B body upper control arms #2201080
11/23/16 10:31 AM
11/23/16 10:31 AM
NY
Beep Beep Offline OP
NY
I am thinking of replacing my upper control arms with tubular control arms.
I am currently running the factory uppers with offset bushings.
Since I am doing a complete restoration and redoing all suspension components I figured I would look into a tubular setup.
Any advantages over the factory setup? I was looking at Qa1 or Firm Feel.
I am also going to be boxing my lower control arms and Firm Feel is redoing my K member.
Re: B body upper control arms [Re: Beep Beep] #2201443
11/23/16 09:48 PM
11/23/16 09:48 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Firm Feel, if you plan on any daily driving duty skip anything with spherical rod ends, they don't last on the street and anyone that says they do, really doesn't drive it much...
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: B body upper control arms [Re: Beep Beep] #2202207
11/25/16 03:14 AM
11/25/16 03:14 AM
NY
NY
Thanks astjp2.
Re: B body upper control arms [Re: Beep Beep] #2202227
11/25/16 05:23 AM
11/25/16 05:23 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
If you are looking to gain more caster and negative camber, you can still get there with the stock UCAs in place.
Some have noticed that with the design of our cars, it is hard to get both negative camber and a decent amount of caster. I was able to get about 4.5 degrees of caster with just the offset UCA bushings. I have seen where others could only get 2 degrees.
Several sources sell hardened spacers/washers that get placed between the steering knuckle and lower ball joint/steering arm. This effectively results in 2 degrees of NEG camber. With these, you can then dial out some of the NEG camber to gain caster.
I followed the advice of many people for my 70 Charger. I did box in the lower control arms, I used offset UCA bushings, reinforced the steering box mounts in the K member and welded in the seams. I made my own 3x3" frame connectors and torque boxes too. The car feels solid and just soaks up rough roads like a newer car.
Re: B body upper control arms [Re: Beep Beep] #2202282
11/25/16 12:34 PM
11/25/16 12:34 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Hotchkis is getting my money for UCAs, today.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: B body upper control arms [Re: GoodysGotaCuda] #2203752
11/28/16 03:29 AM
11/28/16 03:29 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
have fun and let us know how many miles you get before you start replacing for ends....
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: B body upper control arms [Re: GoodysGotaCuda] #2203757
11/28/16 03:41 AM
11/28/16 03:41 AM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Make sure and get the rubber booties to protect the ends.
Re: B body upper control arms [Re: Beep Beep] #2203762
11/28/16 03:59 AM
11/28/16 03:59 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
SPC from Bergmann.
Mopar to the bone!!!
Re: B body upper control arms [Re: 72Swinger] #2203923
11/28/16 05:10 PM
11/28/16 05:10 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
The SPC design offers the most caster/camber variable adjustment and WITHOUT having to relocate the mounting point as the Hotchkis design requires (which is not legal in SCCA Solo AX class E/SP; if you someday run SCCA CAM class, then it doesn't matter what you install or how its done).
Re: B body upper control arms [Re: Beep Beep] #2203977
11/28/16 07:20 PM
11/28/16 07:20 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Also Mitch, they use Delrin bushings and no heims.
Re: B body upper control arms [Re: 72Swinger] #2204531
11/29/16 04:32 PM
11/29/16 04:32 PM
Mopar Mitch Offline
Mopar Mitch  Offline
DELRIN bushings are long-lasting (that's what I have for my UCAs now), and will be installing them into my LCAs (rcvd from Firm Feel).
Re: B body upper control arms [Re: Beep Beep] #2205178
11/30/16 12:53 PM
11/30/16 12:53 PM
Mountain View, CA
68rrunner Offline
68rrunner  Offline
Mountain View, CA
Is the Delrin pliable enough for the LCA bushing? That stuff is pretty hard compared to Poly and rubber. We make them at the shop from time to time for the race cars, but never on anything that doesn't travel on a fixed, linear arc.
Re: B body upper control arms [Re: Beep Beep] #2205268
11/30/16 03:19 PM
11/30/16 03:19 PM
Chicago, Illinois
Devil Offline
Devil  Offline
Chicago, Illinois
Where did you guys get the delrin bushing for the UCA from? I'm looking at a set, probably firm feel, for my 71.
I was thinking about having a Delrin/Aluminum setup made for it.
Re: B body upper control arms [Re: Devil] #2205940
12/01/16 04:55 PM
12/01/16 04:55 PM
Mopar Mitch Offline
Mopar Mitch  Offline
Devil -- Global West (Calif) made the Delrin UCA bushings for me a long time ago (~30+ years ago)... still a-ok!... and greasable.... not sure if GW still offers them or would make them for you.
Re: B body upper control arms [Re: Beep Beep] #2205997
12/01/16 06:48 PM
12/01/16 06:48 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Bergman offers delrin lowers, although they are easy enough to whip up on a lathe with some material, as is bronze.
http://www.bergmanautocraft.com/products.php?cat=2
Re: B body upper control arms [Re: Beep Beep] #2206235
12/02/16 01:00 AM
12/02/16 01:00 AM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
Delrin is an excellent material for this application. I believe the FF bushings are nylon not delrin.
Re: B body upper control arms [Re: Beep Beep] #2206239
12/02/16 01:05 AM
12/02/16 01:05 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I tried Pete, cant convince these guys to just buy your damn UCA's.
Re: B body upper control arms [Re: 72Swinger] #2206319
12/02/16 03:08 AM
12/02/16 03:08 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
I wouldn't use Heim joints in anything that saw street time.
Harshness, vibration and early failure? Yeah...Where do I sign???
Re: B body upper control arms [Re: Beep Beep] #2206361
12/02/16 09:25 AM
12/02/16 09:25 AM
Long Island, NY USA
Long Island, NY USA
Different strokes for different folks.
Re: B body upper control arms [Re: Beep Beep] #2206771
12/03/16 01:26 AM
12/03/16 01:26 AM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
Once you get the SPC upper control arms you will never want to use anything else again. I mean why would you not want the ones that offer the most adjustment range and are the simplest to change settings on....
A new iron curtain drawn across the 49th parallel
