will still be plenty of space between the tray and the sump. best plan as you know would be to mockup but I think you will be OK
[Re: jeff1974]
#2207765
12/04/16 08:52 PM
12/04/16 08:52 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The MP windage tray is a fits all LA setup, so the mounting holes are oval and it clears the 360 crank as well. Uses longer main bolts with extra washers to fit the longer main bolts into the short main bolts applications.
the production tray is a more specific fit setup but you should be able to use longer mounting bolts and washers to shim the tray. Don't think I would shim the main bolts though.
[Re: jeff1974]
#2207859
12/04/16 11:26 PM
12/04/16 11:26 PM
Supercuda
About to go away
About to go away
up yours
The Milodon windage tray attaching kit uses studs and two nuts (per stud, one above and one below the tray) to adjust height, an option to consider.
