hemi roller cam #2201868
11/24/16 03:35 PM
11/24/16 03:35 PM
Z
zbc51 Offline OP
zbc51  Offline OP
Z
I'm starting to rebuild a 472" crate hemi. I'm looking for some sugestions for a new hydraulic roller cam. This motor is being built for the street.
thx
Re: hemi roller cam [Re: zbc51] #2201903
11/24/16 04:21 PM
11/24/16 04:21 PM
Is this a stick shift or automatic tranny car? What size and weight car and what rear gear, converter size, tire height? How do you want the motor exhaust to sound at idle and how hard and how high on the RPM do want the motor to make good power to?
Lots of things can and will influence getting the cam correct for you work
Re: hemi roller cam [Re: zbc51] #2202014
11/24/16 08:57 PM
11/24/16 08:57 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Crane hr254, hopefully you are going at least 10.5 to 1 compression.
Make sure to mock it up andcheck pushrod to block clearance before you final clean the block. You will need to do some grinding.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: hemi roller cam [Re: zbc51] #2202112
11/24/16 11:28 PM
11/24/16 11:28 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Call any one of the cam grinders and give them your specs along with preferences and let them recommend a grind.
Rich Nedbal would probably be my first choice. He is a member here, reps Comp Cams, and wrote the book on building Hemis.
Master, again and still
Re: hemi roller cam [Re: zbc51] #2202130
11/25/16 12:01 AM
11/25/16 12:01 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Fwiw, I'm running a 475", ported Stage V head, Stage V intake, 4 spd, 3.54, street only, & this cam. Switched to solid roller "lifters" though during the build. Real happy with the torque above idle.
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=756&sb=0
Re: hemi roller cam [Re: zbc51] #2202132
11/25/16 12:02 AM
11/25/16 12:02 AM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Roller lifters are tall which aggravates the pushrod angle causing the pushrods to hit the block and heads so be ready to do some mocking up, grinding, and then mock up again.
I can design you a cam if you want, but we'd have to talk first.
Re: hemi roller cam [Re: zbc51] #2202161
11/25/16 12:51 AM
11/25/16 12:51 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Stick with a mechanical roller with pushrod oiling, that's what Rich recommended for my 572 several years ago, I just hope to be able to drive the car before gas becomes a thing of the past. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: hemi roller cam [Re: astjp2] #2202338
11/25/16 02:14 PM
11/25/16 02:14 PM
the Netherlands
dutchrunner Offline
dutchrunner  Offline
the Netherlands
Yep. Go with Rich's cams.
I have his EFIroller cam in my 572Hemi and it's great.
1969 Roadrunner Sox&Martin tribute with 572Hemi and F&B performance Six-Pack XFI2.0 injection.
Re: hemi roller cam [Re: zbc51] #2202450
11/25/16 05:08 PM
11/25/16 05:08 PM
Z
zbc51 Offline OP
zbc51  Offline OP
Z
Thx, guys.
The car is a '70 challenger with an auto.
I'm already running an electric vacuum pump.
It's a 472"crate hemi. I want to bump the compression up to 10.5-11:1. It has iron factory heads.
Which roller lifter are you guys using?
Re: hemi roller cam [Re: zbc51] #2202517
11/25/16 07:19 PM
11/25/16 07:19 PM
Toronto,Canada
W
wkeggenhoff Offline
wkeggenhoff  Offline
W
Toronto,Canada
I run an FHO custom solid roller. Tim Banning said for hyd roller motor would have to come apart for machining for clearance(believe push rod and lifters.
Had 2 hyd lifters blow apart due to acute angle on a couple of push rods.
He talked me going to soldi lifters asked him about street use and he said not an issue he has been using on street for years. He did say though don't cheap out on quality of lifters. I have comps not sure model /
Went with his suggestion on specs. Its 600" lift and 250 duration
Street driven,528" hemi 3:73 gear 5spd. Believe he told me it will work with power brakes as well.
He says this cam will support 800hp
Worked great 2 years so far, revs to almost 7000rpm without an issue and get there quickly
good luck
69 dodge charger,528 Hemi,Keisler TKO 5spd, Mosier 60 rear end
Re: hemi roller cam [Re: wkeggenhoff] #2202839
11/26/16 02:25 PM
11/26/16 02:25 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Crane 66550-16 lifters and the cam is a mild 248@.050 with .628 lift and a 112 lsa, Rich's book has similar specs and Chase Knight used those specs to find a Crane grind that was close to match my 572. I also used comp 959 springs and .060 lash caps with Dvorak stands, Dichelles shafts and StageV rockers, expensive but I now don't have to worry. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
