contemplating twin turbo 572 Hemi #2196816
11/15/16 04:13 PM
11/15/16 04:13 PM
the Netherlands
dutchrunner Offline OP
the Netherlands
Have been thinking about if it's possible to run twin turbo set-up in B-Body early or late and putting the turbo's in the rear.
Now have 572 gen2 with EFI on it.
Turbo lag would be pressent but it's a street car and cubic inches would help in beginning.
Any body have set-up like this?
SB/RB/Hemi?
I know there's very little use for this much power on public roads but I can't get the idea out of my head.
Have been back and forth between Pro-Chager and 2Turbo.
Looking for about 1200HP.
Should not be a big problem to obtain.
Will have to go trough engine and reduce CR.
Have Stage V heads now which are GR8.
Tried to find some more info on the twin turbo'd 66 belvedere build by Troy Trepanier.
But no specs on turbo's turbine and compressor side.
Difference between 572 and 528 isn't that much.
All positive tech input welcome.
1969 Roadrunner Sox&Martin tribute with 572Hemi and F&B performance Six-Pack XFI2.0 injection.
Re: contemplating twin turbo 572 Hemi [Re: dutchrunner] #2196883
11/15/16 05:59 PM
11/15/16 05:59 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I'm a roots guy but BIGTIME ahs shown what a Procharger can do! bow
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: contemplating twin turbo 572 Hemi [Re: dutchrunner] #2196889
11/15/16 06:06 PM
11/15/16 06:06 PM
the Netherlands
the Netherlands
Hi Hemi-itis.
What do you mean with bigtime?
Is this a company.
Maybe a link to them.
Google does not give info.
Re: contemplating twin turbo 572 Hemi [Re: dutchrunner] #2196896
11/15/16 06:18 PM
11/15/16 06:18 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Bigtime Automotive, Bob Romano's dart. Runs 4.60s
Re: contemplating twin turbo 572 Hemi [Re: dutchrunner] #2196976
11/15/16 09:56 PM
11/15/16 09:56 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
With rear mounted turbo, 572 cubes, street car, only looking for 1200hp, intercooling should be easy with that much plumbing, is there a real plus going with twins? work
Re: contemplating twin turbo 572 Hemi [Re: dutchrunner] #2197056
11/15/16 11:32 PM
11/15/16 11:32 PM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
I wouldn't even bother intercooling its only gonna take about 10 psi. whats the current compression ratio?
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: contemplating twin turbo 572 Hemi [Re: dutchrunner] #2197062
11/15/16 11:45 PM
11/15/16 11:45 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Originally Posted By dutchrunner
Hi Hemi-itis.
Is this a company.
He's a Moparts member
click=> bigtime
Re: contemplating twin turbo 572 Hemi [Re: dutchrunner] #2197107
11/16/16 12:40 AM
11/16/16 12:40 AM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Ran a f2 on my 548 hemi.
Made 1200 easily. Would have went turbo but there is no room with a hemi in a b body with inner fenders.
Re: contemplating twin turbo 572 Hemi [Re: HOTMOPR] #2197174
11/16/16 01:48 AM
11/16/16 01:48 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
My line of thinking was with that much tubing in a rear mount, it would be the inter-cooling.
Re: contemplating twin turbo 572 Hemi [Re: dutchrunner] #2197175
11/16/16 01:48 AM
11/16/16 01:48 AM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
true! LOL
Re: contemplating twin turbo 572 Hemi [Re: dutchrunner] #2197220
11/16/16 03:30 AM
11/16/16 03:30 AM
Cab_Burge Online work
Cab_Burge  Online Work
With twin turbo on that size Hemi motor it should make 1200 HP with 5 lbs. of boost on pump gas at 6000 RPM shruggy
How good, and how big, are the rear tires and suspension devil
Re: contemplating twin turbo 572 Hemi [Re: dutchrunner] #2197244
11/16/16 09:23 AM
11/16/16 09:23 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
You can EASILY make your goal with one turbo. When I saw the title I figured you were going for 2500hp. It will take a good chassis and power management system to put 1200 to the ground and make it stick. My $.02Dave
Re: contemplating twin turbo 572 Hemi [Re: dutchrunner] #2197322
11/16/16 01:37 PM
11/16/16 01:37 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
The hard part is getting the exhaust pressure out. Precision turbo is going to be your best bet for sizing correctly.
You can achieve the HP you want with a single 88mm.
I run 4.80s now at only 20 psi, I have a ton left in my car. The hard part is putting it to the ground. I run a single 106mm precision turbo
Re: contemplating twin turbo 572 Hemi [Re: dutchrunner] #2197340
11/16/16 02:17 PM
11/16/16 02:17 PM
Suffolk County, New York
1mean340 Offline
1mean340  Offline
I went with a procharger on my small block only because I already had it lying around from another project I parted out and also because I love the sound of a big overlap cam.
With that said, I don't think I have ever seen anyone who DIDN'T go significantly faster after changing out their procharger for a turbo. Of course most guys who go from superchargers to turbos are also changing other things in the process, but the exhaust restriction of a turbo I'd imagine wouldn't be nearly as much of a parasitic loss as the belt drive of a blower. Not to mention you don't have to worry about belt slip ever.
I think the nicest thing about turbos is being able to dial the boost in very easily to meet track/street conditions.
Re: contemplating twin turbo 572 Hemi [Re: dutchrunner] #2197373
11/16/16 03:53 PM
11/16/16 03:53 PM
the Netherlands
the Netherlands
Twin as to single turbo is looking at the idea of 2 different sizes.
1 for lower rpm en 2e to follow.
Am in the very first stage of thinking about it.
Have a good book about turbo set-up.
But why invent the wheel again.
My speedshop guy advices to go pro-charger.
He may be right . But what if ....
Re: contemplating twin turbo 572 Hemi [Re: dutchrunner] #2197823
11/17/16 06:05 AM
11/17/16 06:05 AM
Netherlands
72Challenger Offline
Netherlands
Just because of the less hassle to install wink
Twin t setup will be more unique though...
Re: contemplating twin turbo 572 Hemi [Re: 72Challenger] #2197881
11/17/16 11:43 AM
11/17/16 11:43 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
If unique is the goal, do a rear mounted single Turbo with a Procharger.
Re: contemplating twin turbo 572 Hemi [Re: dutchrunner] #2197884
11/17/16 11:49 AM
11/17/16 11:49 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Do the crank-mounted prochargers have the problem of slipping/throwing belts, or is it just the ones that are mounted up higher to the side that have the problem?
Ron Bookman(spelling)here on Moparts has a drivers side mounted procharger that runs low 8's in his Dart and I know he's pretty frustrated with tearing up belts.
I love Prochargers, they seem to be the loudest cars at the track.
Re: contemplating twin turbo 572 Hemi [Re: dutchrunner] #2197886
11/17/16 11:50 AM
11/17/16 11:50 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
If you go turbo, find and work with somebody who can take the info about your engine and properly size the turbos and plumbing, if you get the wrong size turbos, you will not be happy with the results and driveabilty will be terrible. Getting the turbos to spool up and make power at the rpm's you want to drive the car at is critical to making the system work as I think you will expect it to. A blower is much easier for the do it yourselfer, and makes lots of power.
Re: contemplating twin turbo 572 Hemi [Re: ProSport] #2197897
11/17/16 12:22 PM
11/17/16 12:22 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
I never threw a cogged belt . Just need a ridged bracket
