Yes, that's what I meant. I want to leave the cap screws and washers as they are, and use longer, shimmed tray mounting screws to lower the tray until clearance is sufficient. The tray mounting screws just look like half inch long, 1/4x20 hex head screws, by using longer screws and washers, the production tray should be made to clear the stroker crank I hope.
