Have been thinking about if it's possible to run twin turbo set-up in B-Body early or late and putting the turbo's in the rear.
Now have 572 gen2 with EFI on it.
Turbo lag would be pressent but it's a street car and cubic inches would help in beginning.
Any body have set-up like this?
SB/RB/Hemi?
I know there's very little use for this much power on public roads but I can't get the idea out of my head.
Have been back and forth between Pro-Chager and 2Turbo.
Looking for about 1200HP.
Should not be a big problem to obtain.
Will have to go trough engine and reduce CR.
Have Stage V heads now which are GR8.
Tried to find some more info on the twin turbo'd 66 belvedere build by Troy Trepanier.
But no specs on turbo's turbine and compressor side.
Difference between 572 and 528 isn't that much.
All positive tech input welcome.
