Ebay Hemi oil pans #2196073
11/14/16 09:40 AM
11/14/16 09:40 AM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
has anyone bought a440-6/Hemi oil pan on ebay? The oil pans are almost too cheap:
http://www.ebay.com/itm/STEEL-1967-87-CH...W-/152175169599
how's the quality? Summit price for a natural steel pan is almost double ($94)..
Re: Ebay Hemi oil pans [Re: DGS] #2196095
11/14/16 11:21 AM
11/14/16 11:21 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Chinese oil pan from a Cheby store for next to nothing and free shipping. How good do you think it will be?
Re: Ebay Hemi oil pans [Re: DGS] #2196103
11/14/16 11:48 AM
11/14/16 11:48 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
The description states "raw"...Take a good look at the pic...Raw, as in no drainplug ??? And possibly no punched holes of any kind...This is where you need to ask the right questions to the seller...
Re: Ebay Hemi oil pans [Re: DGS] #2196248
11/14/16 04:07 PM
11/14/16 04:07 PM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
The same pans are available in chrome or zinc plated for just a few $$$ more. I linked the raw version (surface finish) because the same one is available through Summit.
I'm pretty sure the Summit pan comes from the same Chinese factory.
Here's the chrome pan for comparison: http://www.ebay.com/itm/STEEL-1967-87-CH...E-/151681523681
Re: Ebay Hemi oil pans [Re: DGS] #2196299
11/14/16 05:22 PM
11/14/16 05:22 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
It's a pretty simple part, not much can go wrong. If it fits, I would use it. If not, send it back. All you risk is the return shipping.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Ebay Hemi oil pans [Re: Hemi_Joel] #2196335
11/14/16 06:44 PM
11/14/16 06:44 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Loc: Graz, Austria
That won't cost much ....
Re: Ebay Hemi oil pans [Re: DGS] #2196349
11/14/16 07:04 PM
11/14/16 07:04 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Just got one from Summit, the spot welds on the baffles are iffy and I'm going to hit them with the welder before installation.
"I think its got a hemi"
Re: Ebay Hemi oil pans [Re: JohnRR] #2196380
11/14/16 07:56 PM
11/14/16 07:56 PM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
Loc: Graz, Austria
yep, would cost more than the pan wink
Re: Ebay Hemi oil pans [Re: gdonovan] #2196384
11/14/16 07:57 PM
11/14/16 07:57 PM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
Thanks for the info! Kinda confirms my suspicion that all cheaper pans come from the same factory.
Re: Ebay Hemi oil pans [Re: DGS] #2196407
11/14/16 08:34 PM
11/14/16 08:34 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Do you have a US shipping address , I think I have an extra original 70-71 pan.
Re: Ebay Hemi oil pans [Re: DGS] #2196427
11/14/16 09:04 PM
11/14/16 09:04 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Take some pictures if you like, always up for some work for the cause.
I figure a $94 Summit pan is better than my old hemi unit that is all dented to hell and sealed with JB Weld.
Re: Ebay Hemi oil pans [Re: JohnRR] #2196639
11/15/16 04:56 AM
11/15/16 04:56 AM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
I do (Upstate NY). Wanted to send you a PN but your inbox is full
Re: Ebay Hemi oil pans [Re: DGS] #2196810
11/15/16 04:05 PM
11/15/16 04:05 PM
Mopar used two different street hemi oil pans, one from 1966 to 1969 that holds 5 quarts that needs the skid plate on the K member to avoid damages to it on the street and the 1970/1971 that has a different sump that holds 6 quarts and doesn't hang down as low as the first ones did scope
Which one is this one confused
It looks like a 402 B/RB wedge motor oil pan to me, not either one of the street hemi pans work confused
Re: Ebay Hemi oil pans [Re: Cab_Burge] #2196900
11/15/16 06:27 PM
11/15/16 06:27 PM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
In the description it says that the pan holds 6 quarts. Should be the 70up design then.
Re: Ebay Hemi oil pans [Re: DGS] #2197980
11/17/16 02:54 PM
11/17/16 02:54 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Some pictures, hope this helps
2016-11-17 10.47.26.jpg2016-11-17 10.47.18.jpg2016-11-17 10.47.09.jpg2016-11-17 10.46.54.jpg
Re: Ebay Hemi oil pans [Re: DGS] #2197981
11/17/16 02:56 PM
11/17/16 02:56 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Last two
Re: Ebay Hemi oil pans [Re: gdonovan] #2197989
11/17/16 03:08 PM
11/17/16 03:08 PM
That is the later one up
