Good first day on the dyno with the new Hemi..Updated!
#219680
02/10/09 01:03 AM
02/10/09 01:03 AM
Posts: 1,624 Orange County, Ca.
B1CUDA
Orange County, Ca.
We were able to make only two pulls today, because the actual schedule isn't until tomorrow, but, the initial results are promising. The first pull was just to check and watch everything, as the motor is brand new. We took the motor to 8000 RPM, and it made 1207HP. The second, at last pull of the day, we re-torqued the heads, re-checked the lash, and did nothing else. I am not going to give the actual number, but, it was WAY over 1250HP @ 8800RPM. We are thinking this thing will make every bit of 1310-1320HP tomorrow, after we start tuning it, in detail. Thank you very much to those of you who have contacted me, to check the status of this motor. You guys kept me pumped up about doing this. Off to bed, to catch some well-deserved zzzzzz's.
Post deleted by Defbob
[Re: ChrisJohnston669]
#219682
02/10/09 01:15 AM
02/10/09 01:15 AM
Re: Good first day on the dyno with the new Hemi......
#219685
02/10/09 01:19 AM
02/10/09 01:19 AM
B1CUDA
Orange County, Ca.
what's the combo?
2007 Alan/Roy Johnson PS Hemi, with a little lower compression, and nowhere near the cam that the actual PS guys are running.
O.K., now I am really off to bed.
[Re: B1CUDA]
#219697
02/10/09 01:24 PM
02/10/09 01:24 PM
Posts: 43,124 Bend,OR USA
Cab_Burge
Chris, congratulations. Which class are you going to run with this new Bullet? Where did you dyno it and who is doing the work on it Are you willig to share any of the specs on the motor ? Just curious on what parts and size, intake, carbs and C.I.
[Re: Cab_Burge]
#219698
02/10/09 01:42 PM
02/10/09 01:42 PM
