Leak down right rear shock #2196665
11/15/16 11:00 AM
11/15/16 11:00 AM
usa
mrmopardan Offline OP
usa
Took my 68 street gtx To the track. When the car launched it pulled very hard to the right which had never happened before. On further inspection I found fluid leaking from the right rear shock. The shock had completely drained. I found nothing else wrong with the suspension. I have ordered new shocks, but my question is.. would a bad shock cause the pulling to the right Reaction I experienced? Thanks guys
68 GTX Full street trim, solid lifter cammed. Best 11.34 @ 121 mph. 1.72 60 ft. (yeah I know.. my 60 ft. sucks)
Re: Leak down right rear shock [Re: mrmopardan] #2196670
11/15/16 11:16 AM
11/15/16 11:16 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
No control of the axle housing on the right rear could cause that tire to be crushed and then bounce back on rebound. This would cause the right tire to unload, driving the car to the right.
Doug
Re: Leak down right rear shock [Re: dvw] #2196677
11/15/16 11:38 AM
11/15/16 11:38 AM
usa
usa
So, with no fluid in the shock it appears this was culprit. The car always has gone straight before this. Btw I run Caltracs which haven't moved.
