block clearence for a 440 to 500 cid, #219807
02/10/09 10:27 AM
02/10/09 10:27 AM
long island new york
K
kingdust Offline OP
kingdust  Offline OP
K
I have built a couple of 440s but never stroked one to 500 inches,how much block notching is required? I'm thinking not to much.any other small things to look for besides the oiling system? Thanks in advance for any help. MARK.
LIFE IS A LESSON,YOU LEARN IT WHEN YOUR THROUGH!
Re: block clearence for a 440 to 500 cid, [Re: kingdust] #219808
02/10/09 12:02 PM
02/10/09 12:02 PM
AndyF Offline
AndyF  Offline
Very little to none if you use the Chevy pin size.
Re: block clearence for a 440 to 500 cid, [Re: AndyF] #219809
02/10/09 01:45 PM
02/10/09 01:45 PM
Rod pin size on the crankshaft and wrist pin size, use either H beam steel rods or I beam steel rods, aluminum rods are a different story You will probally have to grind a small amount off of the oil pump pick up boss with BB Chevy steel rods and a 4.25 stroke. if you use the 4.15 stroke with Mopar rod size and steel rods then you have a lot more grinding to do on every cylinder wall as well as on the oil pump pickup boss
Re: block clearence for a 440 to 500 cid, [Re: kingdust] #219810
02/10/09 02:00 PM
02/10/09 02:00 PM
hemisurfer Offline
hemisurfer  Offline
My experience:
I have a 493 CI 440; used the Eagle stroker kit from Mancini. Each cylinder had to be notched at the bottom to clear the crank counterweights.
We also use a Moroso deep sump oil pan oil pickup The modifiction to the pickup make it all work was fairly extensive.
All work done a pro builder. I could prob dig up pics of the cylinder notching and perhaps the pickup work if you need it.
Send me a PM if you want pics.
Chris
Re: block clearence for a 440 to 500 cid, [Re: hemisurfer] #219811
02/10/09 02:29 PM
02/10/09 02:29 PM
K
kingdust Offline OP
kingdust  Offline OP
K
I don't mind grinding but the chevy rod ends sounds like the way to go! Who makes the better kits, I was looking at ohio crankshaft, mancini, or muscle motors. I'm building this for a friend,I haven't called anybody yet just doing a little research first. Thanks again for the replies.
Re: block clearence for a 440 to 500 cid, [Re: kingdust] #219812
02/10/09 04:56 PM
02/10/09 04:56 PM
Livonia Michigan
440dart Offline
440dart  Offline
Livonia Michigan
This might help. this is a 4.15 stroke, mopar size rods, you can see the notches on each exposed cylinder
Jack
Yes I live in Michigan, so there is still 1 light on
Re: block clearence for a 440 to 500 cid, [Re: kingdust] #219813
02/10/09 05:53 PM
02/10/09 05:53 PM
Is this a street car, street and strip car or a race only motor? It makes a big difference on whos and which kit and parts I would use I usually make up my own parts from different manufactors, especially on race motors
Re: block clearence for a 440 to 500 cid, [Re: Cab_Burge] #219814
02/11/09 12:00 AM
02/11/09 12:00 AM
K
kingdust Offline OP
kingdust  Offline OP
K
its going to be a pump gas motor and a street car, maybe go to the track 1 or 2 times just to see how fast we can go. my friend has a set of victor 440s that were made by edelbrock but have the mopar logos on them, really nice heads, i'm trying to convince my other friend to buy them and use them instead of the regular rpms. i think we can get 500hp easy on pump gas.with a nice balanced rotating assembly it should run very well.
Re: block clearence for a 440 to 500 cid, [Re: 440dart] #219815
02/11/09 12:02 AM
02/11/09 12:02 AM
K
kingdust Offline OP
kingdust  Offline OP
K
i see the notches. nice main caps, whos are they!
Re: block clearence for a 440 to 500 cid, [Re: kingdust] #219816
02/11/09 12:03 AM
02/11/09 12:03 AM
Bowling Green KY / Nashville, ...
300by500 Offline
300by500  Offline
500 on pump gas is a low estimate, IMHO. It'll make more than that!
As far as clearance, I used Eagle H-beams with .990 pins on mine with a 4.15 crank, and the clearancing was minimal.
Re: block clearence for a 440 to 500 cid, [Re: kingdust] #219817
02/11/09 05:15 PM
02/11/09 05:15 PM
Livonia Michigan
440dart Offline
440dart  Offline
Livonia Michigan
Best Machine. they also did all the machine work. Very class operation
Jack
Re: block clearence for a 440 to 500 cid, [Re: 440dart] #219818
02/11/09 06:20 PM
02/11/09 06:20 PM
Wendy, I'm home.
dstryr Offline
dstryr  Offline
Wendy, I'm home.
My build is using the 440Source 512 kit(4.25" stroke/7.10" rod) in a 1966 440 block. The only clearancing required was maybe an 1/8th" or less off the oil pickup boss.
dstryr, since 1986.
