Automatic Transmission Flywheels
#2207381
12/04/16 02:44 AM
12/04/16 02:44 AM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
For 5.7 motors, is the automatic transmission flywheel the same for a 545RFE and the Nag1 transmission?
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
Re: Automatic Transmission Flywheels
[Re: AZ_A12_BEE]
#2208466
12/06/16 12:13 AM
12/06/16 12:13 AM
Posts: 8,494 Candler,NC / Myrtle Beach, SC
JDMopar
Nope, they are different. You may also need to remove the ring in the rear of the crank, where the converter snout goes into the crank. My 5.7 had a NAG1 originally, and the 545 converter snout is bigger. It's easy to get out. I cut into it with a carbide bit in the die grinder till it was almost in two, then knocked it out with a chisel and hammer. The part number on my flex plate is 04736604AA, but check to see if it's the same for a 6.4.
[Re: JDMopar]
#2209042
12/06/16 11:38 PM
12/06/16 11:38 PM
AZ_A12_BEE
Dreaming of the 808
Nope, they are different. You may also need to remove the ring in the rear of the crank, where the converter snout goes into the crank. My 5.7 had a NAG1 originally, and the 545 converter snout is bigger. It's easy to get out. I cut into it with a carbide bit in the die grinder till it was almost in two, then knocked it out with a chisel and hammer. The part number on my flex plate is 04736604AA, but check to see if it's the same for a 6.4. JD, thanks, I got one on order from my Dodge dealer for $76 with my discount. And yes, I do need to remove that ring so my converter fits
37 Plymouth PU
