1971 RR won't start, need advice!!! #2198544
11/18/16 04:17 PM
11/18/16 04:17 PM
NEW JERSEY
moparfury1970 Offline OP
NEW JERSEY
Hey guys, so here's the scoop. Car was running strong just a couple days ago and I go to start it and it will not fire. I checked the ignition module, voltage regulator, ballast resistor, pickup, and ignition coil. All check good. I have an electric choke that barely opens since this problem occurred. I decided to swap the ignition coil out with a brand new one and when I did, the car started by ran rough with the electric choke not budging. I went under the dash and wiggled some wires around and it started again, but ran very rough. Shut the car off and tried starting again, nothing. My pal said it might be a bad connection underneath the dash. Any advice on what is going on? What should I be looking for? I have a strong suspicion it is some under the dash. By the way, all fuses checked good.
Re: 1971 RR won't start, need advice!!! [Re: moparfury1970] #2198597
11/18/16 06:38 PM
11/18/16 06:38 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Check the bulkhead plug for burnt or corroded wires. That is one place where the problems occur.
Re: 1971 RR won't start, need advice!!! [Re: stumpy] #2198604
11/18/16 06:53 PM
11/18/16 06:53 PM
what Stump said, clean the female terminals with a spare male terminal from your parts stash (or a NAPA 725147-99 cents) and the male ones with a small metal bristle brush then spray em with brake kleen to clean and dry em & some Koppercoat or similar to enhance conductivity/resist corrosion if available/desired but not required
Re: 1971 RR won't start, need advice!!! [Re: moparfury1970] #2198613
11/18/16 07:25 PM
11/18/16 07:25 PM
NEW JERSEY
NEW JERSEY
will try it guys thank you
Re: 1971 RR won't start, need advice!!! [Re: moparfury1970] #2198614
11/18/16 07:28 PM
11/18/16 07:28 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
If you think it is a bad connection, you can just connect a jumper wire from the battery to the +12 volt side of the ballast resistor.
Re: 1971 RR won't start, need advice!!! [Re: 451Mopar] #2198657
11/18/16 09:46 PM
11/18/16 09:46 PM
NEW JERSEY
NEW JERSEY
Seriously? Would that do it?
Re: 1971 RR won't start, need advice!!! [Re: moparfury1970] #2198659
11/18/16 09:52 PM
11/18/16 09:52 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
That would allow you to troubleshoot a bad connection. You would have to remove the jumper wire to kill the engine since it is by-passing the key power.
Re: 1971 RR won't start, need advice!!! [Re: moparfury1970] #2198662
11/18/16 09:55 PM
11/18/16 09:55 PM
Would that do it?
that would confirm (if it starts with that bypass) that all is good in the 'hood ex for an open from the ign2 terminal on the ign switch to/thru bulk & on to the coil positive primary (the brown wire circuit). If it starts with that then shut it off immediately cuz as you know the coil doesn't like full voltage for an extended period of time. Most all the time wires go bad at the terminals/connections so the bulkhead is a primary first place to work on. I would seperate the halves & jump across the main feed where the fusible link is then have a helper hold the key to start & see if the brown wire brass terminal on the back half is hot. this will tell you if the problem is inside (ign sw or its connector) or bulkhead or downstream from bulkhead to the coil. grab your meter
Re: 1971 RR won't start, need advice!!! [Re: moparfury1970] #2198730
11/18/16 11:38 PM
11/18/16 11:38 PM
NEW JERSEY
NEW JERSEY
thanks gents. I will update you with the progress!
Re: 1971 RR won't start, need advice!!! [Re: moparfury1970] #2198827
11/19/16 06:21 AM
11/19/16 06:21 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Ignition switch to dash harness connector. Bulkhead in the running as a candidate.
Re: 1971 RR won't start, need advice!!! [Re: moparfury1970] #2198901
11/19/16 01:11 PM
11/19/16 01:11 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Yes, check the ignition switch wires and wires to the firewall. I had a pinched wire in my column and it melted a wire. Look for signs of melted tape or wiring.
Re: 1971 RR won't start, need advice!!! [Re: moparfury1970] #2199044
11/19/16 06:13 PM
11/19/16 06:13 PM
NEW JERSEY
NEW JERSEY
cleaned the bulkhead head and car fired right up, now I'm just dealing it idling too low.
