Re: Ebay Hemi oil pans
[Re: DGS]
#2196248
11/14/16 04:07 PM
11/14/16 04:07 PM
Posts: 636 Graz, Austria
DGS
Graz, Austria
The same pans are available in chrome or zinc plated for just a few $$$ more. I linked the raw version (surface finish) because the same one is available through Summit. I'm pretty sure the Summit pan comes from the same Chinese factory. Here's the chrome pan for comparison: http://www.ebay.com/itm/STEEL-1967-87-CH...E-/151681523681
[Re: DGS]
#2196299
11/14/16 05:22 PM
11/14/16 05:22 PM
Posts: 7,491 Minnesota
Hemi_Joel
Minnesota
It's a pretty simple part, not much can go wrong. If it fits, I would use it. If not, send it back. All you risk is the return shipping.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#2196335
11/14/16 06:44 PM
11/14/16 06:44 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
All you risk is the return shipping. Loc: Graz, Austria That won't cost much ....
[Re: DGS]
#2196349
11/14/16 07:04 PM
11/14/16 07:04 PM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
The same pans are available in chrome or zinc plated for just a few $$$ more. I linked the raw version (surface finish) because the same one is available through Summit. I'm pretty sure the Summit pan comes from the same Chinese factory. Here's the chrome pan for comparison: http://www.ebay.com/itm/STEEL-1967-87-CH...E-/151681523681 Just got one from Summit, the spot welds on the baffles are iffy and I'm going to hit them with the welder before installation.
"I think its got a hemi"
[Re: JohnRR]
#2196380
11/14/16 07:56 PM
11/14/16 07:56 PM
DGS
Graz, Austria
All you risk is the return shipping. Loc: Graz, Austria That won't cost much .... yep, would cost more than the pan
[Re: gdonovan]
#2196384
11/14/16 07:57 PM
11/14/16 07:57 PM
DGS
Graz, Austria
Thanks for the info! Kinda confirms my suspicion that all cheaper pans come from the same factory.
[Re: DGS]
#2196407
11/14/16 08:34 PM
11/14/16 08:34 PM
JohnRR
U.S.S.A.
Thanks for the info! Kinda confirms my suspicion that all cheaper pans come from the same factory. Do you have a US shipping address , I think I have an extra original 70-71 pan.
[Re: DGS]
#2196427
11/14/16 09:04 PM
11/14/16 09:04 PM
gdonovan
Oakdale CT
Thanks for the info! Kinda confirms my suspicion that all cheaper pans come from the same factory. Take some pictures if you like, always up for some work for the cause. I figure a $94 Summit pan is better than my old hemi unit that is all dented to hell and sealed with JB Weld.
[Re: JohnRR]
#2196639
11/15/16 04:56 AM
11/15/16 04:56 AM
DGS
Graz, Austria
Thanks for the info! Kinda confirms my suspicion that all cheaper pans come from the same factory. Do you have a US shipping address , I think I have an extra original 70-71 pan. I do (Upstate NY). Wanted to send you a PN but your inbox is full
[Re: DGS]
#2196810
11/15/16 04:05 PM
11/15/16 04:05 PM
Posts: 43,214 Bend,OR USA
Cab_Burge
Mopar used two different street hemi oil pans, one from 1966 to 1969 that holds 5 quarts that needs the skid plate on the K member to avoid damages to it on the street and the 1970/1971 that has a different sump that holds 6 quarts and doesn't hang down as low as the first ones did Which one is this one It looks like a 402 B/RB wedge motor oil pan to me, not either one of the street hemi pans
[Re: DGS]
#2197980
11/17/16 02:54 PM
11/17/16 02:54 PM
gdonovan
Oakdale CT
Some pictures, hope this helps
