block clearence for a 440 to 500 cid,
#219807
02/10/09 10:27 AM
02/10/09 10:27 AM
Posts: 189 long island new york
kingdust
I have built a couple of 440s but never stroked one to 500 inches,how much block notching is required? I'm thinking not to much.any other small things to look for besides the oiling system? Thanks in advance for any help. MARK.
LIFE IS A LESSON,YOU LEARN IT WHEN YOUR THROUGH!
Re: block clearence for a 440 to 500 cid,
[Re: kingdust]
#219810
02/10/09 02:00 PM
02/10/09 02:00 PM
Posts: 160 Florida
hemisurfer
My experience:
I have a 493 CI 440; used the Eagle stroker kit from Mancini. Each cylinder had to be notched at the bottom to clear the crank counterweights.
We also use a Moroso deep sump oil pan oil pickup The modifiction to the pickup make it all work was fairly extensive.
All work done a pro builder. I could prob dig up pics of the cylinder notching and perhaps the pickup work if you need it.
Send me a PM if you want pics.
Chris
[Re: hemisurfer]
#219811
02/10/09 02:29 PM
02/10/09 02:29 PM
kingdust
I don't mind grinding but the chevy rod ends sounds like the way to go! Who makes the better kits, I was looking at ohio crankshaft, mancini, or muscle motors. I'm building this for a friend,I haven't called anybody yet just doing a little research first. Thanks again for the replies.
[Re: kingdust]
#219812
02/10/09 04:56 PM
02/10/09 04:56 PM
Posts: 354 Livonia Michigan
440dart
Livonia Michigan
This might help. this is a 4.15 stroke, mopar size rods, you can see the notches on each exposed cylinder
Jack
Yes I live in Michigan, so there is still 1 light on
[Re: Cab_Burge]
#219814
02/11/09 12:00 AM
02/11/09 12:00 AM
kingdust
its going to be a pump gas motor and a street car, maybe go to the track 1 or 2 times just to see how fast we can go. my friend has a set of victor 440s that were made by edelbrock but have the mopar logos on them, really nice heads, i'm trying to convince my other friend to buy them and use them instead of the regular rpms. i think we can get 500hp easy on pump gas.with a nice balanced rotating assembly it should run very well.
[Re: 440dart]
#219818
02/11/09 06:20 PM
02/11/09 06:20 PM
Posts: 2,966 Wendy, I'm home.
dstryr
Wendy, I'm home.
My build is using the 440Source 512 kit(4.25" stroke/7.10" rod) in a 1966 440 block. The only clearancing required was maybe an 1/8th" or less off the oil pickup boss.
dstryr, since 1986.
