T/A Rear end option 3.91 on Fender Tag? #2206991
12/03/16 03:31 PM
12/03/16 03:31 PM
Vancouver, WA
Cuda Cody Offline OP
Vancouver, WA
One of my T/A's has 3.91 gears in it and I do not have the buildsheet. The fender tag does not have any Axle package listed on it so I'm not sure if they are the original gear. It's a numbers matching engine and trans and the rear axle looks original.
Would a factory 3.91 T/A have an axle package listed on the tag?
1970 Challenger T/A 4-Speed
1970 Challenger T/A Auto
1970 Challenger R/T Auto
1970 Challenger Auto
1970 Challenger RT 440+6 4-Speed
1970 Hemi Challenger 4-Speed
1970 Hemi Cuda 4-Speed
1971 Cuda Auto
1971 Cuda 4-Speed
LOOKING to BUY 1970 & 1971 E Body J, V and R Code project cars
Re: T/A Rear end option 3.91 on Fender Tag? [Re: Cuda Cody] #2207001
12/03/16 03:50 PM
12/03/16 03:50 PM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
I don't believe it would be on the fender tag. Is the axle ratio tag still on a stud? If the gears were changed at some point most guys didn't put the tag back on.
Re: T/A Rear end option 3.91 on Fender Tag? [Re: Cuda Cody] #2207029
12/03/16 04:50 PM
12/03/16 04:50 PM
Vancouver, WA
Vancouver, WA
It's on the tag that is bolted to the 8 3/4, but I have not opened it up or counted the turns to confirm. For some reason I thought T/A's were 3.55 gears?
1971 Cuda Auto
1971 Cuda 4-Speed
Re: T/A Rear end option 3.91 on Fender Tag? [Re: Cuda Cody] #2207041
12/03/16 05:11 PM
12/03/16 05:11 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
Not on fender tag. Unless you have the build sheet or window sticker you can't tell for sure if you got that ratio.
3.55 was standard and 3.91 was optional on T/As and AARs.
Sorry to hijack, but on a similar subject, my T/A is a 3.91 car, I had a repro ratio tag, but it doesn't look like the resto shop installed it on my rear, nor gave me back my tag. I have to buy another, but which stud on the mounting does this tag go on?
Check out my car show and cruise photo albums here: Show Pics
Seeking info on a Mr Norms sold T/A VIN JH23J0B308737. Does it still exist?
Re: T/A Rear end option 3.91 on Fender Tag? [Re: Cuda Cody] #2207134
12/03/16 08:41 PM
12/03/16 08:41 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
Here's the tag on my 71 Cuda.Hope this helps.
Re: T/A Rear end option 3.91 on Fender Tag? [Re: Cuda Cody] #2207182
12/03/16 09:32 PM
12/03/16 09:32 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Does an axle package code show on your other TAs?
Re: T/A Rear end option 3.91 on Fender Tag? [Re: Cuda Cody] #2207201
12/03/16 10:02 PM
12/03/16 10:02 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: T/A Rear end option 3.91 on Fender Tag? [Re: Alaskan_TA] #2207211
12/03/16 10:12 PM
12/03/16 10:12 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
3.91 axle ratio tag on a Challenger T/A (circled)
Re: T/A Rear end option 3.91 on Fender Tag? [Re: Cuda Cody] #2207233
12/03/16 10:28 PM
12/03/16 10:28 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
For the 402 Challenger T/As that I have broadcast sheet information for with legible axle codes as of today;
3.55 ratio (D56) 258 known so far.
3.91 ratio (D57) 144 known so far.
Numbers can only go up as more broadcast sheet data comes in of course.
Re: T/A Rear end option 3.91 on Fender Tag? [Re: Cuda Cody] #2207251
12/03/16 10:47 PM
12/03/16 10:47 PM
Vancouver, WA
Vancouver, WA
Thanks guys! And you the MAN Barry!!!!!
1971 Cuda Auto
1971 Cuda 4-Speed
Re: T/A Rear end option 3.91 on Fender Tag? [Re: Cuda Cody] #2207369
12/04/16 02:20 AM
12/04/16 02:20 AM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
Would the 3.91's come standard with the max cooling package by chance? Or was that optional?
On a side note, A friend of mine has an aar cuda that he swears has the original 3.23s it it.. was it possible for this? I knows there are a few 'standard' differences between aar's and ta's...
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: T/A Rear end option 3.91 on Fender Tag? [Re: Cuda Cody] #2207375
12/04/16 02:31 AM
12/04/16 02:31 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Same gear ratios for AARs as T/As, 3.55 or 3.91 only.
Re: T/A Rear end option 3.91 on Fender Tag? [Re: mopars_1] #2207390
12/04/16 03:11 AM
12/04/16 03:11 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
there was NO orderable "MAX COOLING" on ANY US spec. vehicle (it was part of a "PACKAGE")
the STANDARD cooling system was the same on all A53 "TRANS AM" e-bodies:
2998 974 radiator
2863 216 7-blade fan
2806 070 torque drive unit
the A31 (3.91:1) used a larger capacity "MAX COOLING" radiator 2998 949 with the 340 4bbl (A/C was not available)
